Old 12-15-2014, 07:30 PM   #281
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Originally Posted by Nardi330 View Post
this is my log on Stg2 UEL OFT (unmodified). any comment? thx
http://www.datazap.me/u/nardi330/nov...1-2-4-5-8-9-10
It looks exactly like every other log from an unmodified tune with the same hardware. There are tunes uploaded on this very thread you can copy and paste from to fix the knock. Also you don't need accel pedal and throttle, you should add engine load back in.
Old 12-15-2014, 07:33 PM   #282
Nardi330
Nardi330's Avatar
Drives: 86
Originally Posted by s2d4 View Post
Knock city, can't look deeper as on phone but loads of flkc.
IAM still at 1 so not too bad.
thanks.
Nardi330 is offline   Reply With Quote
Old 12-15-2014, 07:38 PM   #283
Wayno
Wayno's Avatar
thanks.
Try this
Old 12-15-2014, 07:54 PM   #284
Nardi330
Nardi330's Avatar
Drives: 86
Try this
thanks Wayno.
just looking at the thread, it seems V Power is sh17. i guess i should try redo my log using Ultimate then adjust my rom accordingly?
Old 12-15-2014, 08:20 PM   #285
Wayno
Wayno's Avatar
You should adjust your tune in the worst fuel and conditions then worry about better fuel.
Old 12-15-2014, 08:29 PM   #286
Nardi330
Nardi330's Avatar
Drives: 86
true. can't argue with this lol
Old 12-15-2014, 10:54 PM   #287
s2d4
s2d4's Avatar
Got access to E85?
Old 12-16-2014, 12:02 AM   #288
steve99
looks like the same log you pm'ed me ?
Fuel trims high 10% check for intake exhaust leaks then a bit of maf scaling might be needed or cleaning maf if you have oiled filter.
yes bit of knock top end , pull some timing for out crappy fuels as per @Wayno timing map.
Nardi330 (12-16-2014)
Old 12-16-2014, 01:44 AM   #289
steve99
Got access to E85?
I forget how bad our fuel and the stock tune is
Guy with stock car came over a few days ago running 98 ron on stock tune
IAM = 0.51
"converted him to E85"
Old 12-16-2014, 02:02 AM   #290
s2d4
s2d4's Avatar
IAM = 0.51
Haha, right on.
Old 12-16-2014, 02:02 AM   #291
Nardi330
Nardi330's Avatar
Drives: 86
yes same log which i pmed u. thanks.
Got access to E85?
unfortunately too far from home/work.
Old 01-03-2015, 07:29 PM   #292
steve99
Interesting read here on another type of knock control
Pre-emptive Feedback knock control PEKC
http://www.romraider.com/forum/viewtopic.php?t=8509
If Unknown Value(Could be delta load or MAFV) Value is greater than 0.25
could also be a throttle % delta and rapid rise in IAT
or
If RPM is greater than 1700
or
If RPM is less than 4400
or
if load is greater than 0.799
or
if load is less than 2.8
or
if primary ol enrichment is less than 1 (AFR 14.7)
or
if coolant temp is greater than 78 degrees c
then
PEKC is active
seems to be where we get "tip in knock"
Old 01-04-2015, 05:03 AM   #293
Kodename47
Kodename47's Avatar
Drives: UK GT86
or
or
or
or
or
or
then
PEKC is active
I don't think those ROMs had transient ignition retardation tables. I've read that thread before and came to the conclusion it's older logic. However, you could test it by changing the FBKC values as some have in that thread.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-04-2015, 11:39 PM   #294
Nardi330
Nardi330's Avatar
Drives: 86
quick questions regarding rescaling MAF using the tool developed by Kodename47 (thanks for creating the tool).
this is my first time doing this so sorry with the noob questions.
I have been reading the "usage" tab but i'm not sure how to use the tool.
- what is the "new maximum desired voltage" and "new minimum voltage"? how should i determine what values to use for these?
- "paste original MAF scale into the top table" means putting the value as the "MAF sensor scaling" inside the rom?
thanks in advance.
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 11:09 PM
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 11:00 AM
FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. MmmDieselFumes Scion FR-S / Toyota 86 GT86 General Forum 28 02-02-2014 09:19 PM
Fuel gauge misreading actual fuel in tank. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 19 10-09-2013 04:39 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 05:53 PM
