#226 | |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
#227 | |
The largest loss was ~3WHP @ 7,500RPM. Tapering from 0-1WHP loss @ 7100 or so.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
| The Following 5 Users Say Thank You to nelsmar For This Useful Post: | Crawford Performance (04-04-2014), fooddude (04-04-2014), Metabrz (11-15-2014), RazBRZ (04-05-2014), wparsons (04-04-2014) |
#228 |
Drives: Pavement MT GR86
Is that with the JDL or just the stock exhaust test?
I would imagine different headers would also affect this as well. Hopefully someone can get nameless headers and test that, but I'm not holding my breath.
GR86 MT premium
#229 | |
Drives: 2013 FRS
Shiv |
#230 |
Drives: Subaru BRZ Limited
I cannot read Japanese well. However, I saw some improvement result from the dyno. http://www.auto-craft.net/shop/produ...?product_id=48 Thanks. |
#231 |
Drives: GT86
hmm so it seems that the BPBs will only perform well with specific headers etc?
Would that be the same for exhausts aswell? |
#232 |
Drives: Asphalt FR-S
#233 |
Forget the TB, it's already huge. Until the engine needs more air than the TB can flow, it won't do anything to help performance at all.
#234 | |
Drives: 2008 STI
Interesting theory Shiv but MotoIQ's tests were done at sea level and their results were basically identical to Marins. Maybe there is something else you did different to get different results from the other three companies? Keep digging... you will find it
#235 | |
http://w1.weather.gov/obhistory/KSFO.html Note the test dates... I tested on 3/29 you tested on 4/2. Both our barometric averages are nearly the same on those days. Both showing roughly 29.9 inHg. Phoenix isn't a very high altitude at all. edit: weather.gov doesnt have the 39th but shows most dates around there, here is another link for phoenix: http://www.localconditions.com/weath...85001/past.php
#236 | |
Drives: 2008 STI
As long as the baseline run and the subsequent runs are done in the same weather conditions, the differential between the runs will still be the same regardless. |
#237 |
Drives: FR-S 10 #103 AT
@nelsmar @shiv@vishnu
You two both give a lot to the community. I think it's time for one of you to call the other so you can directly compare notes and come up with the best tune for those of us who freely admit to being clueless when it comes to tuning.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#238 | |
Drives: 2013 FRS
The car/dyno we used are also used to developer our OTS maps so I have a fair bit of faith it in and in the process applied. Hopefully we will all learn more as more dyno results, from different cars, come in. Last edited by Shiv@Openflash; 04-04-2014 at 12:41 PM. |
| The Following User Says Thank You to Shiv@Openflash For This Useful Post: | Crawford Performance (04-04-2014) |
| Crawford Billet Power Blocks | smbstyle | Engine, Exhaust, Transmission | 799 | 01-18-2016 06:01 PM |
| Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 | ZetaVI | BRZ Photos, Videos, Wallpapers, Gallery Forum | 22 | 04-01-2014 06:19 PM |
| Squidbelly wants to know the best way to gut a manifold cat | regal | Engine, Exhaust, Transmission | 14 | 03-07-2014 11:31 AM |
| short blocks? | 350matt | Engine, Exhaust, Transmission | 4 | 11-04-2013 09:37 PM |
| Billet Oil Catch Can #BC-175 by Billet Custom | Tim_Asphalt_FRS | Engine, Exhaust, Transmission | 48 | 10-27-2013 03:29 PM |
