Old 04-05-2014, 04:22 PM   #253
Boxer486
Drives: small
The Perrin chart does seem to indicate some losses to me even with a better design and internal construction. The only way to know for sure is to dyno the same Perrin design in 2.7" versus 3.0". Even then it's not so simple as changing diameter might require a change in design as well to be optimal.
Gladly with the BPBs the lengthened runners behave as predicted with an increase and shift in the bands, so no real mystery here.
Boxer486 is offline   Reply With Quote
Old 04-05-2014, 06:53 PM   #254
Crawford Performance
Crawford Performance's Avatar
Drives: 2008 STI
It's almost impossible to get these cars to lay down identical graphs from one run to the next. The ECU adds timing as it pleases so each run can and will be a little different. When you see a sharp dip in the graph, that is the ECU pulling timing. The graphs posted above use a smooth run compared to a run that is pulling timing, so they are not the best comparison of the component change.
During our testing, we do six runs for each change to get an average of what the change actually did. This gives us a better idea of what is actually going on and helps us to create components that supply the increase we advertise.
FYI, when looking at a dyno graph you should always look at the graph and try to ignore the numbers. We can make the numbers say anything we choose but we cannot change how the graph is composed as well as the percentage of difference between the two graphs.
Crawford Performance is offline   Reply With Quote
The Following 5 Users Say Thank You to Crawford Performance For This Useful Post:
Boxer486 (04-05-2014), Captain Snooze (04-05-2014), Dimman (04-05-2014), RazBRZ (04-06-2014), Walla Walla (04-05-2014)
Old 04-05-2014, 10:48 PM   #255
DriftHappens
Drives: '14 FRS White
my fault, i missed the part about similar case! thanks for pointing it out.
Originally Posted by cslntuee View Post
Yes, you are correct.
I wrote on my original post "I personal believe that Big TB is the similar case
as "intake pipe".
I think that will slow the air flow when the diameter is increase.(
I mean the intake pipe)
It should cause losing the torque in the low RPM. (It will help for high RPM
that I understand as you mentioned)
Thanks.
DriftHappens is offline   Reply With Quote
The Following User Says Thank You to DriftHappens For This Useful Post:
cslntuee (04-06-2014)
Old 04-23-2014, 02:53 AM   #256
Gshoxx
Drives: 07 AcuraTL-s,2013 ScionFRS hotlava
No jdl headers, catback and bpb dyno yet mr. Nelsmar?
Gshoxx is offline   Reply With Quote
Old 04-23-2014, 03:22 AM   #257
nelsmar
I may or may not have a JDL header op and front pipe on the car ATM... Unfortunately we didn't make it to the dyno for tuning due to dyno schedule conflicts. So we only did street tuning I did however get 2-3 pulls to see where the car landed and am working on getting a 2.5" catback. And then possibly a few intakes. Currently the car peaks at 27% peak whp gain at about 6500rpm. But past 7k it dropped off and need lots of dyno love! I just swirched te car to ethanol a few days ago for testing and will be migrating back to 91 for tuning with catback hopefilly this week. We decided to turn it into a project and see if we can make 40-50%+ whp gain on e85 with full bolt ons. I was planning on a number of threads showing progress.
The only issue is I have a new engine to install in my car so that's holding me back a bit!
My flickr - Canibeat
Local magazine scout
Old 04-23-2014, 04:37 AM   #258
major quicknap
Drives: blue sardine
Minor detail.
Captain Snooze sends his regards.
major quicknap is offline   Reply With Quote
Old 04-23-2014, 07:22 AM   #259
Gshoxx
So to get full benifits of bpb you have to get a tune?
Old 04-23-2014, 07:26 AM   #260
Gshoxx
Very interested on this product pls keep us updated... I have catback / op/ and waiting for my jdl uel headers. And already have a stage 2 tune.. How much gain do you think am looking at if i add this bpb on my mods? Plus do i need an upgraded tune if i add the bpb?
Old 04-23-2014, 11:10 AM   #261
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Sorry if this has already been answered;
What tools are needed for this mod?
Stopping by autozone later today to slap on these bad boys.
Thanks.
Carlitoz3 is offline   Reply With Quote
Old 04-23-2014, 11:15 AM   #262
Gilwith1l
Gilwith1l's Avatar
Drives: stock brz. saving my money for ls1
Thanks.
10/12mm sockets . a socket extension about 12" long
Gilwith1l is offline   Reply With Quote
The Following User Says Thank You to Gilwith1l For This Useful Post:
Carlitoz3 (04-23-2014)
Old 04-23-2014, 11:19 AM   #263
Gilwith1l
Gilwith1l's Avatar
A 10 mm wrench to loosen a bracket on the drivers side strut tower
Old 04-23-2014, 11:29 AM   #264
nelsmar
Originally Posted by major quicknap View Post
Minor detail.
The motor is for my personal car not the one in the dyno.
You will still get a nice fain without a tune. You will just get a significant difference at higher rpm as the power falls off without a tune. I highly recommend a tune as well.
I am not quite sure what a stage 2 consists of (I just tune a car for what it has on it). It would be near to talk I your tuner. You will likely need a minor retune because of the increase in engine load in the mid range and decreased load up top. As for how much it adds with JDL header I will post dynos after I remove to see the actual difference. Both header and bpb create similar patterns of power dropping off at 7000.
The Following User Says Thank You to nelsmar For This Useful Post:
SirBrass (04-27-2014)
Old 04-23-2014, 01:28 PM   #265
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
@Crawford Performance Can we please work on another group buy?
OFT Remote, OFH, Motiv OP & FP, Perrin 3' CB & 3' IT, Setrab/MoCal cooler, STI motor mounts, Wilwood 6/4 plot F&R 12.8 kits, Brake ducts, complete Whiteline catalog, complete bushing replacement, OSGiken clutch & Diff, 4.556 FD, Stance W/Spec valving 8/9 Swift.
TouchMyHonda is offline   Reply With Quote
Old 04-23-2014, 01:48 PM   #266
Pixie_Niner
Drives: GT86
My husband fitted the BPB to my car today. Couple of clearance issues with the Cusco Diagonal strut bars I have and a breather hose needing a better seal that just cable ties.
But other than that its all good. And what a difference they make, power delivery is very crisp. I have the perrin intake pipe and CAI and they work great together. The perrin stuff on its on made a great noise but didn't feel like much of a gain. But along with the BPBs it awesome.
And all of the above is without a tune!!!
Pixie_Niner is offline   Reply With Quote
Crawford Billet Power Blocks smbstyle Engine, Exhaust, Transmission 799 01-18-2016 06:01 PM
Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 ZetaVI BRZ Photos, Videos, Wallpapers, Gallery Forum 22 04-01-2014 06:19 PM
Squidbelly wants to know the best way to gut a manifold cat regal Engine, Exhaust, Transmission 14 03-07-2014 11:31 AM
short blocks? 350matt Engine, Exhaust, Transmission 4 11-04-2013 09:37 PM
Billet Oil Catch Can #BC-175 by Billet Custom Tim_Asphalt_FRS Engine, Exhaust, Transmission 48 10-27-2013 03:29 PM
