| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
Drives: 2014 BR"ZED" Sport-tech DGM MT
Get a set of winters and for someone like youself go to a skid/driving school. That should help with your insurance rates as well.
#16 |
Drives: Subaru BRZ Limited
Blizzak WS70's are very good...cant handle 5+in of snow that we were getting. but <4in as long as you keep moving you are good, <2in you can stop and go at will.
The 2nd gear start for manual, the winter button in automatic helps with getting rolling. Edit: Since you don't have many winters under your belt. I plead you to go really slowly, at least 20 less than posted. Because even with snow tires this car can and will kick out on you, At least once per drive and you will need to get used to that very quickly. Do not take it out with summer tires on it, you will slide a lot even in light coverage. (summer tires != all seasons) |
#17 |
Lacking brains
Drives: frz
I use snow tires.
The car has done so well that I didn't even bother swapping my snow set onto my awd vehicle, it's sat all winter while the frz was driven for the extra mpg and fun. |
#18 |
Drives: 16 CBS WRX Limited
Snow tires and driving slow will get you to where you want to be a vast majority of the time. If you're wondering if you're driving slow enough, you're probably driving too fast. If you're wondering if you're driving too slow, you're probably going at the right pace.
#19 | |
#20 |
Drives: '99 Camry, E36 M3 (RIP), BRZ
Is your dad's car RWD? Snow tires are a given, don't be like a friend of mine who gets stuck in her own parking lot because of stock tires! I've had some issues on inclines from a standing start though turning TC off helps a lot (then again I'm somewhat new to manuals). Overall it's pretty good in the snow as long as you respect it. Take it slow and easy until you get a good feel. The VSC is actually pretty good even in the snow, and when it does come loose it's pretty easy to manage. Highly recommend some parking lot practice in snow to see what an "oh s#$!" moment is like!
#21 | |
Literally 1 minute later I passed him as his car was facing the wrong direction against a guard rail. I thought about turning around and going home
#22 | |
Drives: 2013 FR-S Ultramarine 6MT
It's all about maintaining momentum!
#23 |
Drives: 2017 Audi S3
#24 |
AKA Mugen Dom
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
| The Following User Says Thank You to Fett4Real For This Useful Post: | rick s (03-25-2014) |
#25 |
Drives: 2014 SSM BRZ
Thanks to all of you again for the advice. As for my dad's car, it is (unfortunately for me) an AWD. Although it'll be much better driving in the snow, it'll at least give me some kind of experience. And for the BRZ, I'll be practicing A LOT with it in a snowy parking lot before I even think about driving around with it on the streets in the snowy weather.
#26 |
Drives: 2006 Cayman S, 2007 Outback 2.5i
#27 |
You're right, just my luck that my first year with the car was among the worst in history in terms of regional snowfall. Tire Rack had the LM's on clearance, and the description as more of a winter performance tire seemed appropriate for the tri-state area where there is typically only a couple of snowfalls per winter. Hopefully next winter is more of a return to normalcy.
#28 | |
Drives: MT WRB BRZ Limited, 2007 911s
The only other car I drive in the winter is a Lexus RX 350 with all seasons. With Michelin x-ice tires my BRZ is significantly better in the snow, so unless your dad's car has snow tires, it will probably be a bit worse (if you end up with snow tires). Just remember that even if you have the best winter tires on an AWD car, ice and snow are still dangerous. If you drive cautiously, you'll be fine. Sent from my iPad using Tapatalk |
| Snow Snow Go Away | Ny Brz | BRZ Photos, Videos, Wallpapers, Gallery Forum | 1 | 03-22-2014 05:17 AM |
| snow....starting to like snow! | brzr | CANADA | 19 | 01-23-2014 01:10 PM |
| Stay safe in snow 86ers. Don't go out with crap stock tires, only snow tires | stockysnail | Northwest | 36 | 12-19-2013 02:12 PM |
| Fun in the Snow | Tdot | CANADA | 4 | 02-08-2013 10:22 PM |
| Having Fun in The Snow with FR-S | Pavel | NY / NJ / CT / PA | 10 | 01-06-2013 07:32 PM |
