Old 04-01-2014, 12:30 PM   #155
was385
Drives: MT WRB BRZ Limited, 2007 911s
Impressive guys! If only these things were STX-legal...
was385 is offline   Reply With Quote
The Following User Says Thank You to was385 For This Useful Post:
Propaganda (04-01-2014)
Old 04-01-2014, 12:33 PM   #156
JDogg
JDogg's Avatar
Drives: 2013 Black Scion FR-S
Originally Posted by Propaganda View Post
I took it off and measured from the highest point... I still had about 30mm of clearance
What kind of STB are you trying to run?
JDogg is offline   Reply With Quote
Old 04-01-2014, 12:33 PM   #157
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by wparsons View Post
^^ IMO, the only reason most FI kits ditch the factory airbox is because it's in the way and doesn't work with the plumbing they need to run.
The Innovate kit runs the stock airbox without issue at all.
As FI systems go, the Innovate kit also doesn't make a whole lot of power. It's a nice bump over stock, but based on power alone, it is at the bottom of the FI list. Has anybody swapped in a less restrictive intake and tuned for it to see if anything could be gained? Probably not, seeing as the supplied tune is CARB legal, but it would be interesting to know, wouldn't it?
Old 04-01-2014, 12:34 PM   #158
Crawford Performance
Crawford Performance's Avatar
Drives: 2008 STI
Originally Posted by mid_life_crisis View Post
Probably not as helpful on an FI setup as NA as the dynamics of air being forced into an engine are different than when being drawn into an engine. I'm not an expert so don't ask me to elaborate: this is just what I remember from physics class and reading about motors.
Aftermarket intakes might be useful in the area where these blocks shine. Testing seems to be indicating that the factory intake becomes a limiting factor at high rpms. Even if the intake you select does not cheat the MAF sensor, if you have made mods that are moving more air at high rpms, a less restrictive intake should allow those mods to move even more air.
FI systems do away with the factory intake for two reasons;
1) It's big and in the way.
2) It's at its limit and FI needs access to a lot of air.
It's a decent system, but it was designed for an engine that was set up a certain way. It looks to be just enough to handle the factory engine. Once you start making other changes, you need to look at changing the intake too.
At least that's what I get from all the reading I've done.
Just changing the intake all by itself won't accomplish much, but changing it as a supporting mod for other mods makes sense.
The problem with the stock intake on a FI motor is the fact that you can run out of MAF sensor resolution. The larger diameter intake tube gives us back the necessary resolution so we can tune for the increased air flow associated with the massive power increase.
Crawford Performance is offline   Reply With Quote
Old 04-01-2014, 12:39 PM   #159
mid_life_crisis
Ah, I forgot that part. Thank you, I added it to my previous post.
The Following User Says Thank You to mid_life_crisis For This Useful Post:
Crawford Performance (04-01-2014)
Old 04-01-2014, 12:48 PM   #160
Propaganda
Diamonds & Cadillacs
Drives: '13 fr-s, 1974 911s
I have the ft-86 speedfactory tri-bar
Propaganda is offline   Reply With Quote
Old 04-01-2014, 01:09 PM   #161
Drives: 2008 STI
They are if you paint them black :P
The Following 2 Users Say Thank You to Crawford Performance For This Useful Post:
P@ul (04-04-2014), Propaganda (04-01-2014)
Old 04-01-2014, 01:14 PM   #162
OrbitalEllipses
Drives: Attitude
FYI, I did say if these made power as claimed I'd ask for a ban.
@Hachiroku, 30 day temp-ban pls.
The Following 4 Users Say Thank You to OrbitalEllipses For This Useful Post:
CajunFRS (04-01-2014), Crawford Performance (04-01-2014), Dimman (04-02-2014), Turdinator (04-01-2014)
Old 04-01-2014, 01:18 PM   #163
kodyo
Drives: Scion FR-S
NO, PERMABAN!
You must pay for your crimes!
kodyo is offline   Reply With Quote
The Following 3 Users Say Thank You to kodyo For This Useful Post:
CajunFRS (04-01-2014), raven1231 (04-01-2014), was385 (04-01-2014)
Old 04-01-2014, 01:21 PM   #164
was385
and just throw on a sticker that says "This part is definitely stock. Seriously, just don't ask questions."
wparsons (04-01-2014)
Old 04-01-2014, 01:30 PM   #165
OrbitalEllipses
Drives: Attitude
They are if no one checks under your hood:P
FTFY.
Old 04-01-2014, 01:33 PM   #166
Drives: 2008 STI
I don't blame you for questioning the validity of these parts, the gains surprised us as well. That said, in your shoes I would have been just a skeptical!
The Following User Says Thank You to Crawford Performance For This Useful Post:
SkAsphalt (04-01-2014)
Old 04-01-2014, 01:37 PM   #167
xxscaxx
Drives: 2013 SWP BRZ
Any chance you guys could make a one off spacer that is a lot smaller? I wanted to do spacers for my innovate supercharger but have minimal clearance. Just figured i'd ask. @Crawford Performance
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
Old 04-01-2014, 01:37 PM   #168
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
what? you can make a good amount of power with innovate, justn ot with base/carb tune
86-tundra is offline   Reply With Quote
The Following User Says Thank You to 86-tundra For This Useful Post:
Crawford Billet Power Blocks smbstyle Engine, Exhaust, Transmission 799 01-18-2016 06:01 PM
Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 ZetaVI BRZ Photos, Videos, Wallpapers, Gallery Forum 22 04-01-2014 06:19 PM
Squidbelly wants to know the best way to gut a manifold cat regal Engine, Exhaust, Transmission 14 03-07-2014 11:31 AM
short blocks? 350matt Engine, Exhaust, Transmission 4 11-04-2013 09:37 PM
Billet Oil Catch Can #BC-175 by Billet Custom Tim_Asphalt_FRS Engine, Exhaust, Transmission 48 10-27-2013 03:29 PM
