#617 |
#618 |
Drives: brz 2017 hksv2
sorry, missed that one
#619 |
Drives: 2017 Red subaru BRZ Limited
Used the mapping at the start of this thread to get the pops and such just tweaked it a bit. (used -8 for the value and just between 2200-5200 rpms). And Can elicit the pops on command with the throttle. Sounds great. Just wonder what my AFR should be sitting at while on idle with this tune. Thanks.
#620 |
Drives: BRZ SWP Limited -6MT
your afr @ idle isnt affected as you're not touching the go pedal.
i like getting a pop on upshifts @ half throttle acceleration |
#621 |
Ok just wanted to verify. It shows a 20:1 ratio while at idle so just wanted to make sure that was a good reading.
#622 |
something wrong if it exceed 14.7
20:1 should only show on overrun with no throttle i got a similar leaning when i wrongly edited the A/f #3 sensor, check that and check front #1 sensor scaling too maybe? |
#623 |
Drives: GT86
So I just copied some video from youtube which says to only change the base timing b from 2200-5200. I finished it and went for a drive but nothing happened after driving for 5km whilst playing with the throttle. I'm editing the Stg 2 OFT map if that helps. Any suggestions?
[ame]https://www.youtube.com/watch?v=ISkRrK8P1c8&t=184s[/ame] |
#624 |
you must change also knock corr A map or the total timings are still too high
or put more negative in the base timing B |
#625 |
Drives: BMW E30, 2014 FR-S
For future references: I downloaded Steve's definitions, opened it up with Notepad++ and replaced the calid that was there with my car's ID "ZA1JB01C", saved the XML, loaded it up into RomRaider and the RPMs are fixed.
| The Following User Says Thank You to kevaughan For This Useful Post: | tomm.brz (06-17-2018) |
#626 |
Drives: 2016 Scion FR-S
help
never mind, i didnt notice there were two spots to change!
#627 |
Drives: 2017 Halo 86
Thumbs up from me! Sounds great, but I had to change it to go off between 3.7K and 6K, it was just too much at lower rpms.
[IMG]http://www.ft86club.com/forums/data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAoUAAAIMCAIAAAA M9EGTAAAgAElEQVR4nOy9+5MW1bXwv/4I663zA0WBUDMFJcVYPFNgMTM1l3doDQH0y2UQJkRhGBiG4doD ylUYhvtNcLjsJCZGdEQRjWIOSmQLGEOOia8ZjUYUW3PwxGgU4i XHY47p7w+7e/e+dPfT3c/TT8OwVq2y+ll79V79XJwPa+3VveHSpUuHTryOioqKioqKWmLtu/LfR9/64Ib/8386Ozvh8Ik/oKKioqKiomaiZz7/esCUmZ2dnXD4uT+goqKioqKiZqXH//rVv/3bvwH5ZR8qKioqKipqVvr4X78eMGAA/Ojf30BFRUVFRUUN0Z89+qsfVE9ouOHGYukPqifwyR/9y1e5XA5+cvJNVFRUVFRU1BCdVFb5AvnRV2/8rlj6AvkRn/yh//oql8vBg8+/iYqKioqKihqiDTfc+OUf/uOvR39cLP3yD//BJ//xR1/lcjk4cvqdAvXh3XPAkTmrX/xTjBNfPD0n55w5fneMEwOuoWrOo38KmN+5MOFS1YgPv/jz8QAw7efKzHuWV7GZH360a4QWItrb/Pl4/dqSziZdbcB7SaCrp4EiI5afjn6Rhbydor8XVFRU1KJrww03fvH a+b88evjj3sMf9x7++NHDHz96mL38Cztwjz+WlDinPEqcs9xzv 3jtPJ98ywdf5XI5eIReKESP9G4aAXPWnH6HHbfseefI6YfHQ1V L7zv5z92zibkd2TMH3EmSXMPp0y1NVSO0oHvNKmh6WDroPe2GV iOyyx5RKU1y5PTD4wEg2tsJvryoH0iyOcWvoIjTlkxTei+oqKi oRdSGG2688urL//XzHk8fdg4OrlozeVor04Or1vhaFP3o5z1XXn2ZT971/le5XA56X3qvEH10bwtUdt9P3/Us9JHvQ/Xc3ndjTBL/FOUaRprdygyP0pfmVsL3977b+9J7j/Z2j4SWtepF6pbq7zdVjzRfkt5dU0sh11b4u8s7ZxHnT+NSs3ov qKioqEXUhhtuvHz+zKUH9176yd5LP9n7n+7BpZ/snTyt1XZl8rTWAyvvVSz/+ZO9/+k6X3pwL5vk8vkzfPK1F7/K5XLw2JmLhWjvS498H2Bk5xnxpSNNjzx25mLvY5tHAgDAyM7N3 4fq1sfe85nksc0jKzfvf+k9d5IzrZUta19SPXtfOtNaCd/f67rtbYHKzfvoS62VLWtfekSZvFew9Gqj+zur2eVp/o98H5zQvS+daa1klurWx97jkzgHnS3gvK8z3rtw3rl08Y7/Xv45nBEvKWi2CB+7++72tvD3srZJ/vBfOtNa6RjY5xZ0kfq0PhfpvoXv731vf2c1xHk7IT+DoPeCioq KevVoww03fvbyi38+tOPDwzs+PLzjw0M7Pzy848NDOz48vKOnc +Xkaa3fuaIc93Su/PPhHR8e3sH+++Hhnezgs5df5JPf+95XuVwOjp67WKA+dvZM62g AgAn73jt67uJjZx+ZANWtj/Njx75/RTW4dv105iNYWtadVT2Pnrv42L4WmP4IO143HSbse49ZxKDuJI 9MAGcSPsovlU8i+1e3Pv4em/bouYuPPb555OjN+71zxQNnhsf2tQC0rDv7nvSu97WMXHFGnhlg 9Ob9Z9977PHNIyPMFuEzf2SCt+SqnuJNLnxc6lcjX6TuIH9uwl vY1wIA7Fz97Qd/OIE/g/D3goqKino1KOOx1bPFemCL1bPlgx7hvw9secDsnDyt9VtZJk9r fcDsdNwecJwt95TPXn6RT7783S9zuRw88bJVFH38iS0jASbsf//xc70ToGbeE+87xtFbes69/8TLlmgXdf2dAHf2ipOIMmG/5P/4ud4JMHf9ufcfP9c7YfSWB86enTe6Zt4T7+uTS5ehj+6fCzB3/Tkff37N6++U3o5+oJ4lXrf7jvToQdP6X6c3rf/Vuj7u8f657hV4VzVy5Vn/j1e4SN9LzXuRMT6c4J9B0HtBRUVFvXq04YYb3yG7TzbcFKQbJ4 yfPK31r65Mnta6ccL4EP93yG4++aILX+ZyOTj26w+KpT0ra+DO 3ide7p0INfOPWcd+/cETx7ZWjN7a87J17NcfiHblFGWeJ14+N390630vW0FRKlaeY/994uXeiRK+vfmfePnc/NHCZYA0oX4x3OKcuN+5csGuHkhnaSF8Yz3x8rn5o2Hi/jyz5f2o/ed0r0F8786HDJJDlGnlz8T/ImN8OME/A9/3UsSfJSoqKmrhynh86rZRL3xv1KnvOf899b3cqdtyp743quuOi ZOntf5ZlsnTWrvumHjqttyp20a9cNuoF25j/qOYvkN288nb3vkyl8vB8d98WIg+2bOt7fgHx3/z4ZOv/LptNFTc++snXzk6CWpc49FJAJN6Pjj+mw8P3VsDrt09txVGbzv 0ygfqnK/8um1060bN7owe31YxunWS7KAFrWk7/sGhe2tgxlEn9Iyj8mWroaUZeloBoOLeX4t2/UAbdU5RJhSHnjy+rQJaN76SZ7b8H7t41vFtFWwq901xC/c/dG+N+9VIFxkyre97D/qoo3w4gT8Dv/dS4M8SFRUVtbjacMONF35yP51cI2s1nVzTPXXy5Gmt77miHHdP naydVUMn11z4yf188pa3v8zlcvD0+T8Xok/95ugknp3OOMqMXTO8l0/1zGODFfdumwQ1C45/6J74yoIxUm47qefDaBFfWTDGiyVchjM5P/ZCjNlGfvOhHHFe128+DJ7hlQVjHAdhNvVAPev4tgrho1D8J82o Ed9m3tlifOzSZbP3O2/SmJoFxz/kHz5/v8pF+k0rfkf53nL0DyfgZxD0XlBRUVGvKm244caLDx96edb3zs 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 inOMSoqKioq6lWof/3bPziPPxf1jQvP3AX199HPuOXBFrem3PKM53Bk71gAABjb/bpy1hvUGQJY+OCFz5T5QwKJ547t3stGmdv607+4C6TLCJ729fu q4a4jn7357udvHFkoXbPf5T3Y4jorPqFRUFFRUVFRi6Iej//43ueivvnuM3dD/YaXPguyv/nuM3cDQPXeF9797M2X9o71jNLBH9/7/M1HFo7tfl2ZR56Qy8KfvevMfPcjn/3xvc9f6K6H4JnD9YXuehb3Zy3ObCGX9+YjC6HlGedltXMinwEV FRUVFTVV/etnLo/funhZ1D++9+zdUL/hzOee5ZGFLjXrN5z5XHH4WQvc/Yhn/OOZ+6vElrCWZ5X5wwKdub+q+v4X3vtcHNUPgibU5nl9Q7XjH3J 5POjPWuo3PKKeiIqKioqKmqp+8tl/Ozx++/0ror518cRsqN949rLz8uy+Kuh46OLlty72bayu33j2sujw1sW+ jdUwu9czcn9lWl2VQE6s6n2nLl4WR/WDCDP3bayu39jrN5t2ee77OjG7et+pi30bqzseEi4DFRUVFRU1 Vf3kc5fH71hXRP3T+yfmQH3X2cvOy94OqNl3+v3Lfzq7rwrqu8 5e/tP7J+YAVG3pe8e68qez+6qg4+fvX+ZniaPhqgRyLTCn9/I71pXTW+rBm1A6yDuze7p3GeGXd3pLfVVNPTOe3lI/Z25HlOtHRUVFRUUtXD/lPL7wwd9Ffcd6bg40bDp3xX3Zt6kGAABqOubUNGw6d4U5zGltY BXfOb1XlLPeObfPqwm3PqfMLwfypGpr34UP/v5Ob4f7ch+bUJz54dY8c3qTn9tXJb2LsMsTnZUTUVFRUVFRU9W/Xf7G4fF7f/4SFRUVFRUVNRP97Mr/ODx+/z+/REVFRUVFRc1EP/+7y2Pr0leoqKioqKiomajH4w8++hoVFRUVFRU1E738hfu8zA//62tUVFRUVFTUTPQK5/HPUFBQUFBQULITh8c2CgoKCgoKSnbi8PgKCgoKCgoKSnaCPEZB QUFBQclekMcoKCgoKCjZC/IYBSV1udy3r154LmzHicvJp1LmAgCAunXr6+v39V32n/Zy376Q0bQvGAUFJaIgj1FQUheRiAnomHfOoksaF4yCghIuyGMU lNRFwtuJDug4ceXKFSEFrd/Xd1my1O/ruyxmwo5D4Jx9++rr9/3h9fvr6zs66llG65zcceKyMLpvX4eU8kp5sABd3wtGQUFJVZDH KCipi1z+VeHKgHe5b189dJy4fPnKlSsnOjqe/fzZDvelb4bqz2MG1RMdwA9cEv/h9fvrOYaZ/fNnO0QwKzwOvmAUFJQ0BHmMgpK6+JZ/ldyU0RFEBktrxI49ZE7GXWdm4cDjcYD/FV8eY70aBaW0gjxGQUldJLxdPtEBHc+6uazfKABzCKVgEXj87E KIwmMnf0ceo6CkK8hjFJTURV2OlenYt6+eWTr29V1xOqjr7/+DV0zOP2cyHn/+bIffvwl8LxjzYxSUtAV5jIKSusjFZ75I7NaqOzrqvXq1s2Crn hVx/TgOj/suu9m4bz9XcKkcBQUlDUEeo6CgYBM1Ckr2gjxGQbl+RUiPMQlG QclYkMcoKCgoKCjZC/IYBQUFBQUle0Eeo6CgoKCgZC/IYxSU/iz+z/Zi/dPBDVxJtqBwHwqW/FpRUK5vQR6joCQR7flZkVCUcKulAm7/9T2dPZoz5Cx2UuxYeKcyCkoBgjxGQUkiJXuKZNF5fNnFZshZJz qSZLqX3WdwJ7lQFJTrXpDHKChJxIdzffvybqAkPpoj2FNioX8g +SYlfauokGeJiFmsr5v3RE/nIjtOaJtNibtfiA/UTJZYo6CgXEEeo6AkE7VeHW0DpdCtlvx3c1JfXj7B59TLzi4ZT wRt3HRFQGaQm7DflDsqEJd7MhP3Fy8gtU8dBaU/C/IYBSWJBOXH4RsohW21JK1Ge0/nyLPzkpq8AoRu3HRF5HHAJk4Oe9VA6uVx9IrFbdwMCgUlsSCPU VCSSCQeaxsoRdn6MDyQzmN9q6ioPFYK1+yJ1vwo35aLly/37avvOHGZ4di9PMyPUVCSCvIYBSWJROKxtoFS6FZL/p1QeevVooOzVZQQl1l814/Fxi5lCwrxQAkqSt+++o6ODnHBGNePUVASC/IYBSWJ6Pc73f/v+TdQCttqKaADS99qSe/nUraKEuNyi3flIoa1/Z18q9nqZWgFc3dm7K9GQUkuyGMUlFLIVVXIDWoEu+IuHiebFu8/RkEpRJDHKCgpytW5gRJ/PpdyeWIfdew58flcKCiFCfIYBQUFBQUle0Eeo6CgoKCgZC/XEo8BBQUFBQWln8o1xmM7I2EfFkbH6Bgdo2N0jJ5SdORx1E8Ko 2N0jI7RMTpGTy868jjqJ4XRMTpGx+gYHaOnFx15HPWTwugYHaN jdIyO0dOL3t94bBGDfaYmDRzmQ9QELv7+widVYHQvljuW51LTi W4Qq/TRvXE3fCbvnY+W9L3z8CX/3rld/Oqz+eQz/c3zoaJH55PqE+qxShldHypl9BJ871Gip/e3LiS6N5bob13/4rFFDPYxUFP4OqRPSf2R5P2Q3E+qoOjUdOLymOGXmk5072dSyu h8XGJCyaJr33Ipo/Pg0g+gpJ+8bWf0vXNLFu/de8t8qOjRbf1PSvCFlTK6PlTK6CX4Wxcheoq/+ZDo4mCiv3X9isfen14dtUKy4NqpGRXHkb6nsOiyk0GsSM7Fji 79D1LK6BYxDNMU/wcpXXT1Wy5l9ICfYWm/d+Ef6yWNLvHYIFZJo3Mo8PBFj+73JyXwwkoZXR8qaXTZp8SfvO ySyt+6PNEL+1vXr3js/U8oFQzcj8mk4v+mUjkvzz9cIn1PYdGFq2AjUZyLHF0AU2mjW8Q Ak8oZS8mia99yKaNbxADDEMtVpf/exZ98qaM7pUPHXOpPXviLaBCr6NF9/qQEX1gpo+tDJY0uuKT0ty5/9DT/1oVGL/Rv3XXDY9VDKSWVjIiOPQMeu0PSb6lETHKzo9LzWPuWSxnd+8Kz iM7HuTHDT77Evzp3FAAMw0iHiOpFhF1YKaPrQ1lFT+lvXf7odo q/upDohf+t61c8zl8cCP5HTXgpIcr3lL9mK8TOoG5p2+nV7oInFP NT9ueRnM3mvTtjpfzkBYPzyyv19y7/4EsZvQQV4+i/eTONirE3vd/fZTlWKaPrQ6WOnvLfujzRheFUquWB0Yvwt65f8dh7z9q/zfUPUa9ohX9ShUUX/rkY5JxadJ9/rZUwuuShLGOW8r3zo1K+d/cfzLKldJ+875dwXfzqeFD/oSL19djy3+WQb7mU0UOGShE9/b91wdFL8asLju5K8r91/YvHwj9R8v9GxX/OhP+7JfHdF9KvRPxnk+XjnFp08Z3yX0QJowvjbvhM3rv+xZfiv btl00yi6/+IL3n0rN67973L5YFiRrftwL/LeqxSRleHShi9NH/rgqKX5m9dcHQhYKK/df2NxylJjO8Jo2N0jI7RMTpGjx8deRz1k8LoGB2jY3SMjtHTi4 48jvpJYXSMjtExOkbH6OlFRx5H/aQwOkbH6Bgdo2P09KJfYzxGQUFBQUHplxKPx1lfLQoKCgoKSv+ U2DzOMJcHgNP2vZno1RC9y16fibLoG+wHMlEWfav9RibKou/6h52Jsuh737czURZ9/2/tTJRFP/CEnYli9IOP2pkoi37oZ3YmyqIfPmxnoshj5DHyGHmMPL4aiYg8 Rh4jj5HHyGPkMfL4eo+OPEYeI4+Rx8hj5DHyOPvoyOP+w+Moz8 mL/hSxKDze7UWcwSwv0tGKhas+9CgZzAzT6D0JeFya6CHI3GhNGAo wlq5jL2d71zMrr/NGekuIcxQe32fdORRgLN3PXt7NowtGpkvIMMWuW5LxeAu9y30X DypDc4XrqaZ94c4F8njn26QcoPZknqHVPdIzBct7rMJ53D7Xm7 CuVxpau8XQ7XsuWk3VANVk7cUi8Lhjpht7Jg0cAqg/4G9JzOOeHjIMoGG983LJBGfaYfMsxZMPwQSa1xmj5wXngfvJcI DGNYLlEWvmCIARpOsRyXPpeDf6eBpkicvjgzvIcIDGe5yXS2/1flHcqAyJ9oM/tWbeBHAT2fTTJDw+1E2GAzQusw8ftrubpf+XhzdboueyRh/7oUNW83CA4aT7UAl4zB+cLT3RW9qZ3MdSAI8Z4abRe160bs0pB +6Q56wNvWjdmoPByy1mGbzc8oHi1RA9HMbgInYjvQVgyCRrHQM t566/s8tmX+coPGYwBheo99kbJhoA5uIAz2ETrf330QZgB5olGY+3WO vLAKppHwMtg64zZJ+8w5C4G+JcII8ZccGPx0FDq3sMAGPq24Xm xw5c51KfobOkHIyms/aeXhPAaDorQ7oYPN53wAQwpj/FDiTE7jtvTR8jQVq3JOYxAxK4TOpZb7LjrnkGgDGjR/BcbzIL9wlxjkjE/h09CoxB5nFXiwGg8vjAGhPAmHk/O4DGNT6WuDxmMAYXsQ5cb6W656a7DQBj5g774D0mOxDsCXnMYA wuj7l2NxsARnO34LnMZG7KkIPwLHgsbaiTbPexvDxWaJcjbY+S wQCjd9s+bNOHuIXDMm5+XJro4TAO4PGQSda6EOdlZAjALbNtHw xH4TGHscDjxWMDkt0lZBhAw932fp5P65ZkPF5BxgLcNdf2IesW +8FqGbohzoXwmBNXh27QELMHJccxeUzrtLRY4K7ZfpGB2fHZc5 aUV5t1RcqPZR4b058SeUzrVUKrlmQ85kACIUdk2jXPADCXPB7E JIlAunMUIvb76FFgLNL0wP1k+AizUcuPZfr6H8TiMYexwGPaqK XFQnJsLv2p4zP8bsuZ4SazMVF+zGGs8JjZleRYRrW57JDrOdxs LF1+bPOCtZP4Frg7d3QeP0oGsxTzUTIYjME5do5cMdaHdpsgEj FH2pLxOO3ogTw2ZynZrVuClmDs67yMDAFjiMPU+PXq+6w7h5qL 76MNwHksEBqMO5fYHmLvNkGk71CyQbck57Extsx5F1IJmmXD7v WsX2H3hTgXyuMldOdJE3x57DfUtgQAzLavi7B+zFjriIzY9rkg 8rh8i8WS6breYtarWWaswHj/b+19T3nkgDFk/XkfS3IeT6A81ZPxozKGZ5B+uaOPM0bPw+PxVMxuWaW6cY1/vZp5iujVLfF4fCs9eI8JnMcCoRXEevnxDjIcYPjdFkumG+9JWK 8+1E2GN1Ke+Mp1aYe46inLTA/Gh6zm4dC4LJN6tZv7lobHrALMeLbbBIZGHXL6UFF4XILoYevHA mK9/FheJ/Z1nm2C6DyULE6yfizyWKpFS4hNj8dzTQAYe4fVx+hbRk7K68rS UIhzEdaP/XjsO7Tza1obmhzH47Fbi+bQDeHx2i0GVJO1xVs/9vLjp8gwJRuWh4atsnRLQevHGpMOaAurUo6oD2mWKETs99Hzrx 8LPO5qMWAE6fJbP/ayYXe9WbckWT8WeezWojl0/daPjeE3wfC7rU13G3AT2VTg+rHM40OHaGNwciyuN3c3GzCcdJd y/VjYF9Ihcwnq1QxmcofU6N32PS/aM6aBlKTqQ4XXq0sTPSKPZ5vAStAb7Vlj/RCr5seCs2+KHIvHnlFbSC5BvZpVp32zXr6QHMU5Io+9tqxGsvr rmDwO9ozIY96lJTJVX0hW6tW1j1pN1SBJAJLDebx+lRt9DJk1A wDMjvNOLdoXsXEXkn2Z1DXPDTqSdD0ezKTHaYPcqbRkArBcUB/SLUFEvK6iK/R11obBw623HswwLIqA5KXjAcBc+oh94BHaCDC8xdIteXnsLPeC R1CRx2qXlt9CMqtXN6y0Zt4kX6qMZGbzqzYDgEdQlcdauqzy+B BtBBg282zzcDm6jGRIg8dexiv1c4FJfVLn4vRzMbYZtz7qrst6 TVJ6j1XIULJ+rlJFj8jjZWSI0s/l21At9HOFJdNxebyEDFPyY85a70DOoUVLAf1cXspbTb2DFWSsk g3rzinlx0qvtQLg1T1GeLE6Vn68douh5Md8tdg7kPu5ithfvX6 VofRz8UTZG3KzYd1SrPyYdyd5jUtu/qcP6ZYCM9R+Fj1Wfqz3V/Pct6vFULq3dEuB+bFPUdrtvuZuSj9Xof3VMoDF5WE1GwajuVvP p0tZry75/U78fiEmrOSr3FYkZp/Fvd+pZNEj8rhLu98phMddRbnfSaxXs7TYmXDxBvluqJLd7+SBm aXFwpDunAmP8y4ex6tXXxSy3rmUryiz7q3S3+/EeewkweKQZikWj3set2aMdCZmOZ9Yj1Xu+dGdCyRiP4teLB773 t1UhPudxHr1T4Ws91Z6SLgbShwq5v1OMl+VxWPOY4e7AJDl/U7pCHtXISu4qerVED2Ex6kqix7C41SVRY/SC52GsujReVxcZdGj8DgNZdEj8rjoGpFJKSlGz8vjlDQij1PSi DxOSZHHyGPkMfIYeXw1EhF5jDxGHiOPkcfIY+Tx9R4deYw8Rh4 jj5HHyGPkcfbRkcfXBo9RUFBQUFBQii7IYxQUFBQUlOzlGqtXf 2R3ZqJXQ/Q99rpMlEW/z96UibLo3fYLmSiLvsO+komy6Lv+aWeiLPreP9uZKIt+4Ek7E8 XoWC3PpFqOPEYeI4+Rx8jjq4+IyGPkMfIYeYw8Rh4jj6/36Mhj5DHyGHmMPEYeI4+zj4487g88lveHiPKYzIgPzgwn4jH3C ZG1pJUbL1njagHmUzPIGcymIEssHpcmeggyd1vfLweoo2vZy3Z 3Qm7hqg+1Cw/XTMbj9dakIQC30K777E1LiLfdIgAMIctDnIMssXi8yVoyFKCKP s9emmQUO4VbuOpDc7z3vr0QHs/35jkRNFRG+rhxu903xQAw9q2yLxeLx6sPOf8f1f7KZ3Tnt9bUc QDjyOpvPU8m5YesovB4z4dWUw1ADVn7oWRvn+cG2mbldY7L456 DZBhAwwbn5ZKJTqxhbZaP8zFrRgVABek6JjnDRJqMiP05ej5wK ntD8Udy6g/gVJ7WGe7M7HnBqe8NdcBvd6mDKT2t030eJ3vpbiEFoG1xwYciP q2zqDx20eqQ1SKGt7EE30YinyU+jy/RHADMp+Z5Mghg0HbL5DgEjYiXaI758LN0Sywelyx6OIzBRexaM gRgyDRr7W56CzvgnvrQbnoLO1EhenQeM5qCBtQlZCjA0AlWV7h z0OkRecxgDC5iN1lLhsKo263nN9EpAKNut56XPcoYNPUAACAAS URBVKUh+cCH3xF5vJ12AEANvbzd2lcGUEMv60OrSD1A/RTLGVpF6gGKyeOd75JyMKa+a+/8lQlgTH03gNbjyOpvFaOPczIer91mAKiI3XPUBIC6o2zUaHolz DkujxmQwGVSzwaTHXe1GQDGjIOqf1ebAeAwqWeDyXz4WXGJ2M+ jR4Ax8KdnaztVeJ58t0e+0UWwc0QeMxiDzGNnB6qg3R75blSaJ S6P+XbL0tOz/TaV8ja6kHezcLarSpfHPM91eRxlm8XoGy+ymcPruufJIIDcMdv kOIQ8RPQ/iJsflyZ6OIzBpWm7CQC3tNtrd9uz6gDKySI5OfYfYvOIlig85j QFv5RXSY5156DTI/KYwxhcmppkFMCUOfbzStLsO6SDucB6NeOxmAdzXUXqATrm25cd N6Ojpqj58epDBoDZ9i0Ds5oi73yXlI8za8dJPGaeQclxXB7veY WU15h1wSnv2m0GgNn+YSTnKDzmQNKJ0tVmAJhLjmn+FWZDhS+T VIBh9CgwBm1vqK55BtvbMYDHEn115yg85jAGgaYH7ifDR5iNIb svBx/E4jGHMXg8po1aWiwkx+bSnzo+bGPmgzvI8JvMxtTzY4sYJlV3P xZYaxAriiUxjy/RHMOhk56aTUEZJ7OL8NMtcXlcguiBPDZn8TRXSoI1xEYZis1jc 856WqUA9S4TAKrusrXkWHYOOj0Gj83tYnY7xwQRukPJz7mz7xA 7NwjGcXmsJMFyluzC2O6bYkANLXK9um0ZiDwWKcsq1bW/8urVyimF85gVn+uOBpag9xw1PRjnc47B44lUz/B6Npg+QDpmzaiAhg1SzZad65tNYvQ8PJ5A9b0ae9abOl959uyX N/s4R+LxeCpmt6xS3bjGv17NPEX06pZ4PL6VSrtLCYRWEOuzEeRP rZk3QeM9palXSxAuNY8/0pZsfYno5aOus25Jlh+nHT1s/VjgsbAkPKTcUFNe3yF2um9yHGn9WAbqenvOLX4rx77OvpZ468d Jeezlx1oynYDHrDTtmxzz1NkpXBv7VhV7/TiEx6sPGTCOrP5W4vHOb2ltaHIci8drtxlQQ9aGLgnveYWU88J 1PucY68d+FVdlYdXJGitIl7CG6uWImnMUIvb/6HnXj/32TlYWlaX8WB/SLDHWjwUed7UYMIJ0+a0fe9mwu96sW5KsH4s8dmvRHLp+68fG8 Jtg+N3WprsNuIlsKtH6sczj0terL9lN84WmKl8iHjPBqSq7zro lIY9Tjh6dx47RnlUXsCQsDjkV74BmriQ8DuVrqjyOVa/2CG1vr5LhHZfHDLd6M5fnYJ+oARh6+N+nSK1UeZAczmOvLWsca Q+oVzttXKKMI6u/ZcvM/p1fEXnsLAADQPXm8TVyCN8U+UNaB1C29WxTBOcgHjuLoKDmeSq TjtEGoa3JaWUSpYLMnggslVScQ4h4fUWX6ds1z40+knQ9Hszjx 2mD3KW1ZAKwPFgf0i1BPHbWhsHDrbcezDAsioDkpeMBwFz6iH3 gEdoIMLzF0i15eews94JHUJHHapeW30Iyq1c3rBT2aZYnLAWPP cRK3Vv5LPF5zBupFASKL3n2qTsHnR6RxyWLHpHHXosWb9pye7V 8huxZdQBgfH+t7YPtZDxeQoaKxWqlfTpVHvusDXOLNmSSUcXp5 7JP1IBEVikbhvop1mXe2OWeUuT8mGOY93P5g9nNj/l6c1HyY7FqzfgqZcNgNL3iNXbpzsXKj3krEzcq+Z/YY6w7F5ih9rfocfJj3pnlNW25ua8+pFsKzI8Pav3VPPftajGU7 i3dUmB+7FOUdruvuZvSz1Wq/mqFx6W63+mS3brd/ReMdMeRHxE/Kvb9TiWLHpXH9qJp7vWIGXAdXasPrSW8oQogfj+XL1CVxeNS8l i/qUlMlFO638lplnaljPRxHjvcde0CwlO/3ymcx3kXj4vFY8fIfl1p3O8kEEXMBVnOF8KkA0W546gfR4/D457HrRkj3ejzLKUWrdzvpDunx+ODKd3vJNarfypkvbfSQ8LdU OJQFvc7pSnsXYVXjNPTqyF6CI9TVRY9hMepKosewuNUlUWP2M9 VdGXRI/K46MqiR+dxcTUik1JSjJ6XxylpRB6npBF5nJIij5HHyGPkMfL4 qiQi8hh5jDxGHiOPkcfI4+s9OvIYeYw8Rh4jj5HHyOPsoyOPrw keo6CgoKCgoBRdkMcoKCgoKCjZyzVWr/6HbWaiV0P0I/aaTJRFP2SvzURZ9PvsbZkoi77Zppkoi77d/lsmyqLv+h87E2XR9//WzkQx+v5f25koi/4AtTNRFr3neTsTRR4jj5HHyGPk8VVJROQx8hh5jDxGHiOPkcfX e3TkMfIYeYw8Rh4jj5HH2UdHHvcHHsvbQlDveYRUGBcN8Z6XGU Ssk26gRjI3yKI7L6HLFQuY0xLwuDTRg3i52ju9WbGMIO2K8x73 AZnj6WrFmVti8XipEJ0bD1rjhwM00jVBzsPJwiBLXB6vtyYPAb iFbnVe0mr3elp9nO2VEwwAY/ISe6vv6cl43OK+iyp6OmhoKOlVLGDuKQqP57kTlpHXlKF7SB0b qqGfKs6isXAerz7oPq3zBXWobakbbykNshTI446Z7oQzaeAQQP 0Bf0uBROyf0aPhs+NOd7b9gUNwJ2WWfftNxZKYx/t7yTCAhj3Oyw2m8/PjFq6Lm5yYw0wr6PS4PH7gITIMoGF7mIXp4ilu9CVWz/P2xiXSfjLMmBqPXbQ6ZOXPsuaQtojBNo2Q9pOQLfF5/DXNAcASuvxtMghgUI+1XLdwZ9lHP/AwGZHHJYvuC8uH6RgAGE9XP2yNH8EOXMseMgRgyBzLo+zD1vgR MGSOxXyGzLE8H26JxeODdAwANNI1IoDZMWg85s6byBCAITOtNb olLo8ZTcEFKocro7JO2SWkDMDjsXJ6Mh53kkqAytut0920iR3w oW7aBABV9LTuw4cK5PE22g4ANfTTe0gdQN1ky0PsNmtPGdRNtj 7dRtvZ0Db7tckGgPmL4ubHOy+QcjCmXrB3vmACGFMvCEOuZecL JgDUviAcXCDlfvyOy+N9B0wAY/pT7EDCzL7z1vQxEqh0S4FE7LfRI8B4/UoDwJh+jIHWmH7MG2Lord9v7ztGhikH7lBiHjOacvru7yXDwLi z196/xwQw7uwVPPeYzG2DafAh5fS4PGboBYG+usWxbzeZceMSA8CY8Z A3pFuKzWOe5+qZrru3ceH7LYbXdd8mgwByJ+3lIZaTJjDL1/a0JQCNZK6Oxrj5cWmih1eVGY/FhHgPGQIwZrW9WrdweK82wbHYzeP98umI9WrG4OFkIYexzmOum 8gQgDFL7TUhlig85jTlQF1CygCq77L94bremjzEqL7FzY/105PxuMUEgKYW+3S3vadKyIM1Zje12AqPJXgXWK++h9QBtM+zP 9Ut26w9ZQA19NNt9i9q8qXFCXi8+qABYLZ944NYmccyqi+QcoD yg1ZReWxMf0pkEq1XKaVaikrEfhQ9anJsdrxs73uZ1gMMW2npP gzDw1Za61cazLnAejWnKQfqBtMAMBefDsx6dR/x9Fg85ujl9NUtum5cYgCYi09KkyjJcQo8Nqmyv5OMY2HQNemWx Dz+muYU+OkWKUO1xjW69WSWmwbhMAqPSxA9nMdKNvwwHaPA2C1 NezweQdq9/FjDeSweeymvNX642cwT34CUWkKvbonBY7NVTIWXkDIwyhzKyvV qVqm+hXr1av30QvNjyxzqx+Nu2sRgLCbNeWEci8fbaLsCY7c07 fG4jLzGDhwx9txjF6de3bYURB4riGUJsQJjl+KqMVm9mmWHCpD 2/9be95T3txLGkPXnfSwFErHfRo+VH7vQDfFZv9KA0YZzAQXUq/f3kmFNlCe+bkXaY61YlxayZHPxaf/TY/N4CuWJr69FPWW7KcLYLWJLltTWj3UeUxNc0KbK43/YJoOcWPLVLf/w1msHNRpyhurnHD0/Tjt6WHJMx4BGU54Eh/BYWD8eMsJIyGNGX3EBOITHvqvLQevNkdaPBaDeZQJA2QTLyX2H kJVSpdqYvERfPy6Yx8KScOVQwz8/ZqiuokJ+7FqKlR/zJDiMx7xw7VrS5rGXH8upM4N0UHKcMD9+igxTMkJ5aNgqS7cUL UPtZ9HjrR8bw0b78JiVppm9407IC+8Y68dxeKwvGCfmsVKIDrE ErTc/cJI2+CXHJeExK2K7r9OuV/MicIhFGVpCl+s15IQ8Tjl6eKWaN3N5dq0ErderFWfflq5wHjsF aqGZKz+P7eZGhd+aJRmPeb16vd16C3gpstPGJQpfQi4Gjx3o2n uqAhDLS9lRitsJeWz/okZGrF6vFpzzLySH85g3cEEjaT8QWK/2UP0NrXUBzNxCmrny8nj9Kjf6GDJrBgCYHeedeqwvZuIupmL00 JwYAABGk/Vu8ZnVq5UlYcZdngrzejVzDkqRfXnM27Wgkmw4rQI1Sr16/2naIKA6Fo+9JqxRZOPJRDwWGBziCSnzWEiNFSBL/VyyJT6PQxqpuIVnn57FTUx151g8Lll0fxjbzeMBwBi/xy1Nyy1acquX1PMl+yTr57KbGwHAGL/J9m/dEnPfkDauEH6z6BF5vN6aPETIj2+hW9Xu6xTyY96Zpee+chuXv 6VAHvM2Lt7Y5a0W8wM3Lfaci5ofcwzr2TAvSnttXN/QWgBoJKu/CZsznEkan6SeJp4sekNuRqhbCsxQ+230CMmx17Tl9nN5TVsMui Kzj5Fhsk+x8mOOYd7PxS28jUsBcKr5Mc+GedOWOKqsJZeOx0KD F3Aup3G/09f23B7vH+tz/S2ciMJQUe53Kln04GVjT0aQ9oft9jmG91IpXCv3O4nOCe532iR H5wmuL48P2gtnGpKnbimQx/dp9zuVgsd27+3uu2B89arTwlBK9zs5mS4AuHwVs2HlfifROW+X NfOKwuNd2v1OYqKs3N3kJdYAUIx+rv3aPT+cSU4iKA5plgKJ2G +jR+Hxy9b00c58jK+ctV4aDQBudbqY9zvJQFXud/IIfdq6s9K9BvF+p5Lw+IGT1oxRbnS3QB20eJwOj1MT9q7CK8bp 6dUQPbyfKz1l0cP7udJTFj2Ex6kqix6xXl10ZdEj1quLrix6RB 4XXWMxqeiK0SOuHxddI/I4JY3I45QUeYw8Rh4jj5HHVyURkcfIY+Qx8hh5jDxGHl/v0ZHHyGPkMfIYeYw8Rh5nHx15fE3wGAUFBQUFBaXogjxGQUFBQ UHJXq6xerX9q45M9GqI/pHdmYmy6G/YKzNRFj3bWv0G+4FMlEXfar+bibLoO+wvM1EWfc9f7UwUo+993 85EWfT7L9iZKIu+7/d2Joo8Rh4jj5HHyOOrkYjIY+Qx8hh5jDxGHiOPr/foyGPkMfIYeYw8Rh4jj7OPjjzuFzxWtoWg7gPSXFOBz8sM49ap WSQHkKuzTi20f9VBpzqRjWWzfJyP1BkA5s6F7CV3hql3JORx+t GDeHnM/YxrSSs3XrLG1QLMp2aQM5hNQZZYPH7QO326YrmLrtD9++x56w0 AwzhpO6N9ljE2wDkvj1d70ZsVi75XlfKsUNE5/FmhIci8z7pzKMBYup+9vJtfj2BkusTd7I7bdUsyHs8VglbTC3m HtljdZZpnITzebu0vA6ihXyj2+W50PqRbisLj9gXOtOW7rKAhW ECDLAUSsV9Gj4jP9rneD6yuVxpau8XQ7XsuWk3VANVk7cUi8Hj hHCH6w5593Sb5maybLGbf+47VVAVQRda9UyiP162RHwi6xhJHO 5rdgWaqWgDqD5eGxy5aHbJKe0WASZnFIJayn4RsScpja9lAAJe IO28GAHPnQmvZQICB5MhCHYfAieg6K5iMxeMSRPeF5SWaA4D51 DxPBgEM2m6ZHMag8fgSzTEffpZuicXjPloJAHfRFZypJ8lggMH rrRV9tJIdKKecJIMBPB6zEyERj302zHAtym7QR5yHePMtNIbMs VbLG2+E7aURDmNwgXqfvWGiAWAuDvAcNtHafx9tAHagWZLxeIt N7zAAzCMRhxiMoXg8ZjAGDbGrSANAwxTri+10ETvQLUXh8e7jJ gDUHbfX7jIAjGmv+gztfpWUs4PjJvPhQwUSsb9GjwJjB65zqc/QWVIORtNZe0+vCWA0nZUhXQweO3CdQ0N81m0yAIym0zKni8FjG czG9Gc8y/2HTWa5/7DJ6Hv/76zpt3hsLkl+LGwfwXis76BY+H6LgUQ8UmfkbjaFDFXA5M1UsH Acgg6/I3VGQEZ7NUQPryqfJ4MAcsdsk8M4H4/9D5LVqxlWx5J5D5oAUPmgvaLPnn4XwFgyT3UzKu9y82MO42Q8l lnrv7OkbuHw9naD1jamjMJjDmOBx4vHBiS7S8gwgIa77f08n9Y tSXl8pDoArvoQh3GxeMxhrPN4vgkAi+bbX2y3f1kDUEbe1C3Fr Vev3WUAmO0f+3HrVVIOUL7LkpkkASxxhtovo0fjMa3T0mKBu2b 7RQZmx2fPWVJebdYVKT/e+w6tk9Ni1eE0KReT49OkvMqsK1J+7KD3GTJMS45lHhvTn7Hv/x2tD06LU+OxSdX9nQxDLEZ7gxYxAAxi6ZYkPD41i+TA3ClVjN3 UU8Yhw97UO7ysVM1xtXQ2L49LFT0ExpdojsHYSY7NpqB8l9lF9 OqWBDzmabGXH7uEVirVd1GvXt1nGWPN6TzJTsxjJRt+mI5RYOy Wpj0ejyDtXn6s4Twqj83F99EGj8cCocG4c4ntIfZuE0T6DiUbd EtCHguIBaN7he1PXza0xeouM49soS3F5LH5y+10kc5jLxu29pc BlJE3dUsRebz7uBkEJBdXDoFYdhgCpARE7H/RI/H4LCnnPzAZse1zQeRx+RaLJdN1vUWrVzPcOuKH2IVzAMBc+I6X TNc9XLR6tVCFNjt+p3H6sPM5s7yZYduRW8g6zT+19WOBx97ux8 H0LQqPrWUDIVdnndKI+Ct1pdZTnYg7b4ag5d5QHpcsenh+rCwY +/LYy4ZdZ92SgMcMqBy97vrx4LGGxOOTZDAYxkl9/bgwHrMatUJTcYvJIB4L68dDRhixeexQWeSxVIuWEJsij2kLQPU d1gVG3zJC8w4VkccOlf14LKwWN5QZDn11SxHzY16Y9cOVs7zq5 YgBzsmI2P+iR+KxW4vm0A3h8dotBlSTtcVbP977sMlq0UoeLGb P3LhukwFVZF3x1o/3/d7JepXkWMqPnyHDWL1atuinlILHQgXasaZSr2YgFEWE4qk7TF/OKURkZeSAdqowHpcweh4e203zhZYuXx4fM8GpabvOuiUuj52as 9vMJWTD0+8SKOu0cYnCl5AL4DGDK2/m8uxaCVqvVyvOvi1dsXjsGbWF5PTq1QkWkkvGY2fU/mWNPKpb4vJ47S73x1RH1rp54e6PaZ3W1sTYIzc0me0f+ztHJOL 1ED2IwbxLS2SqvpCs1KtrH7Wa3H3J9dOj89hr1BKY6ruQvPdhE 9xqtuMgSgCS2WDoUjEAODkuXx4OSpp1YIcvJEOqPPZ6tThrpQ4 veajgfi6xw9mr/QZ1S4lEPHWHCVpqGzk/Lln04GVjn4Ys8SXPfXXnoNOj9nPZ0+8C/2SX93Mp7dM+/dVJecw4Csb4PW5pWm7Rklu9pJ4v2SdpP5fC4yVkmJIfc9Z6B3I OLVqS8XgFqVaSYN4+rQ+VgMe815obefeWbilKfszrsT4dTB/TOplbunOBGWp/jR4lP167xVDyY75a7B3I/VxF7K/mvVo8P2YHjMHrNhm8WC0kzcXMj9etMcRiNc+GeYcXB7ZnyTA/5i9BMJXofichbXXS02AiOq3RIPsXwOOUogekxa3b3X+0Sfc7+f H4o2Lf7+Q0S7sylswT82CG2PR4zO9fYjKCtD9st88xvJdK4Vq5 30l0Tn6/k1ivZmmx82Eu3iDfDZXS/U5O7usEPbJVuJ1JHyopj+03p7jRnSHNUhQe7/7YmlbnTOsUZl0meamkMFrcO476a/Ro/VxC1juX8hVl1r2V9v1OUtY7h/IVZcZjcfE4JR4ri8ecx/u0+52ctFiwlIrHqQl7L2FETFOvhujh9er0lEUP7+dKT1n08H6u 9JRFD+FxqsqiR6xXF11Z9Cg8TkOjMykNxehReJyGRudxGhqLx0 VX5DHyGHmMPEYeX41ERB4jj5HHyGPkMfIYeXy9R0ceI4+Rx8hj 5DHyGHmcfXTk8bXBYxQUFBQUFJSiy7XEYztTRUFBQUFBSU+upX p15jy2n1yYibKvyv5gSSbKov/LXp6Jsui/tFdloix6l70+E2XRN9u/yURZ9G32B5koi77rf+xMFKPv/sLORJ3on9qZKIu+5yM7E702eVx6IiKPkcfIY+Tx9RQdeYw8Rh4 jj5HHyGPkcfbRkcfIY+Qx8hh5jDxGHmcfHXl8zfOYek9epMwS5 emY0Z+XmYfHx35AKgAq6qxj7YGWJxfaTy6kE93rnHh7kCU2j9O Lno/HtNU529g6W7FA65QgZ7N3sWc/12Aolsg8Pu1+6QZpUSwAsJwuE50vkkG6/Tu7hRgARuNFe1lcHm/zfnIzVAvAZHqvv7M7FOIckccbrQlDAcbSdezlbO96ZuV13khvC XGOzuMWL2hP0NBQcjyvc2Ieb7XPTTYAjK0rbUu0t3qxepllJal hhmpqFZHHqw86f0NqX1CH2pa617CUBlkKJGK/jB6doLveIOUAtc+p9gWL3FiLaJClQB4vaHcnbKdBQ7VPq5by3V ZReNw+351wuxU0VHdMtcB8WhIe8ydXS7tHGMRSdo/IZ0nKY6ttIIDEP91iP7nQ3lABMJAcbLc3VACAuaHdxxKfxylGD +dx7ygAMHsXW1sHAgwk5xbbvaOEA4myPj4ujCERj7+jOQBYTpd dJIMABhFrmQNXc5qPs9VoMB+aY84SpOPz+Dk6GgAm03ufs24bx Q7sBYsMj82SszYU4hyRx4yv4CJ2I70FYMgkax0DLeeuv7PLZl/n6DzupjMARt9uvdJNZwBAFX1FHoIq+konGa34dFv3DpWdC+GxQ 1mZx1tpK0DNZMvaSlsBoJpaW62tZZ6lZrIVhmQWPQqQdl4g5WB MvWDvfMEEMKZeEIZcy84XTACofUE4uEDK/RgWl4j9NXosGIPG413PmQDGtDfYAdQ+52MpkMe7njYZbnf9npQ L3N39qb1mtwFgTPs98+EHUPu0N1Qgj3cfMxlu1243AIxp570hb tl9zPQ78***knq1u5NxlN0VY+23GMbjg3VGRYUp5qO6xYeIAQd xeZxq9Gj1amvrQIBR1FJ47ELXS45HUWuxbU0xWT7twjgZj+XEN 3faXvadPW25lharPlaj4fp8ZzUaRm550vzYIat12yiAUWTBc/aMyQGZrj4U4hyFx5yvATweMslaF+K8jAwBuGW27YPhAng8+nbL B7GdZDTAjBZbQLV171AhaS6Ex1utrWVGa7WWH8s8rplsWStJDU Brq83AnCdFjs6k1QcNALPtGx/MyEyScXWBlAOUH7QKJGJ/jR4Lxvl47H9QrHo147GY9S5oBwBzwSf2rk9orTy0ZrfBhopVr1 673QAw2y8pybHZfsnefYnWAZRvt3Qwl47HLo6FrZ5cUxRLEh4f +wGpAHODUB/WLaL/hgoAkOCnW6LzOO3oUXjcO8oBrZA0KzCW8uNzDQbncesUPZOOxe PvaI6B1k2CXZERe9oEkccGaWHJ9HKavF7N9KdkMMDgRZaTKLvR b/upfa/CbHEoxDkqj81ZSnbrlqAlGPs6LyNDwBjiQLqwejXLeoNg3E1nK DB2Ce3vH4vHrFJdTf3r1Vud1REnFW41QeRxGTlXFB63LQWRSQp mWFKoAMklmWpMQMT+Gj0qjxfRoHyX2UX06pai8FhPeb38WEb1r qfNEBgn4PHuY6YCYyk/Pk/K3Wr27mPuew+AcTo8pia4WC0Zj622gVBRZwnrtbrFJ0M9WGcoF WNuicPj1KNH7Ofia8A8LfZbFXbXjwcaNd56c4E85hheTr1aNId uCI8vkkFgNF4sYP2YV61HkQXusQdmZhTcpKEQ5xjrxwJivfxYX if2dZ5tgug8lCwuND8OLkErQ4zf4clxRB6vJDVgbF3pt37s5cd uNlx6Hns5opw+MlAFJYjFIuI1HT3G+rEfj71s2F1d1i1F4TErR OtLwu5qsVFeJ43qxe0C82MGXaUE7a4WG+W1cn7s55waj1lrltT MlX69mmFPlJFjtigWAYp0IgBU0GPt9rHbTQCj7Qe6JQaPSxA9I o/dErRPUTrA2QNw4Ty2py2X6asvJCv16mWn57idfK74IZmNhFeq9 TXgYi0ks+gReTzbBFaC3mjPGuuHWDU/Fpx9U2QWPZyaLSaw9Lfb7qkKoKw4xNict5krCo+dNi7pG/SQ7NHX7q0GKCPniliv5k1M0EjaDwTWbD1cfUNrXQgxt5CGprxE vB6iB9F3zX43egNZ8/dAHi9YBADmgr/bu/5OawHK91u6JQGP1+x2o9eRNZ84cNWbuTz6fkJrZfrqFezoPF4r bDW/1s2JeVHaB9WXaB1A3TGfCnYJeCykxgqQpe6tfJb4+bGExqAOZz f7tNoGKv1TuiX2+nGq0UN5LLdo6Y1dYPYullNnOYcujMdeG5fe 2MWL0jx11nLoAvur2QKwWGpWCtejyALe6qUP6ZYCebyMDFH6uX wbqoV+rrBkOiKPQ3q1fIbsnioAMO7ttMMq1bHWj7fJ/dWctStJjV8/F1TTNPq5eL+SlBHywqzXyvQNrQWARrL6m7A5MXqy/Jjnvmv2G0r3lm4ptJ/rE1rrglnJfb1WL7efS+7wKkJ+LDdtQd0xL/f1LG5arDunzmNLTnYYWq+i+52EanAG9zsVEj08P7Zmu7eQBN/vxHksOEv0TcpjB6XON96iWFhyLHZvFfd+p5+SweJPbhRZ4GS6T vQZPIH2Wq/FIc1SII+7tPudQnjcldr9o0xm3wAAIABJREFUTpzH3fbx2903y JLjTjJa/MSK0s8VxONt2d3vJCaLyh0+XnIJAMXoqOqv0Qvk8e7073fycmX 2dnZbHo8/sabVOXaGXtFSlPuddl+yptW6E7IVYs5jYSi7+51SFsDngYTXq1 NTFj28Xp2esujh/VzpKYsewuNUlUXPy+OUlEWPwuM0NBaTiq4YPTqPi6vReZyGRud xGoo8Rh4jj5HHyOOrkYjIY+Qx8hh5jDxGHiOPr/foyGPkcTQeZ6TIY+Qx8hh5fJ1ERx5fGzzOUDLnMQoKCgoKSkqC PEYeo6CgoKBkL1ivjlOvfnphJsq+KvvtxZkoi55tvfol+95MlE U/ZK/NRFn0bvtXmSiLvsX+XSbKou+0/5WJYnSslmdSLb8Gefxwe6kVeYw8Rh4jj6+n6Mhj5DHyGHmMPEY eI4+zj448Rh4jj5HHyGPkMfI4++jI42uex9R7PB4NshTheZlB1 Px5MxkBMKLW+vkC++F2ehtwMVctED35kGSXT4/N46fcp2M+1R5oeXqh/fRCOkm4sK520WIs+EECHtPZ7ukb71Ys5kOLgpy9oYdudkyzJyf g8Wn3K+abSXALaBshJ35eZhAv93o/sBnMQuloxaI7N9F71NMFY3QeL/WiN3PjQWv8cIBGuibIeThZGGRJxuM57jxV9JRoN0kOBBlKjojO 7GWBPO4kY8QQZeQZcXQzbXY/n8PMMtf7xA4Xhcer3L8etfQ7ZajNi3VasZSTi0UhYj+OHhGfyt M6RVWe1ulrKZzHQbtFpf20zt3eFlI+G1rwIf6gbG4Jf1pn8XjM t06UtoiQLRYx2JOtpf0kZEtSHltzBgK4QGVwvW1SgNtAsnuBva rCOdBPj89ja8FAAIm+usWD9KTbPUtXBQCYXe3WgoEAAwlpj8fj h24GAPOhRdbGgQADySnvwH7oZufAdfYZOlVvMDa788Tisc82Et q2Tp6z1Wh4m08M4vtJOJCOz2OG3iZ6D7VurVQO3CHu3EsGAww2 LTY02LTuoXabafhgOyKPD9IxANBI14gAZseg8Zg7byJDAIbMtN bolmQ8NkkOIHe7dWoTncoO8vlAFT3FLcXKjzvJGIAxd1ivejC2 1pQBVNNXGZWlA3eoQB7vsEg5GFOt73bQ5QDGVMvD0g66HABq6X c7LFLODlzLKmIozsmI2L+jR4Hxzguk3NuyQtpQ2dvfgu9mwQ+0 ragS85jBGEJ2e3Sfra1bCuSxt2WFtoGjvHeFtImFvlVz+vVqfS dj11Kc/RZ9eby71hhRYfIE9+eTTC0tFpLjCur6GHOafU6Py2NSZ1RUmGI 2rFscHt9uummxH9Er6FMxeSyx9mb61iI6G9iB/dZkU0ia3eRYGuJnFViv9vZStKct19Ji1UfYYeI7q9EwcsuT5sc OmK1bKwEqSVsvGQwweq/tk+nuNYENUXtGE0AlaWMHvmlxrHo1Y/BwspDDWOcx101kCMCYpfaaEEssHs8xAWDqHPvUJntnlV/Wu8laNlSzmyTHzioKjxlfleS4k4wBaJ5r+0DX1z8Bj1cRA2B5m +2BJ4BbUlLIzyqQiP07euTk2H+3R5nHMqq1rZqT8ZjDOB+P/Q+KVa9mPBaz3gXtAGAu+MRnb8c1uw02VDoeB+PYS5i5Sbck4fH Pm8kIMFcJBefdtd7eHzJivfx4d63BeKyfHovHT/2AVIDZJVSndYtIbn5h4lBXRRCMI/H4oZs5Vr0k+FS9IfNYH7I2DoSqgc4lJapXu1ly7rTt8pW/QRmxp00QeWyQFpZML6fJ69VK7ttLBoMxuJKdIye+Xn7swpsduJ d6a68fxaPw2Et5rfHDzWae+Aak1BJ6dUvy/NiPuyKwPULTqXlhHIvHc03Q0dtJxoAxpsz5Lg6rQ3IynYzHbSa ITPKtxCoZ4Q66PC+QIhKxf0ePwmNvi2U/xLKEWIGxS3HVmJDHi2hQvsvsInp1S1F4rKe8Xn4so3rX02YIjN PhsbYJsmhJicfWnIEwotYSF4B5LZpD12f9eKAxAow5zT6nx+Gx tWAgVNRZwmqxbpGr0wMJaWdglhaMSZ0RkDrn5/Hbi73Ks7dIPNCoknisD9HZEATvWPmxvrcxh24Ijy+SQWA0Xixg/ZhXrStJm5sES9D1Wz8eXGlAJWnzCtd+zhF5zOgrLgCH8Nh3dTl ovTn++nFuqKHyODxpVtabk/F4s3242i/ZnWsCg66SDbOqdXhyXCweszqtYg9JKItLxGs6eoE81vdjFiEdl BwnWT/247GXDbury7qlKDxmhWh9SdhdLTbK66RRvbidJo9Za5ZYdJYtq dSrGUdFEZkavJDM6tXL7w09PS+PGXRFGTlmi2LRWrr8F5Kfut0 MaOli0+ThsVadZhbfJWE+5NWr35psgn+KzKLn4bE9bblMX30hW alXLzs9R94y2x/JbCS8Us1TYV6vZrVo37VhvUwdspDMoodXqsVmrvw8tpsbFX5rl rg8FtGrIJYvGPs6h7d0sej5eeyuCvutKDfPtV9lwGYpMmNz3ma uotSrmZE3NHl2+3RtvrYmjJ63gQsaSfuBwHq1h+pvaK0LYOYW0 syVl8dr9rvRG8iavwfyeMEiADAX/N3e9XdaC1C+39ItCXjs7bhcR9Z84sBVb+by6PsJrZXpq1ew0+N xaGqsAFnq55ItcXns1yDtU5TeXWuwFeVVFeAdeP1c6fZXu7mv1 7Tl5seexW3sisVjuUVL7swKadqShmSfODz22rj0xi5elOaps5Z DF9hf7UBXKDVT69ZKIeX17fDiabFewY7Xz2U3NwKAMX6T7d+6J ea+IW1cIfyOwmNOXN7PJea+yjqx3thVOI+VdWKvjctaUybkx9X UBbOxptNvUTkBj+V+JWOqJXQw2adrAcAgq9zyLC/e8uamAonYv6NH7ufivVpSNsyL0l4b1ze0FgAayepvwuYM53F4f sxz3zX7DaV7S7cU2s/1Ca11wazkvl6rl9vPJXd4lSQ/tuRkx+3ekix2ye53EpNmlhxzHgtDpbvfideixXyaJceCJcn9Tm/dTarc01lyLFgcvnLW6kOF3e/koNT5flsUC0uOxe6t4t7v1EsGiz8wBlTlfiePxywJBgA3ORYtQ V3WbDB42dgTnuD68vigvXCmIXnqloQ8to/c7s7D+CryWFk8Fp2Lcr+Tvngs9k4r9zuF3xyVgMc7tXt+OJNWy X98ysnFHfbFqYb3MnxajB6Fx7u0+53ERFm5u8lLrNllFNzPFcL j3enf7+Tlyuzt7LY8Hn9iTatz7Ay9oqVU9zulLIDPAwmvV6emL Hp4vTo9ZdHD+7nSUxY9vJ8rPWXRI9ari64sel4ep6QRmZSSYvS IPC66xuVxcTU6j9NQ5DHyGHmMPEYeX41ERB4jj5HHyGPkMfIYe Xy9R0ceI4+j8TgjRR4jj5HHyOPrJDry+NrgcYaSOY9RUFBQUFB SEuQx8hgFBQUFJXvBenWcevVPFmSi7KvKtl5t//eyTJRF/5O9IhNl0Y/ZqzNRFn2T/WQmyqJvtmkmyqJvtd/IRDH6NvvPmSiLvsP+OhNl0Xfa/5uJXps8Prig1Io8Rh4jj5HH11N05DHyGHmMPEYeI4+Rx9lHRx4 jj5HHyGPkMfIYeZx9dOTxNc9j6uwzozz6Utq5qQjPywyi5oFmM hxgeK11oM2aOQAEMWY2i5600c8unJ6Exz9uJjcB3FRr/bjN/skCewV/BuYk1dN3SDk9Do/dLZu8zSS4RX8etc9QtOdlBvGSLnGj98xxjM+PckxLpirOVs8gJ/rzS5XTuSUWjx9yf3JVpJVZXnQfojmbdur+b1tGlTD0kPeLnZ6A x/d5p8/kxifs9vkGgHFbj71K8X/Cuq0CYCJdFcU5Co+7rLahAFX0WIiF6RzvUjd4zvbBSQaA0bbcV v2j87iFfwX0dNDQUNKrWMDcUxQeb6F3uRM+qAzN5bEAqmlfuHM yIvbj6FHYudV+ZbIBYGxbaX8YPtQqXY/qnIzH260HygBq6FeqnS523+lJz2i/NcUAMB5YZav+CXi8ioxjnrX0n8pQm/BO2Si36M5p8phvnSjv1OTg1nt6tUEsZT8J2ZKUxw6DZaBaMwcA D***AmKXVgCAubRNGfI9PTqPrVkDAFygbqs1AMwVbQy95goBsQ FD0umxeOxuEcE3lpB3mBhITnlI9hnSt5qIxePnRwGA+fxSq2cQ wCDy9lL77UaDwdUd8pzfbjSYz/OjmLN3lmuJxeO3aSUAzKadL5LBAIO7rM63LaOKHdBKZtFhDC6P +ekKpCPy+Ak6GgAm0lUKZXvYPwg0xDI3kHkc5ByFxwy9INBXtz h2OhGgYpJ1rItOFEeXsyenF8DjTlIJUHm7dbqbNrEDPtRNmwCg ip7WffhQgTzeYq0vA6imfQw2DDzOkH3yDkNiT4hzMiL27+hReL yS1AD481gccthsHi1ifsxgDBqPOaQZlfnoKtIIUBwe77AOl8O4 qdY/d9BlAOOmWh5ld9jvTTUAzBdlcvs7l6peLebDFjEM0zRA2cypoP 0WfXncVWsMrzCVBLer1tCSYxnVFZQ5+54encfbao2bKkw3wbVm DQCooH5k9R+ST09Wr+Y7J9LZIG6hKO7AqA95+y0WVq+2egYBjK L/WMoPQnw4s+kScCz/mGqKGXbMevWLZDBA5UN2Jz/QEcthDBp62RDPsOPWqxloK0i7c2yMnqilvBzGIo+DnKPwmKOX8 1W3BPC4YpLl+hsTqwrLj1tMAGhqsU9323uqhDxYY3ZTi63wWIJ 3Mh6vIGMB7ppr+9Bli/1gtQyeEOdkROzf0fMnx9a2MmNetV9+rAxttY9W50uLY/GYw1jn8SrSCLB4vq1B2lhcU6T8eBUZB7Cszf7nDutwuZz17rBf rJUtbSY4zvaLtQDl5L1S81jAsUUMMKln4Ck0d9ItSXh8oJkMB3 OpWnCmjeARV9GlFd5QwOlRefzjZnITmCu8grM1awDcNMCpwsv1 ap8h7fQkPH7oZo5VLwk+VW/IPNaHrI0DoWqgcz2J6tVuluww2OoZBI2DnAnlerVH37***QCjZ 46SVSfj8du0kjHYrT97PBYR+7ZlVJnTeU6s4VxNpqPzuIcMBhg 831rFis8TqU8J+gnrtgpzJk+peaXa1zkqj80NYr6rWzQkgwdj+ +AkA6poofVqL/e1zKF+PO6mTQzGYtKcF8YxeGyMdf40y2VYlhE6YqxfYfeFOCcn Yv+NHqVSXU196tX60FZrm3A9Psl0Eh6bJ5UM2OOx0ei+05O8Ul 1Di1av9hBrHS6XEcss7js9vMr+p5cfa84l4bGw5bFbik6dx9bM ATC81lIWgA9MMoOTY549O4Vr/fTIPLZmDYCbai1hAZgaADCAbHMK18asZu6sD+mnJ+znEjYwdhe JBxpVEo/1ITobguAdr59LSnn9EavzWFg/HmQ0Js+PeTYcwmOlxK1YfJPjKDxmiGXJcQ8ZDMZtPSHrxwKP8z pHWj/W6OvLYy8/dleXl5MKMNqWF3P9uHKo4Z8fM1RXUSE/di0F8niuCQBj77D6GIHKyEmPSfQuZSjEORkR+3f0/JVqY9tKv/VjfWgrnQdQM9lywFxGXinO+rEfj+ebANA4xfqK5dBl5K1VpBGM B1YVb/04jMduUVocctePx5UbJeYxWyt2is7K9scABjmbRr2acVQUxlR3 nTi4/2uSCTBuxu3+p0fkMeOoKDfVnuVF6R9PMkFKkS1laFyjfrqOZDa Sh8dadZpZfJeE+ZBXr35rsgn+KbITPZzHbsHZK0r/Y6oJUoqs16uV031bulj0PDy2p88GqCKtIfVqXx47ReyAZq68PH aq0OZMrzNL+sFrS8h8yTmCcxF5PMcEgIlz7GNd9oYqgCGHuyap 0X2QzEby8tiBrr2nKgCxvJQdpbidrF7NKrS+mR9fTI3iHDtD7b/R87dxSb8fB8khQ95o6EIyOykxj3m9ert9sgYAlj80Rb2eMCQzl 8T16pCFZL2UnTaPhdRYp7SXMoNJlX4u2RI/P/ZtkJaWh5VsmLVxKcAuYn/1tlpDSILNFcqBPFRYf7XcoiV3ZoU0bUlDsk8cHssNWWA+v9Rr2 uLQ1Q949xY/K1E/l9fGpXVm8X4uBcwijxnFwTBetH0q1fn7ueyZE/04KrZMK61eYn5cnP7qUB5L2bBfP1fh/dW8M0vPfeU2Ln9LMfq5vLSvmnoHK8hYJSPUnQskYv+OHmWtV2y iZrkvXyQWh1aSmrTzY6+Ny3qgTMiPOa2L2F/NMaxkw7XUpzq9gy4D2blEPFbSYQGtGdzv5LN47PJYzKdLd7+TS N/i3u/01t3E7VNykmPB4vCVs1YfKvB+p3/MIfzmsaD7nYRsWL3fSTg9wf1Ob9utXe6PLuh+pxAec09lhog87 pFPZyXrq5PHm1K736nb7r2dfwX0tFSdFoZKdr+TByeWGgpDunO BROzf0YvIYylpztdlzbwS83hHFvc7eYRmabET/UUvURacS93PlZIAPg8kvF6dmjrRw+vVqSmLHl6vTk9Z9PB+rvS URQ/hcarKokesVxddIzIpJcXoUXichkbncRoakccpKfIYeYw8Rh4jj 69GIiKPkcfIY+Qx8hh5jDy+3qMjj5HH0XickSKPkcfIY+TxdRI deXxt8DhDyZzHKCgoKCgoKQnyGHmMgoKCgpK9YL06Tr2aLMhE2 Vdln+3IRJ3of12aibLo79orMlEW/bi9OhNl0bvsxzNRFj3bevUW+7eZKEbfYv8hE2XRt9t/y0RZ9B32l5notcnjvW2lVuQx8hh5jDy+vqIjj5HHyGPkMfIYeY w8zj468hh5jDxGHiOPkcfI4+yjI4+vcR5T72F4VDW5liI8LzOI mntmknKA8hprz3x7bxutcy+mbqLiaTUNcCK2z2cWz1kwxuPxYf dxm4fbbLLAXu4+FHPcJMWTjnMDLW8LssTm8ZlZpBKgss46s9A+ 20Gnu29m+h2FOufjMXWuDoxds+2/LrV2DQJBmFF3hgVTVAuAeXxJXB4fcX9f1aSVWaj7GMsW2qn7X7 Bbuw0Aw6B2J5UfeMlniM7jjd4PfiY3Pmm3txkAxm2H7FWKvzLE T59EVc+IPN5ozRsKMJYeZS9ne9ezProztyTjMX8Epv48aj6U+H mZ4eToJGPEb7CMPCWOzuW/DXo+r3MCIvb36HnAuZnOcr/KHytDQvTXPX9rXZlsKYTH80z+Xl5Thu4hzl/zGvqp4iwaC+Txdmt/GUAN/UKxzzd5oC+CLCXhMd86kW8RIe0VwS1850W+n4RsScpjh7KMx+0 jAQaQtexARuzaGsMbGkDWzndArmE7Fo+t5gEALo831xoMrssrQ Kas1TwAYADZzIYGkM1tuiUBj63OgQAuYu+/GQDM+xfaR+sMdlCAcx4eHx8FAObxJdauQQCDyKseUHWLfXyUY3 HPsj+eTeo8NsfNjy/QSgBooYysg7utzguWUc0OaCWzKKc4DDYManfKRh/ncB4/SUcDwCS66knrtgqBqYecED48FocOkcEAg9usVU/S0ewgLo8ZX8EF6kY6gR0r3PV1XkZGAoycZB3dSCewg2Q8lreIk HY1DthGIt5+EhFTuk4yBmDMHdZ53bKZzgwaKpCI/T16KIxduDIqi5TtdHazYENj77Be5/5QJB5vo+2MrPeQOoC6yZaH2G3WnjKom2x9uo22s6Ft9muTDQDz F0XMjxmMdcSuIg0ADVOsL7bTRexAt5S8Xu3uH6HvoKjvrphkv0 VfZK6tMcpHmuW+PB5A1s6XsT2S7plvr60xGKr3TDR90+LoPN5c awyvMN382GoeAFBBD/uQlY4DZ+jwJBPAaG7WLbF5fLTOqLzZFFJezw5gdM5K7hy5Xm3t GgQwin7s0vfVBkNLjmUeDyKvLrE/nmIGpMWx6tWUDAaoPOKkvJVHbAZmNUW+YBnVRmWLIfGYefomxx Hr1YzHFaTdOTZGT/LLj5WhjSYAjN5or3rSnjnJPT06jzlfIQC9Q8kDIc6zTQCYMNs+ utFeP1Z2jsXjKFsodpJKx0fisQTvQni82VpV5p8gzpxrn99sH6 gWRn2dCyFi/40eRs1OMhZg1lzbB65zTWBDm+0fVwOUkV9yGBeLx3Iq3D7P/lS3bLP2lAHU0E+32b+oyZcWx+Ixh7HO4/kmACyab3+x3f5lDUAZeVO3lJrHfDsnixhgGGIxmufJ3Em3JOHx npmkHMx2qV7NMmMFxm5p2uOx0TSTHTjCT4/O48PNZDiYy716tdU8AIYPcOaU69VeNry51gAwmpt1Szwen5lFK sG8XypBC3nwQHJ0YULn6Dw+PkqCsVOFlixiPu3lza82eJ98XYO l+0fg8QVayRjslq89HouUZZXqFurVq4WKt3N6Mh57ma7d3mbAJ OpTr9aHvLMEnMfjsbme58TiEM99Q5y9/FiDd8L82DKH+vG4mzYxGItJc14Yx+Ixx49v1qhAyNe5ECL23+j 5eGyMdbAk16u9/NhaV8Z5bP5Yz6QL5PE22q7A2C1NezwuI6+xA0eMPffYhdart1v 7y8xfbqeLdB572bC1vwygjLypW0rLY2ETZO8wmL5F4bHVNADKa yxx/ZinxTwJDuGx7Gw0zYzFY6t5AAyvtYT1YzoOQhDrrhYPMIY7Q7o lOo+tzoFQWWed0RB7/82g5buxnOP1c73aYPBM9+Mppp4ci/kxd5YtPqdEy495NhzCY0oGg2FQW+LxBXt6S3ByHIXHrGrNaHqI DAbjtkN+68e+Q+768eAKIzaPHdBqPGYWX74qzu768cihRnIeC0 vClUMN//zY24FR2yO5cB4rKaDGKgAYU2Y4DiHOyYjYr6OHUXOuCQp0/daPx5YZ3lDReexWp6Xc14fHvHDtWoqzfuzHY2G1uKHMcOirW0r FY9aaJbVusRcOdlOpVzMMi1Je08uhu2eiKSPWp16tTKUvJIfw+ LC3m7Ijw2vP8nr14Ukm+LR02WQBG5IauHRLXh4zsorCKHu0zgC tPyuWc1weiwzmy8M+nV+j6MdLfIAdvJDMoufhsYvVoHq108Yli mFQu5OvQCfjMUttWTOX06slhXC4GzJ03F7N6tW+LV3MNzqPnbq 0XzOXL7y77MdZvdq3pYtFz8tjB7r2nqoAxPJSdpTidmwe05ngd i2FQIs55HWOTcT+HD1SvZoVpfWWri32H9gQB3AqPLZ/USMjVq9XC875F5JZ9EJ47Izav6yRR3VL2jwWUmMPyF5+rHV4yU MF93OJ/dVW0wC1n4vTlx+4abHnnCg/9umv3lxrCPmxudyvw4t3b+mWAvurz9xhgpz+Kr1a4c5xeOw1bQ kM9l1Llnq+9C6wRPmx18blYpVjmPdz+YPZzY85vxPwmHHUZ51Y SIKVVi9piLeDJe3nUhDLyArGvGW2hGeP1qIzb/4qrJ+Ld2bpua/cxuVvKZzHnWSMWINlFdpqep7jR+xpUpwLJ2K/jp63n8vLj6vp63qHl9jPVVwe8zYu3tjlrRbzAzct9pxTy495rz U38u4t3VIiHvPblpg4aL167ncSsmH1ficxw/btsi78fifOYyGfdlJh3VIYj532af5FdM4K4bGPc6z8mOW17FyX purisVDKVu93Ek4P6rJmgwFpsZf1Bt3vFM7j8MXjcB4fkm+X4g XnqDwWkubk9zupS8KeDCUPhPHYfmCSG72Q+5267d7b3XkYX73q tDCU0v1OW7Q1UY9J9lN38N+GmxRGXECNTsR+HT2Mmlu0+508Ht u/FKK/rvgXp7+aZboA4PJVzIaV+51E57xd1swrOY/tN6e4sZwhzVLqfq6UBPB5ICE8TlOd6OH16tSURQ+vV6enLHp4P 1d6yqKH8DhVjcLj9DQik1JSjJ6XxylpFB6np9F5nIYij5HHyGP kMfL46iQi8hh5jDxGHiOPkcfI4+s9OvIYeRyFxxkp8hh5jDxGH l830ZHH1wKPM5TMeYyCgoKCgpKSII+RxygoKCgo2QvWq+PUq1f Oy0TZV2X/ZEEm6kR/e3EmyqJ/ZHdmoiz6efueTJRF32A/kImy6Jvs5zJRFj3bavnvMpKr4b1vts9koiz6VvuNTNSN/m4mem3yuPRERB4jj5HHyGPkMfIYeYw8Rh4jj5HHyGPkMfIYeYw 8Rh4jj5HHyGPk8TXFY+o9DI8GWYrwvEw/YlFhpwRzequ9cp5lDBBf+jtXTnCM00eqljg8Tjd6FB7/uJncBHBTrfXjNvsnC+wV7tM6jUmqp++QcnocHtPZ7nwb71Ys5k OLgpy9oYdudkyzJyfg8TH3B1ZLWrnxkjWuFmA+NYOcwWwKssTi cY93+p1BFq7H3edrzqArufE31q1jZEssHt9n3TkUYCzdz17eza MLRqZLyDDFrlvi8rjL6hgKUEVPsJfLifNVcotiZzKUPLjJfm6O 90FtKYTH/AGc+tOw+VDip3XmBefhZme+5sOvBg2NWfOMYoHmw0XhcarvPS8 4hegvKUOd7sY1fEiIvrcoPN5C73InfFAZmiv8X1BN+8Kdk/FYDnEh79AWq7tM84zE48vPdoAsHc9ejsRjvnWivkWENMQtfD8J 2ZKAxyvuJINlmM2rNmAAmddqTx8J7IAPccv0kcB4Oa/aYAfcEovHaUePwGNr1gAAF6jbag0Ac0UbQ6+5QkBswJB0eiweP 3QzAJgPLbI2DgQYSE55B/ZDNzsHrrPP0Kl6g7HZnScWjy/RHADMp+Z5Mghg0HbL5DAGjceXaI758LN0Sywe/4ZWAsAMupIz9Te0EmDwvdZKPiRzlw8NvtdayWEMSXnMYAwuUO+ zN0w0AMzFAZ7DJlr776MNwA40S1weMxiDS98uq2Mo3DzJOtFF7 wC4eZJ1Qj9lObkZZJ8uegdo/I7OY3mDCmlP5YBNLOLtZhFOzWfWjAEYs+aZV1893MwO+NCrh5s BoPnwq7oPHyqQx2m/93BqujO/5M7sIbnb6hwqD7lBX+q2Oof68Ts2wHfoAAAgAElEQVQuj7dY68 sAqmkfAy2DrjNkn7zDkLgb4pyMx1tseocBYB6JOMRgrJM7D48d Enc8q+TErvly1Ho138lY4rFBLJ/dFZPst+hDxAmmTDLLGAAwkq4QaOdPxAFkXqvnHFQxzsPjlKPn5 fG2WuOmCtNNcK1ZAwAqqB9Z/Yfk05PVq62NAwFupm8torOBHdhvTTaFpNlNjqUhflaB9erzZBB A7phtchjn47H/QbJ6NcPqGDJf5vH/z977/mZ1ZPm+6w+xLFuPBQKBcBQQtmwQGEEFOeBEpIMTHAub8Cs2icE bkgbb/EwCTXdI6EkTKjnpodOn05lO+vRJJqNMR1Gd6bmac6TOaCKulBx Fc1VXc3vezFE3edOjmVd1X9Su37Xr2Xs/z362wVWqF9ur1n4WBseffFetqpVCVxPHm95kGrwFjMvxWMJY4/ELQxlidw6vAdgxxX4s9bRrKcRjCWNJ03n8EMDjh9hfW6LZeoWL Y5PHfnjnYVKeBo6n8abUx2CSAbByPBZg/b2EbQazJ27/3uKxAe9yPK76e88hjvc/y/7Hy+z1YYA+/EsT1fufZR76covuXI7HZ/AQwMHDzEPWV9m7W0zoBpzL8vjnWzLg6i5JGBfj8b17n5xwSGxS +cQn9+7l4bHEsRTNZrcnRV+EqWspw+OjW1Rvqd4t9MwRsgl0Ii L0lOGf5odT5UpRF/R2pZ9QIl9ddfQwj9+ZwOsgOaMSznSyC9aJDzTz1Z4l5/UyPL7zkMSqEsGfjyCTx+4SvdQNw93pn6dUvlqAduOHTIjjZH+W 3uV2Hb2upQSPf417leRNdyMMGIs8tuLxAD72P+kjA8lTrpIuwO PkhQtkB0gea4QG9NQcU4idSkCnbx++6FoK8zh5VVe3hxLQecy5 q0/pkH4CeRwAsmBcWB/TpM/HpJfJfg4kXTg2BVJhfSyeLIff357gMNa+hKYwzsnjqr/3vPrYQaxCtbMk32oDj9FQyjkzBc3VsPiv4PwZdjfgXJLHGmIBv XyG+enLl16lL69Kfv4qeRbK5atbrefSmyA7TY6r4rEUnYJ/ISKazsk4x6fxejEeVx09yGM62QXrtlFtA5ggAOjC19LENZqckM 7ukvt6yXoumXlWm8TdaNjgsbtEpiEL3oX0sbVh7OWxUsPC2bWU 4DEH6gA+Jp57v09fdHeFXR5bSe+S+8c6j41ctIHYtvNYZ2oeHl 9mrw5rRqWPM8R08f3jTX3IrxFV/0enQ3OLPP5SbQkPDAz49fHvpUCW+lhYWuRx1d977v1jHr05j/n/EITFcU4eH04AYOhxepfTdxX+zNxXNpYCziV5TJ4F2PI4/ZbTdxUmTZfK8Pieu3WcjhOf3LuXi8e8NMso5uJfpGSuKl/tbOUGMsYKlmf2JAAIPaWcz+xJwCdSc9ZXVxQ9wGPOUX2s2/Y7mZR+ZywBQyJTa2nXTvd1F8lp9DCPnew0t3i3hOWSyld/vS8Bv0Tm0ZvwmO0/ppV0eXn8YQJpTls4u5aiPE5zzkYx16Y32Yv/kz31tAZdb7667TxWRmcjue35apfH4Xy1tU+s4G1yugSPU/CwG8MZmJHp3DwJ3qI8TqErhHDW0sDCx3mS20V5XOn33pTHKWXZ 68NmUtqbr+bPTYu5iuareXbaq3rlRnIe56L1XEU3ksvx+O7NEQ AYuXn3Xil9rEtjSWe3nsss9XItxXlMUZctMY0iKUOPKmejosrw KcTjyqMXra++tg1pIjg5Yz2YS63VV5slWmZlVqBoy1gyfYrwWJ ZxWQDWv5Ta13XOej1vPRd76mkAQI/8mr1oJa49pV5OzVfbeTyH11j6WLJWPZgaWre0yGOJYa/2lbT2FXaV18eyOsnVf2Ypk9/SIo9lZZarfc0yLr+lRR5X/b03wbAs0ZJFW4K+6kEusdeHAQCdPs1CmeqC9VxK8m4h6uEMHrL UsOvcIo/P4C2WCJbl0+5SeR6n9dUplY2y6jw8lseW+OBo7dB5Jy5M+RD60 j5xpNGuzeedqo7e+nknnb7tPe/09RQeFp/HxbFmSfkqWesutXbe6Q/syA/ED51x3snH439t93mnX6t/dQChhq3zTroa9p93amO+msviNPoLF83TUJWcdzJpap130nlsbR 5fadN5p5fZ+4+Jb5kzRmVotaWKzjul+AUAwVeVndaWKjrvVPX3 3kwW/1KLrhQwf7bOO8kvxR+p1Xquq84RJgVmLou1Jde55XouooX4+VX tOJO71CqPtQIuLpXv5eRx1QPifSABHlc50+jhfHVlk0cP56urm zx6uJ6rusmjB3hc6eTRAzyudOZhUnWTRw9Ts7qxHL73nPnqts+ cPK5o5uFxddPD49L6OPI48jjyOPI48jjyOPK4DTwW9Vyl948jj yOPI48jjyOPI48jj9vGY3fkrq/uDI9rmpHHkceRx5HHkceRx53LV4eHn9edGrXzOI444ogjjjgqG gaPxd4x6Jo48jjyOI444ogjjqqHff6Yl3Hxp2W6f1wfj9nisVo m/6dayfnqP7Gklsmjf8VerGXy6BfYtVomj36Z/ayWKaK/X8uM0a+wj2qZPPor7P+qZfLor7Iva5ng7B+nslh/XnY87jwRI48jjyOPI49XUvTI48jjyOPI48jjyOPI4/qjRx4vBx57xzKrr448jjyOPI48ftCJGHm8onmcs746gEx5O6a8 h7qS+zJ9xCKylyxAMnGULR6jo136l/ac3Yr0pQlxY+XAnhI8rjZ6Hh6H78vUZ3vvy1Qtm1QzCWlx76P2 LOW7LzOLlx+LH7ARfNiyQPJklvMsmc96vRCP31axxi3LJDljOX 8q7suUS/8kr04Vrxfl8Xm6rwEwSK6mX5It4gOPeJzZi3sQANo3x656Xy/K40t0ug9giNzhX06L770P/8jynFZ/UWfV6+xHYwgATZ9id0rw+BI93AcwRH7Bv9RCLFqeaknzv8TeGE MA6PAp9osSRHzgoweQeZke7wMYJh8GLHxqt6JeVM7s1hgCQMfn me2fn8fa9Z8/tpZeJk/pS6fxZtBGH/5Vizw+jQf0D1yFP9ZXXyHiWtTkNrccVn/U223gMe983JzHomlEqI0ExUgtyX4SpqUEjxeexg0TZrNbEXTh2 aNsYgPwBweHIIko6TixAbwEDfO46ug5eEwnuwD0fhKQnDnO0au aRvyX57KWjNcL8Vi0iJCNJcwOE934c4Vkz5LbaqIIj/9INgLALJn/CvcA9LxO56Xlj3TXiMbdP7HE9DGc5VIhHnOaTpIz/0TRIMAkOfMp7gXoXaRn/ols4g/KmaJBc0m+JT+nKI85TUEAVcKVU9ml7BxeBaB4bL1elMccxiB4f Ins5s+n8HqA9WNUIVYuWfw+hdcDlOQxBxIIxlwij/JnC1SKPQ6oTuENACWJuBKih2EMGn1dS2onewH6x+iHl8lefXUe 9wO0xOOXyVMAmx+jf8/RO0z+Xi3RF/sAholn6TTezN9qlz4+jQcABh6nv1cwpgurALaQ33MqGw9iqQCP 1XmnkZt3793TK67z56s9jRMFotvTb9FDxD2JSTI62gWwgSwctZ WohkMJP+WclTFuwuOKozfl8bVtaF1/IgSuaqrox7azZL5eLl8tOyeSadBbKOodGN0l1W+xtXz1V7gHYO PHTAGV81hXvR8nwH3+yJ6cNZfc1wvlqzlZB/HRtxMA2PQ2O/NPbHwSYBAfNcXxpreZBe9NbzMPhvPwWNJUAnUOrwLYcpD54Xqe 7mugLYNCH7uvF+KxhDFofNUou3vah1j+FlfPl+h0H9o9VEofSy CBiR+51Iff0Ji0OOR1Q48OlVKoKyR6GMaSr64lg8f9Y1T4o73D reljk8cGYk/jzQBPPcts6HJOh8VxIR5zvlri+DQeAJg4zDzQ9fqH948Vfe99c mLk5s0Tzt2ZzXlMEpeqUjGrjsjC5FrK8FiDHDS20oWjZAB0IqL Rpw3ngT26GKWjXdDoSj+hRL666uhhHr8zgddBckYlnOlkF6wTH 2jmqz1LzutleHznIYlVJYI/H0Emj90leqkbhrvTP0+pfLVQyTZNXcmr9LGJau/rhXgsZbHSx4LQZmZb8XgQH/0U9wLqHeQBiuerz9N9jeSILoXn8CpAq1LKmvlqnqkeJCpf7b5e mMfJWSl8TSnsh7FA9foxeodnqodIyXz1JXq4L1mUutBRfhvG6C +8AOME4qpxiJTMGK+Q6Jk8Ti7qete1OEgGBWN2awzBMGlDvlok pW29expvBrQ5/a61VPazCXg5XZrHhxNw0XsaDwAaWJVGv20vmWK6KY+t+mrPRda Qp57LUrpaW+SqeCzTwoJ/ISJqW7aciGQArNeL8bjq6EEe08kuWLeNahvABAFoTY7R5IR0dp fc10vWc2kNjMUmcTcaNnjsLpFpyIJ3IX1sZad5ItrdEha7xT0j yFh1k9v5ecyzzRK9Yv+4dxA14fHbCWTBu8D+sQbUgwkArNpDU+ 3bwC8amWq0b87dPy7LYysRHdhUtpy5OD6F1wOaPtXi/rHDJG7RBaIwbhijv5Dy8RTeAOjwqRZ3cB/06KH9Y4e+Xh4rfSx2l+dxP6Dj8y3vHyt9LLLTJnfVEhfEL7MfD +cQx/l5/Aq7vcUndg8nwKFrqWGetQ6L46Y8Ln3eSdsK5sVaRjFXBflqZys 3lDF2iKicF/Yk4BOpOeurK4oe4DHnqD7WbfudTEq/M5aAIZGptbRrp/u6i+RcPHay09zi3RKWSypf/fW+BPwSORePtRQ0h6tbzGU56/R1M9g5ecxR6qpbnq/Wt4QD+Wru7JXIhXgs89Xn2ZFBUBI5LePSh9xCroLH7OyQU9KV5 reTs6qMy/jzeJBclEmpFnT2SpU/h9D8rBPdg6UYvXUeH0oAYO8h9uFldnEYoHH7shPdg2S+EqamFL suaGW+mi9xiezuJbfKY7Er7NtRnjjMfs+BzSUyZ3PTYi4vj70j Vz2Xp4xLl8YWkI16LtNSnMd0tMuWmEaRlFqySpq1iiqfTz4eVx 69aH31tW1IE8HJGevBXGqtvtos0TIrswJFW8aS6VOEx54yLvbk LACgXV+J/LPUvspH1HO5rxer5+IcRehTZtRLixIts2jLqN6SS4ZPizw+T/c1NH08SK7a1ddV6mOVi3aqtzihXei2Wl+tMYlvlOp0kcVNMotr ba+2WuH8oEcvzWNDDfvquVqvr5aVWRK0qoyLvtjnSOesTeXSPL b2iVUZF11YpenjLUSAGS2c9m0qh3jc8nkneXAp5ar62mds53kn Lkz5EPrSPnEUIOJia+edqo7e+nknnb7tPe/09RQeFp/HxbFmSfkqWesutXbe6Y/s8OviR4yr269wj/4jN4IPKx5rzhy97uuFeCzPL/ExiI/+Ezu6KD6Q81VnbSXnnUygWuedOsljXfWqii1Vca2GlM5t5HFaM KxCvCGZlLIn/WtRCrKNRHwgo7fO4ysdPO+k09c675R/8zg/j63NY7122jrvFD4clcnje/c+OeG7sNo69QTxPpA6Jv+3DPG4yplGD+erK5s8ejhfXd3k0cP1 XNVNHj3A40qnoEImjyudTZlU6YzRAzyudObkcUUzJ48rmqDr4/Ssk0NlnsUeuXk39/5x5HHkceRx5HHk8X0cPfK4Zh7z4W4iFz1/HHkceRx5HHkceXxfR488XhY8bmH/uFM8rmlGHkceRx5HHq+Q6JHH9wePaxy18ziOOOKII444Khr3E4/jiCOOOOKI40Ed91O+GgBu/iOrZfLo7MTRWmYa/b2ZWmYavdZ89b+zpJbJo/9vdqaWyaNfZD+sZfLol9hPa5kxer3RL7O/qmXy6FfYx7VMHv1l9ttaJhjnnTKZvVz6H0ceRx5HHkcex+gdiB 55XCePpQK+d+/uzRF1czW/NzPq48jjyOPI45XGpJUcPfJ4mfDYuLna+jLyOPI48jjyeIUwaS VHjzxeJjy+e3Mkvf0j1ccjN+/m4zERd5hVdF9mTh4vLRhx1yxQffWEuM4MJohtARi5XYbH5CH1C cnjR1L75Bakf+k4G0sZznl5/LMJvB5g/Tb6s+fYezNkt/bnOfuc7imXDLv5eiEei5ZNqpmEtLj3UXuW8t2XmcXLz8SP3E58 OMviOs+RecsCyZMleHxHvD6Mj3DLF+JSzGly2vX/hqJhbemOij5ejscX6Pf6AIbI9fRLsk184HHLcw6v5ivSeUpG14 yFeHyRHuwDGCLv8i/lB/bhH1ieZqx3dYt8vSiTYvRKoweQeYke7QMYIh/wL6fVj/H5/M7SUpTHl+lsH8Aw+e8BS9bSIfUX9XY5Hl+hc30Aw+Rv+ZcJfpi/Ii1yukva7aE/yMtjiWQxjC5PEOCxaCPhNk5UFoqR6jmRYWmfPl5aQABo/GNleeN2wi1v3E4AYOQ2e+NLOj6o2FxGH88+hbsBHtpjGCe38P8 psBBLt3***OHJI+zxDelDtnN+HtND3QACqByuu8cy3Lrxa8+xs/3pg/t6IR6LFhGysYTZYaIbf66Q7FlyW00U4fGfyUYAmCPz3+AegJ43 6bxrkc6mj/ugIJ2Tx9+QTQAwTU5/gXsBei/T099QNMwfyCZucWEMgsfydQvS+XnMYQyCppLNnMo6Yi/Q7/XB6r2UL63eS69fYGf3Ig+28/OYI0H+Wr9IHuHPJ/E6gHV7qfpdf5H9YC8CSF6UFulzkTxiOedkUoxedfQwjEEA9RLZ w58t7nqdRX+LDy6RPfyhKI85X0FDrGvJcr5MHuPP8/ghgIfGqIffPHoYxiAQe4XO9cHDj9G/vUKeAHj4Mfq3pqexZD54+J3J4xbrq+3GiRqfW+y3WIjHb3yM1z ji2OQxGv+YvfElGcmWxfl4vCfxiV3wIZY8BAAbyOwR/hba/lTAOS+PX9uG1vcnUuD+bCxxZLEmjvuJ8EGHJjyvl8pXy86JZBr 0Fop6B0Z3SfVbbC1f/Q3uAdj4GZsPWD5LgFv+zJ6cA9iJD7tgLpev/gL3Amy6w07LBxexEsbgoJcvSYWdk8cSxhK9c3g1wLYp5lG6ckk xmx0fypDFeXgskQCOzDqJ1wE8MsV0Krw4ZLpNJcB9+JKr6sJMi tE7ED0MY8hAbx/+i4DzdAIAe6bZB5fY+SHTOQ+PJV9BItaxBJzlnMcPATx2iBXjs YQxCJom+GGAJw6xv7VEs3fJBXNufSxvsjZz17l4TBKLqqr7ov4 sIO1a2sXjExMAkJz40uH0bf5LNtXNHNvpGMRLjn9zHmtAhe4td PYIm9yCHtrDHt8AAX08uQVJHmc45+LxzybwekjOagnn17apP4+ JWKWPX9uGOI/d10vw+M5DEqtKBH8+gkweu0v0UjcMd6d/2lL5aqGSDfS6FkMf0107RTabK+MsGOfh8TdkE2ewyD8rHuuI/Yai4WRcamIH57aYzsXj5LguhefwakCr018ZpvCdSkDncR8+q+M c0PfmfBTni5lUSF6UykzZySMWEiyEADp4kiklx5fKMClGrzh6J o+T81IT60tS+waclT524J2Xx8nLUuZ6LQHn1E4ey4Jxcx4nP9D V7aEEdOj24Z9JZ+8SfzcLxoH945Gbd9MyrjL1XIbSNdLQHeMxV 72WODb08cd4Dc9Xmxb3leY8lplniVhlD+wfd6Hu5s5NeUwPdcP 6bVTfAJa5aAldz/5xN1oP6NCE5/Vy9VxaA2OxSdyNhg0eu0tkGrLgXUgfc8TqCWfXou0W9+xEpj72 OefXx1INB3hspbgti1cc59o/1ng8lUCaixbQDfFYJq4d5wL7xw4VJAMcVNgMELuY6/pQYSbF6B2IHto/dnjMLV6+Ws5i/3hDHyrMYw2oLmIz9o+zUJ3hH+BxSuWyPFb62BHTYR5zALfAY53 BujquMl+targG8dKXans4SzS7wA5vJKdMChdCWxvJQcTaWe5yP OYc1YfO1OyNZJ6vnv9+8PVCPHay09zi3RKWSypf/fW+BPwSmUdvwmORgg5YrKU5Mu9msEvymI1PAwzjI4F8tZfHaRI 7o5irKI9VUpodHwJDIrv5avUJ2RvJJamQnQh1tzPdhGqrTIrR2 xQ9P4/TvLSvmMsL78vsr3i+2lvS1Qkes5eHM0q6CvG4UL5aEZr9YNiEd 5N89Scn4MQngse5zx8rfasx2LuXnBCrnsu0lOKxD88qWS3VsKz wksBWlrL62JOCdhEry6elUa/nakEfuwXSnqT0a9sQ31E+2w/qQdVzla6vNku0zMqsQNGWsWT6FOFxoIxLWqT2VRYhi13nQjxWZ VxOZZas57LArPOYUxwQ+oJ5MtUleKyKtuQmsfsgZPEcXt1efWw WCsEQeVfKNTdHqnzK1jTF6FVHz8ljTlZAR08xA8+K1rqzLP4qW 8/VlMeW9tWXZBlXgN+FeOzZG5YWZynBD5es5zLqq7XDTs30sTrf5 ElQO07VnXdyN48lj286551SWaxZitdzPYW7xSfoVdZeHmvOBn3 bx2NDNHNxLHmsLbXnvNPXU1jUKaXiWLOkfJWsdZdaO+/0Z3b4TfEjl+4HuxbJY22pLeedvmFHLosPzDrvFOCx9LQ+oTSPL zrnnXQ1bJ13SmWx5twij1MFBgBCokkq6EtcoumW8md+YvQqo+f k8Sm8Qf8x7sN/EeIx+4sxFb3seaeyPL7M3h5Tf1FlzzuZNLUONelCuW3nnVqsr6 5o8G8kfz1XeyeP3iRfXdlMowd4XOVMo4fz1ZVNHj2cr65u8ujh fHV1k0cP8LjS2ZQKlc4Yvd7oAR5XOpvyuNLZlMeVTj+PW6qvjj yOPI48jjx+IJi0kqNHHi8LHrehvjryOPI48jjy+P5n0kqOHnm8 THjcen115HHkceRx5PF9z6SVHD3yeFnwuGl9dRxxxBFHHHHE0f ZRuL46jjjiiCOOOOJo+4j11UXy1S8erWWm0Vdwvvo/2Xwtk0evN199gV2sZfLoF9mNWiaPfondqmXG6HVny9+vZfLoV9 h/q2X6eWy0dypw/jjyOPI48jjyOPL4wYgeebwMeMyT1Sc+SRmcHniK9VyRx5HHkce RxysoeuTxsuCxUVAd66sjjyOPI48jj1de9MjjZcBjUV8teMxPI xfgsdGnKc/tmG2/L1P1lgAA50pq675Mw5LdCDnMY7JJfUIyfoS9eJSiLv1Lv/OmPalxfINtKcpj88JL0cQJwGmELJfac1/mN7Jlk2omIS3ufdSepXz3ZWbx8rfiCrqd+Flp/A/27C0EgHZ+y06Vds7D4zviA7Puy7SmdX3mHXV/nr+lBF8MIPM83dsAGCQXLrCLc1j11gOABp6zndncHgSA9s6xCx fYxfNkSESfKsfjC/TJPoAh8hr/cipR0aXxIrshr+rkow8v6kbdsxCPL9IDfQBD5CfKwi7vRQDowE n2E8OT7BTf6UluMf+oP8lm0kqOnolMq5GU/EC3lYUZ613d0uy2zkxkXqKH+wCGyC/4l9PqP6JFy3PaiJ76X2JvjCEAdPgU+0UJHl+mz/UBDJNfByxqid0eQwDouXn26yvsv2n3ZV4upI+948Qn9+5BMx6n cOU8phipDhOye0QzS8s8NsGc9jnmU3VXFP0kwm2dcvH4zFO410 Tp0S0IuvDRI2x8A/AHuSQt4xuA0/roFsQfpKU4j+mhbgDz/mpfWyfVasLsJ2G8XojHokWEbCxhdpjoxp8rJHuW3FYTRXj8H2Q jAJwkp77FPQA9t2gK1G9xD4CN2ELOeXgsL6NWjSUoGlYdJuyWx mk3J3m1tdOFoiiPOYxB8FjOOdwH0LeHXrD8U2CjvXPsggQ5p7L 1CXl4zGEMAqgX2OJeBJDMBPgtmli8doE+2ccfyHZuKcpjDiQwi XISrwWwmSTRxck0RH6SokvwKagRV3L0EIxB3p4tbtKWvSuUp9N Uymx9Ee5mEYIxCL5eIo/yZwvSirsOpNMLt0vxmKMXNPq6Fn3O436AlMeXyRhA/xjlD35/aHN9NcUIJQkCq3VToLtiu/otutPbr8nkMRr/OG28mCWL8/F4T2JylKIugA3kjMZaP4+78NEjyrl0vvq1bWh9f6L6SYwljizW xHE/ET5pa2Tr9VL5atk5kUyD3kJR78DoLql+i63lq7/FPQAbf8tO/Seb/w+6cyfaeDJb8hZyDvBYTtlmMdBvUcIYHPRmNUsO81jC2KIpt3v EMd3bQEODQh/P4T6AoYPMg+E8PJYw1ng8M5QtduUrmjjePsVesxR2Th5LIOlMu kgP9KGdQ45GPInXAuyc0inFTg5lSMM8RFwx0UMwBkfgnsTrAB6 ZYjqP7ZaOUwlwn0BryACPJYzBRK9c6sNvaDxeHPK6oUeHSulji V5JU9di+6OxYeTlcf8Ybcbje/fu3hxJt4q1I8gjN+8W6O+UEF/fRWHLY2kXj60WTyaSQepmjm3xiw0vOf7NeXx0i8qP926hZ46QT aDzGKGnDP80O53qZoq6oLcr/YQS+eqfTeD1kJzVEs6vbVN/HhOxnlaM7usleHznIYlVJYI/H0Emj90leqkbhrvTP22pfLUQvoKv7NlbCE6SzBR0Iec8PP6GbO IMFvlnxWMdsd9QNJyMW/2PNZzbYjoXj5MpV90eTMAFLc9UDxKVr57DfYD6UqIXz1dfoE/2JTMXyHaQPNYIDejJOWYjdioBzmD9WYd0MR4nJ6XmuySytUPEk 7M9idcCWpv+2ZKTFtLcBG8uIq6I6Bk8Tl50uy9fJI9YMLbgDej gSebp/1iYx8mi1MSO6t0wRn/hhTenL1fMQ6Rkvvoyfa4vuayrW9diZaqHiZGv5p5ZMHZ5LO/ITDeNv/vuu3ufnMhZXy0Sz8uCx1z1us2MlSwWHRgtS5P+x14eS8kr6Bvi semcjHN4G68X4jE91A3rt1F9A1jmoiV0PfvH3Wg9oEMTntfL1X NpDYzFJnE3GjZ47C6RaciCdyF9/B90506Zi0Y7vw1uCRdy5tHD+liq4QCPrRS3ZfGK41z7xyaPz7O pQZ84ni4c58gAACAASURBVMN9gPbOafvHBxPgOe0sPZ1r/1jnscg8exHL1bM0tsjjlEwak07itYAOnPTtoU4lALB2L/0JR1EfvnyR7LQshYi4YqJn7x87PHY3lYWbTV+xf7yuDxXmcQpa h8fcootjYdwwRn8hpfMpvAHQ4VMt7h879PXyeB73A3puXts/Vvo4e7/Zz2N+zIm3dcpdX62aH4v/JcG/62C+WtVwDeKlL9X2cJZodoEd3kgO8djZSA7kqxWqz+xJABB6Sj mf2ZOAXyJn8lhvdcyHztTsjWSer57/fvD1Qjx2stPc4t0SlksqX/31vgT8EjkXj9mTJwF23N5/y/4h9EnkIs58pQmP2fg0wDA+EshXe3mcJrEzirnK8Ni3GZyWcRnf 6d5p3OAymiPcK5G5b04ea+j1bCRbni3mqy0mpXuixjeosCRztj xVq2+dBjZTY/TCPM5OQbsbyW4quzSPUx3s7BPbG8nzs2P2X5QHyXylRR6nZVxG rOeeTABg7BD79WV2eRigD9/Ok6/mAlnTx4XPO2k6VyLWqN5qZmmHPl5aQHqyWqphWeElga0sZfUxR V22wDVKtAw1rJyNei7Dp8X6ak9S+rVtiO8on+0H9aDquUrXV5s lWmZlVqBoy1gyfYrwWFZmyVott2TaUMPNnAvpY1XG5VRmyXouC 8w6jznFAaEvmCdTXY7H1q6wXn19wayvPk/3NjR9XKKey6KsWasFfXhRZ60EsL6XPETK13NZGtFgDDpwkv1El TLRA32aIhwiPzmJ17ZXoT6g0XPx2CzRgiHyrhTKbnZa+ZSt57J 4zDeJdbLKwi6Zwba2llutrw7y2NK+en31PO4vXM8ld43Vead7n 5y43847uZvHksc3nfNOqSzWLMXruZ4Sh1yUurXPO2msrfy8ky6 auTiWPNaW2nPe6espLOqUUnGsWVK+Sta6S62dd0pRCgDZR5gkj/M4F6uvZkcuiw/MOu8U4PEX6ofG+IRWeGxtHgd4fKEt5530fDWXxekHzlw0T0Ppm 8eaRAbIEMdt5LH0BBB7qLqmzKg0jtFz8jjVvgAgxLHksb7ExbF uKX/eSeNxWiwN8g/whuRxyt00ulLPdfH4SrnzTi3VV1c5+DeSv56rvZNHb5Kvrmym0 QM8rnKm0cP56somjx7OV1c3efRwvrq6yaMHeFzp5NEDPK50NmV SpTNGD/C40tmUx5XOpjyudEYeRx5HHkceRx4vTyJGHkceRx5HHkceRx5H Hq/06JHHkceRx5HHkceRx5HH9UePPF4ePBZVXSc+uZe2d9J5HEccc cQRRxxxtH14+y2O3Lwr7waxzzvVOlitM4444ogjjjiqGln9FjN 5XGu+umYe15yvfv14LTONHvPVNeWrf8IWa5k8+gV2rZbJo19k5 2uZMfoFdqWWyaNfYriWyaNfZj+rZXp4/F3ab1Hw+JMTcOKTZbN/zABq2TyOPI48jjyOPF5B0SOPlwuPtWYSoF9eHXkceRx5HHkceb wSokceLxceL+P66sjjyOPI48jjFUHEyOPI4+++4z2djFH2/mqfpbX7MnPxWPWWAADnSmrrvkzDktEIuSmP1RWY4lJM+75Mr3P R+zID1LxxAK8GWL2V3jjGXj9OtosQ2/dannS/+IPNHOMW5awZ8/NYtGxSzSSkxb2P2rPUwn2Z/8nmfyuuoMtzBWYh5zw8viM+MOu+TGta12feUffn+VtK8MUsXs6 p1ye45TJOOyjuIAtZznLJfb0oj8/TfQ2AQXI1/ZJsER94xOPMXtyDANC+OXbV+3pRHl+ge/oAhsjSRXZ+Dstm0AAAffgF3XNKfaeT3tdLEPGBjx5A5nk61gAY JJcvsCtzuE+P3sDzAecsSyEeX6QTfQBD5LaysFf2IgA0cZLd1j 3l996HX+GWk3gtt+ivF+LxJTrdBzBE7vAvp1WIH1me0+pv/qx6nf1oDAGg6VPsTi4e3xMdFsvp4xSuGo8Ni2jKaPaTMC0t89g Ec9rnmE/VXVH0kwi3dcrFY9HWSVlkiwjZT0IuSYvRT0I2nwj2k8jmcUpZz uOZDQBdeJE/mIhd3IrUUhdePJaC3MF2Xh6LFhGysYTZYaIbf66Q7FlyW00U4b HsDCF7RXD7t7gHwEZsIec8PJaXUavGEhQNqw4TdkvjtJuTvNra 6UJRiMdvkgEA2EEW3qSja9RD42m68CYZAGg8TRWSL+MGmEvmg4 ffTXnMaQoCqBKunMouZefwKgDFY+v1ojzmRAEHKnO4AdDYS5Xx AhnklgtkUPpnvZ6TiCshehjG4AB1DvcB9O2hl8POWa/n5DGHMZhATSlr8vgi2cXdRAuN2xfpRB9/ILu4pSiPOYxB8PgS2c2fT+H1AOvHqEKsXLL4fQqvByjMYyWIi/GYYoSSRNfHpqXlfosFeOzt12TyGI1/nDZe9Mri3Dzek5gcDfRbNHnchY8eUc6l89WLW9HqDclqL4+78O IxE9sbyI1jbHEr4qi+sTfJkMWF8tWycyKZBr2Fot6B0V1S/RZby1d/i3sANv6WnfpP3t4YbTyZLXkLOQd4LKdssxjotyhhDA56s5ol58 xXcx6vwbOXcQNgYI4pQpvieGCOLbzJJnYArMGzLpgL8VjSVAJ1 Dq8C2HKQ+eF6nu5roC2DQh+7rxfisSSKBRVutwSiyaTGXrqU9X pOIq6Q6GEYg0/yWuLYdc56PSePJYxB4/FFOtGHdg359LFG611T7LZ8cBV2Hh5LGIPGV42yu6d9iOVvcfV8 iU73od1DhfTxd999d/fmiOzvVITHFCNIiJ6dti0kAZ2+CFPX0i4eWy2eTCSD1M0c2+Jn BC85/s15fHSLyo/3bqFnjqgmx7IDo+6fZqdT3UxRF/R2pZ9QIl994wBeDcmMka/mytiCsUhNKx6j/Qf4Qzrk60V5fOchiVUlgj8fQSaP3SV6qRuGu9M/QKl8tRC+gq/s2VsITpLMFHQh5zw8/oZs4gwW+WfFYx2x31A0nIxb/Y81nNtiOj+PpfZV0BWE9uhjbYkr4ywYN+dxckSXwnN4FaBV6W9 bM1/NM9WDROWr3dcL8ziZ1DXfRZWbHZxiNma4p9SOWa8XIOIKiJ7J4 +TQeTIMJlAPJgAwfJA54th0znq9AI+TeSl8ZaZ6iPjz1UIl75p it0X6WvFYJrEL8Dg5K4WvKYX9MBaoXj9G7/BM9RApk6+2Rq79Y5F4Vlx1LR3jMVe9bjNjJYtFB0bL4u1/3ITHZpNjhJ4K8djpiEw2gd0+uQiP6f4uWL2V6vvHUhZLERzgse mM9h8oWc+lNTAWm8TdaNjgsbtEpiEL3oX0sdHkGO38NrglXMi5 KY/1XeEAj60Ut2XxiuM8POZM5XwN8FjbLW6sQaY+dsR0gf1jDagHE wBYtYem2reBXzQy1WjfnLt/XJbHOmkkVC6wySFHIBoa0dw0LU3EFRI9tH9sAvU8OzTo2zn2On stxfaPNR6fxGsBTZzM2D+29ptb5LGViA5sKlvOXByfwusBTZ8q un8cHtk8llVZYux65VXLgvDvKstXqxquQbz0pdoezhLNLrADG8 lNeOxsJAfy1QrVZ/YkAAg9pZzP7EnAL5EzecwxrI/VW9+X0L2xNzER68lXWx/l20hOo4d57GSnucW7JSyXVL76630J+CVyLh6zJ08C7Li9/5b9I+eTyEWc+UoTHrPxaYBhfCSQr/byOE1iZxRzNeUxR6lZzOXPV6tX2MQOgB1kwc1gt8hjma8+z44M gpLIaRmX8fcstpDby+MMxkjhaEGrzUR84KIX4HGQr9XxOC3jMn 60fBKZzQ8B9OFXWsxXh3jMzg45JV1pfjs5q8q4jD+qB8mg81i7 mcsa7auvltA16rlMSzv08dIC0pPVUg3LCi8JbGUpq48p6rIFrl GiZahh5WzUcxk+LdZX0/1ddj2XpK98ELJYOZfSx2aJllmZFSjaMpZMnyI8lpVZslbLLZk2 1HAz50L6WJVxOZVZsp7LArPOY05xQOgL5slUN6/nYhM7AACNXmYLOp53kAVX+6riL7FkVni1QR+fp/samj4eJFft6uuK9fEcbugJW6kIZZVTToaVI+KDFz0/j+dwn56stsqnK9XHbn21ZK0q45L8Fkul67ksHqtctFO9xQntQr dwfXVZfZyPxx057+RuHkse33TOO6WyWLMUr+d6ShxyUerWPu+k sbaG806aGrbPO+kKO6PKOo3ul8VTWNQppeJYs6R8lax1l1o775 SiFACyjzBJHudxLlZfzY5cFh+Ydd4pwOMv1A+N8Qk5eXzZPOXC Ba513knxmM0+Lf6o7TzvZALVOu/UYR5bG6h6htZ/5qetRHzwoufnsbV5vEx4rKvndp530nisq15VsaUqrtWQ0rnceS d3pCegoDmPqxoAkJ/H7Z1589WVTf5vEOJxlTONHs5XVzZ59HC+urrJo4fz1dVNHj1cz 1XdFL+XM3lc6WzKpEpnjB7gcaWzKY8rnU15XOn08pj3d0oT1Pd 4sXVquxd5HHkceRx5HHn8wEePPF4mPDbOH1vtniKPI48jjyOPI 48f+OiRx8uCx9999x2/oCvlcXpb1ycnlo0+rm9GHkceRx5HHq+I6JHHy4XHRn8n8+5MqH nUzOM44ogjjjjiqGgUrq+udUQexxFHHHHE8WCOtvd3eqDz1YvH apn8nyHmq+vKV//f7MVaJo/+l2yhlsmj/5At1TJ59B+wpVpmjP4yO1/L5NHr3iW5Wcv08LjF/k4d4HGd9VyRx5HHkceRxysgeuTx8uFx2f5OkceRx5HHkceRx/d/9MjjZcHj78r3d4o8jjyOPI48jjx+EKJHHi8LHpfu7ySGeV8mEd e1icswO3BfpuotAQDOldTWfZmGJaMRclMep53r+HcxcZQtHqOj XfqX9pzdivSlCXFf5sCekjwO35epTfu+TN05oxFyGj2Dl6Jlk2 omIS3ufdSepRbuy/xPNv9b8fOV5wrMQs55ePyuuoxw3LIcJGdc/7vs6HkEgNBnLF29S9FQhnNTHr+kXXiZZXGd1+GZps45eXydPro aYBtZ5F8eFx8oLXLKJb561rzsczV+vgSPr9FHVwFsJYv8y6Mih LTIeVS7MzLLUpSID3z0ADKv0D19AMNkiX95SPtAy/OQ9u/O/QPOOXls38Nq3tJqO7u3tJqvF+XxBTreBzBE3uBfTmnfoDRaS31 4qalzSB8HBjTjcQpXT/cISIhqwWj2kzAtLfPYBHPa55hP1V1R9JMItHXKy+OFp3HDROns VgRdePYom9gA/MGBMUgeSzZPbIAMfvN/wgCPU8pa/RZlPwnpubgVqaUuvHgs0NYpF49FiwjZWMLsMNGNP1dI9iy5rSa K8Fh2hpC9Irj9W9wDYCO2kHMeHt8lmwDgIDkjmfoZ7gXoPU/P3CWb+IP1ymf8zmrBY/4ilOLxT8kAADxCzv2Ujq7jD47Fdb6OGwCNKcqd5YPhnJPHHMYg 6HsWNwAa36OL18kgf1Ce7PnvIYBk0v0Q+VZRHnMggSDQS7gB0N hHF6+RQf6gPMkgd5MMcy1FibgSoodhDIKvV8ggQOMxunSFDIIG 6ZfZ+SvshceQwV3pYxE9P485TcHoYgKD5GrWXehzeBWA1lLMfL 0ojzmMJU0vsKW9CCA54fEkI9xtDq8BWLOXvhFw9vPYu3NsGZvw mGKEkkTvf2yKXre7Yrv6LbrT26/J5DEa/zhtvOiVxbl5vCcxOUpHuwA2kIWjtg7WYCzRq5xL56sXt6LVGxK 3/7F8MLBt9lu8sTfJkMWF8tWycyKZBr2Fot6B0V1S/RZby1d/i3sANv6WnfpP3t4YbTyZLXkLOQd4rMBM0RDAED76bgIAm95lZ+ 6y8YMAQ/io7YY2HRT6WMK4HI8Va+noOk31ei1yXscNgIGXmMXjxhQtxmMJ Y8nj4wkADB5ni9fZ5DZT8nKLK5r5h3jFcZjHEkiSSUcTABg8yh avscmtAKvw81lv6UuuJQ8RV0j0MIwzeNx4jOo8nhzOgC7/nD78QiEeS5pKoMoun5n+aMug0Mfu64V4LGGs8fjEUIbSlXMOrw EYmWJv5HH281hncBEeU4wgISpfTTEChPRktNTJMqvtWtrFY6vF k4lkkLqZY1v8K+Elx785jzXEQmMrXThKBkDnMRp92nAe2KNLYT raBY2u9BNK5KtvHMCrIZkx8tVcGVswFqlpxWO0/wB/SId8vSiP7zwksapE8OcjyOSxu0QvdcNwd/oHKJWvFsJX8JU9ewvBSZKZgi7knJPHUhYrfSwIbWWqDxKVr75L 0VAyLkV2aR5LyRuwaCp54CV2ThfNWTBuzuNk8joZBFcfO5TV4Q 3o0bNMz28PHmcecdycx8mklHqGRszGjPQJWPIScQVEz+RxMmlJ Yf6lBWML3oD2JEytJrjh+uficXLE7rqNVqWUNfPVPFM9SFS+2n 29MI+TE1L4WoQGND7HbNZeICMcxnmc28xjkXhWXCUJ6ErZS9+K eMxVr9vMWMli0YHRsjTpf+zlsUxKC/qGeKxtGHMekwGwXi/EY7q/C1Zvpfr+sZTFWpvFTB6bzkX7H6upNTAWm8TdaNjgsbtEpiEL3o X0sdHkGO38NrglXMi5KY85UCV6xf5x7xAyePwZ7gWEPnP3j1vj MWeqIY4diyumRXK7MUU9ye0C+8caj7VN4sZqZPJYZLB1VLsyuv D+scakH6ht0cYq5GESdzYEomPJScQVEj20f6zxWOljJwVtLUk1 zF/3iuNc+8caUA8mAFrX7QZ+0chUo31zJbt8Zu8f6zwmI2kumo73a fvE3v3mPM5t5LGsypL/C4B/pzLQKXary1erGq5BvPSl2h7OEs0usAMbyXnrq8VGcihf7fBYOS/sScAvkTN5rHcv5mP11vcldG/sTUzEevLV1kf5NpLT6GEeO9lpbvFuCcslla/+el8CfonMozfhMXvyJMCO2/tv2T+EPolcxJmvhDPVsphLU8PjBzXKpmVcRiyxhdwCjzlK9Wos 12K/wiYeAViHZ15KIE1cC0vrPA5np62NZO+7rfA4NbLJra6R53i18i XX0iIRH7zoOXl8KAGAwUNsiWenvZTVN5JT0ZxRzFWUxzJffZ4d GQQlkdMyLuO/OLGF3D4eK2NgI5mdGDLpG3AGh8feUba+WtZqSdYaFV7mUlvruZ YWkJ6slmpYVnhJYCtLWX1MR7tsgWuUaKklq6Baq+fy+ZStr6b7 u+x6Lklf+SBksXIupY/NEi2zMitQtGUsmT5FeCwrs2StllsybajhZs7F6rnY+EHwi11Zz 2WVT3vqq8vymHMU0Oh1mX92LUL7mmVcfkuLPJbPlhoW1dS2Pj6 LG4FkdVEeqzIlUdOkKpjY5FYAQI++xBZ1bumWFon4QEbPyWOZe XZrtdSS0Mec2VbuuhUen6f7Gpo+HiRX7errKvWxqtUSkleqYbX kFnbl1Mdtqa9eDued3M1jyeObznmnVBZrluL1XE+r4xtC3drnn QI8Xqz+vJOmhu3zTrrCzqiyTqP7ZfEUHk7fTsWxZkn5KlnrLrV 23ilFKQBkH2GSPM7jXIjHabG0GEP4qK6DOWKr4/F188jQOjzjWlR2ms1MIWX/y3add9J5zLUvgLIIHutLsso6vHlcmMfs+X0iRGoRTHrJ/GtZhZ93La0S8UGMnpPHLztHmCSPU1msLSVm9KL1XF6gWuedOsn jVOmm0U8Y2WltiaPXde4Mj6saABDvA6llptHD+erKJo8ezldXN 3n0cD1XdZNHD9dzVTd59ACPK51NmVTpjNEDPK50NuVxpbMpjyu dkceRx5HHkceRx8uRiJHHkceRx5HHkceRx5HHKz165HHkcS4e1 zcjjyOPI48jj1dE9Mjj+4PHtY6aeRxHHHHEEUccFY3I48jjOOK II4446h8xX33/5KtfPV7LTKPXmq/+E0tqmTx6vfnqn7OFWiaP/jZbrGXG6PVGf4st1jJ59Hpz9ZfZ+VrmfcnjlVvPFXkceRx5HKN 3JHrkceRx5HHkceRx5PFyYdJKjh55HHkceRx5HHkcebxcmLSSo 0cePxg8Nu7LJOoqNaIt64b235epeksAgHMltXVfpmHJaITclMd p5zr+XaguEepLe/quzwRodl9mgJqvHMCrAFZtpa8cY68eV1fIHT7mcT69FWlL9PGu kHMzHouWTaqZhLS491F7lvLdl5nFy4/FD9gIPmxZIHkyy3mWzGe9XojH76pY45bFewWm575M80LNQjw+p 114aVnW4xnL+Ya4qnCUnLOcpaUQjxMtujRiOroWYBdZsJyx/C9EOHtfz8+kGL3q6Fm8PKm9Lo236OhagJ1kIct5LZ7NshTlsbw NlH8pelvZjTT0Jdk8w7UU5fEluqcPYIgs8S+ntQ9s6nyJDAacK +FxClfOY9kiQnZVlB0mjH4SpqVlHptgTvsc86m6K4p+EoG2Tnl 5LNo6mbjtwrNaPwkHxuBebW1dal2ExylTV22lrxyjj3***OHTx 9jhDemDA2OQ9D29FQWcm/JYtIiQjSXMDhPd+HOFZM+S22qiCI//SDYCwCyZ/wr3APS8Tuel5Y9014jG3T+xxPQxnOVSIR6r7hGCqar/segnYb2SXnktmzvx9lClePweGQCAUXLuPTq6nj8Iyw3cAGgcoo qy79HR9dA4RLlP4xBVPtJSiMf8t/wusqBjgD+DQwXpo94iAwCNZ6iyFGJSjN6B6F5Y3iIDALCTLOgA viWiWzyWzldwA6BxgC64lqI8TptTub2fRS8N5SnbbMjuGo6lKI 8viY7OHLGXyCBAY4wucdBK7vqdBZu9ztXwmGKEkgR5eSx7I1fS b9Gd3n5NJo/R+Mdp40WvLM7N4z2JydFQv0UBY4le5Vw6X316K1q1IRH6mGwBg A3klWPslb0JAHr8gAtjyWP6eFfqbIrmovlq2TmRTIPeQlHvwOg uqX6LreWrv8I9ABs/ZgqonMe66v04Ae7zR/bkrLnkvl4oX82xOoSPvpsAwKZ32Rne+knvf5y6oU0HhT6WMC7H Y5O1hiC+gRsAA+fYOdci4X0ugdTCJkZ9ejpnvpr/xl+LZyUS3N/yV3EDYCBhCyZUJBUaz9BiTIrROxA9nFW+JaLf0qK7+pjPK7gBM HCSLQQseXgsYSx5fDQBgMGjLO1k5W2Pwd8y2j87ljw8lnwFP48 bY3Qp4HwKNwAGp5kHwxXxmGIkehzb/Z3Sr6VOlllt19IuHlstnkwkg9TNHNvpGMRLjn9zHmuIhcZWunC UDIDOYzT6tOE8sMfuf9zoSj+hRL76lQN4FSSHVb5a6ePTW5HL4 y172eENINCr4O065+fxnYckVpUI/nwEmTx2l+ilbhjuTr/3UvlqoZJtmrqSV+ljE9Xe1wvxWMpipY8Foa1M9UGi8tV3KRpKx vP0dwrz2FLD75EBC8YiNa14vB7PKH3s4LwQj6/iRvr7nY6uTSa8qusqbgBqpL+1RY5U5FH9SMjJpBi9uuhhHivJS 0fXJhNS+GZIagO9rqUAj5NJvbeV0sfZiJU+AUteHieTlroVKWg Dxl7nU7gBqJFCugP5apF41rjqNDnuGI+56nWbGStZLDowWpYS/Y+tJsdo9OkQj7UNY85jMgB2++QiPKaPd8GqrdS/f9yFVvkQ23Yef/OC3sBYbBJ3o2GDx+4SmYYseBfSx1Z2miei3S1hsVvcM4KMVTe5 nZ/HHKgSvWL/uHcIGTz+DPcCQp+V6rcYEsdkAByaShEc4LG2f9xYj0rymP9mX4 tnLYtFhSQBRQ4u6aRKy9j1zMOkGL3S6CFxLKK7qemAmNZXs/abc+0fazzWtoQbq5CHx9zZEMeOpdj+sYZYpY/NfWKv83QCunMffqFSHsuqLDEQfl+yVpC5uny1quEaxEtfqu3hL NHsAjuwkZy3vlpsJIfy1Q6PlfPCngT8EjklYlYZlz4Ektmrx3m +2pOC1njcrny1m53mFu+WsFxS+eqv9yXgl8g8ehMeayloDle3m Mty1unrZrBz8jjNOYtiLk0Njx902x4b/3WILeQWeMzhKou5lN1JQbv5asvZW9IVpkKaJjVrgjJVGgwkbAG ziV0AkEwkCegWnSs5mRSjVx09nKnWi7ma85hN7LT47VhK8zg1s smtrpHnt7XSLdfSCo+nE+Ap6EtscsiHWFsfa85eiQyV1lerJ6O eCxLikc7tredaWkB6slqqYVnhJYGtLGX1MR3tsgWuUaKllqyCa q2ey+dTur5a4laWaFms1XislkrVc5klWmZlVqBoy1gyfYrw2FP GxZ6cBQC06yuRf5baV/mIei739WL1XGz8IPjFrqznssqnPfXVZXnMOQpo9IZITZslWmap l1HzZfqUq+fiv9/R6FW2kEUFVUxER9eamkzlWsvVNMXo1UcPkBXQ6BXmL93StW+gj CvA70I8ViVaop5LVW+xya0AgB59iS3qzNYtLfL4FG5Y9Vzegmq tniskpivnMavpvJO7eSx5fNM575TKYs1SvJ7raXGWRKlb+7xTg MdtP++kiWYbui6PWzzv9PUUHk5jpeJYs6R8lax1l1o77/RHdvh1oTu5uv0K94A2RvBhxWPNmaPXfb0Qj9NiaTGG8FFdB3PE VsfjG+pnDgBgPZ55j80cQupLK3FtnXfSnUucd7pqRpcyy0uFt9 WeZXvO/MToHYievW1sRA/w+BabPYAMT9fSKo/Z8/vEB6YWweOXzD/qKvy8a2mRx5ed804BHl+u5bxTdQMA4n0gtcw0ejhfXdnk0cP56 uomjx6u56pu8uiB/eNKZ4AKHZgxer3Rw/Vc1c2mPK50NuVxpTPyOPI48jjyOPI4RrejRx5HHkceRx5HHkce LxcmreTokceRx7l4XN+MPI48jjxeQUxaydEjj+8PHtc6auZxHH HEEUcccVQ0Io8jj+OII4444qh/xHx1kXz1j47XMvk/Vc3RV3C++n+zM7VMHv2/sIVa5nKI/gE7V8uM0VfyLsmPoXfAXAAAIABJREFU2WIt877kcZ31XJHHkce Rx5HHKyB65HHkceRx5HHkceRx5HH90SOPI48jjyOPI48jjyOP6 48eeXzf81jdjqn3kdC/7sh9maq3BAA4V1Jb92UaloxGyLl4/MMDeDXA6q30h8fYj46TbeITt+1t6ky/J26sPH6sJI87ED2Dl6Jlk2omIS3ufdSepRbuy/yTatmkLrz8WP3I2S0l5JK8qtp9vRCP74jXh/ERbvlCXKI5TU67/t9QNKwt3VF/1PESPD6jXXyYZZHzmrgsEJFzlvM6PFOCx52JnsWMJRXrgGXZgG d0zx+b15ryVem8h5wtQcSVED2Ll+e0f2XL4nYJs25p1Z1Hi9/S+nbGZZ9ZvapK3xWaxcsT2uvccl58gyNkwXK+qUXPer1SHjsdm tw2EqIpo9lPwrS0Tx/LXhHSororin4SgbZOhXicUo1D7vgGgC58jj94OGc4n9uKlHMXP ueBIv9HrDm6l8eiRYRsLGF2mOjGnyske5bcVhNFeCz7QHgaSzg tFE0fw9ltlpyHx9+QTQAwTU5/gXsBei/T099QNMwfyCZucWEMgsfydQvSOXn8DhkAAETOvUNH1/EHx6Kc6eg6aExS7iMfAJFz13CDWwrxuGPRvcD4JdkMAHvI2V/S3Rv4g7D8GPcC9B6hHtLIJfnwS7I5yzlG98LS06pEWKw+3D9Pr 0+XzUsah+g5s+VJ8S4m4o5u44Ju3m/K4bFqqiHfkr0mm/XS8MKS83WELNyko2vUQ2OcLtwkAwCNcaqQrHzkW87rVfOYJFka V/SYqK7foju9/ZpMHqPxj9PGi15ZXIDH57ai1RuS1V4iOpAznen3ugA2kBSNfpH ahMediR7MKsvOiWQa9BaKegdGd0n1W2wtX/0V7gHY+DHTWijSXSOm6v04Ae7jdld0Xy+Ur/4C9wJsusNOywcXsRLG4KCXL0mFXTRfzfmnq0zXcg03AAbOMA8s 5VJRfdyZ6FkaMYUT3b3BFIU/xr0Am5eYjRndcykB7vNLdmCPoynzKNSVED2cVdYbaWtSeOAcO+ daJLxVH26nJWihfLVq5yxg7PJV9po0cS553HiGFuOxxdo1ePY8 bgAMnGAexMqlwOsV81jvgGwKXdnySQpmaXIt7eKx1eLJRDJI3c yxnY5BvOT4N+fxDw/g1ZAcN5LAXJt6cOg4k22gExF970AxHncseoDHdx6SWFUi+PMRZ PLYXaKXumG4O/2xKZWvFirZpqkreZU+NlHtfT0/j78hmziDRf5Z8VhH7DcUDSfjUhM7OLfFdH4euxLTtZxJQCeihO U7ZCALhzl5XHX0MJMsRfhLstkLJJ1D+lsu0goR8cGOHuaxpYbf IwMWjEVqWvF4PZ5R+tjBeSEeq66RdHRtMpHZ+xk1UlqL7LTIYP thnJPH53GDq+ETCeg81hF7HjcANdaI6N7XK+ax2dJYkZUkEtAd 4zFXvW4zYyWLRQdGy9Kk/3FWrnj1Vqpvykph6ohO17lFHncuerjwSmtgLDaJu9GwwWN3iUx DFrwL6WMrO80T0e6WsNgt7hlBxqqb3C6kj6UaDvDYSnFbFq84z sNjnvg15KljCRBRyllds+bncQeihwQi2QwOUWQW1zA6WlDsofZ uQCWJ+MBHD4ljMgAOTfXmnlk81vaPG+tRSR5zpspGk2+bvSbNn WbV+3ktnlX6OGO/OQ+PedqZozfA4xMJcOhaS/rrlddzGXqYp565aDaKuSrJV6sarkG89KXaHs4SzS6wAxvJIR5z tulj9db3JeR+uDfRIedz/l0r+epORg/z2MlOc4t3S1guqXz11/sS8EtkHr0Jj7UUNIerW8xlOev0dTPYxXjMxqcBhvGRQL7ay+M0 iZ1RzNWUxxxmevGUa2maMX6HTaCMoqrlED0TSHT3BlAFTQH8fK DtuXqdvWVNMXo4Uy2LuZTdSUG7+WrLedRX0sWjhzPVVjVWpj6G gYQtYDaxCwCSiSQB3aITPSePOVzNYq4m+eqbbGJEvGK9Xi2Plb 5VT5o0toBsimnD0g59vLSA9GS1VMOywksCW1nK6mODdmpT1qyo sminy1m51EI9VyeiZ24byxItszIrULRlLJk+RXjsKeNiT84CAN r1lcg/S+2rfEQ9l/t6IR6rMi6nMkvWc1lg1nnMKQ4IfcE8merm9VxsAgEAGr0m8r0e iyy2MqquGpNUFVLJ0qpCPO5YdD+Q2IE9AIB2/1ikZ80yJaPc6QNnY1X5lKuoWhnR/TBmE6MAgEZviNS0WaJllnoZNV+mT7l6Lk5WNHqVLWTxWJVx0dG 1phpWWe5y9VycrGj0vNgVNou2lBo2Sr2kxXm9I/XVfCjFqwaHbQfOO7mbx5LHN53zTqks1iyt85i5J44CROzAeae2 RPfL4iks6pRScaxZUr5K1rpLrZ13+iM7/Lr4EePq9ivco//IjeDDiseaM0ev+3ohHn/DjlwWr2eddwrw+AvzLErRei55goiPdXjGteh61Dpx9A6bmUTK0 xtiOUT3Msk9xvNLNnMEqS8/MJO3+gbqB+yc7lzixNEKiZ69bazGejzzHps5hNSXVuLaOu+kO3 vFcZjHV83oUuB6efx2u887nTej85yzdd5JF8rWeSfv653JV1cy ACDeB1Jn9HC+urLJo4fz1dVNHj2cr65u8uhZGeOq53KI7gVGB2 aMHq7nqm4GeNyBGeBxB2bkceRx5HHkceTxciRi5HHkceRx5HHk ceRx5PFKjx55HHmci8f1zbqJGHkceRx5vGKIGHkcedycx7WOmn kcRxxxxBFHHBWNyOPI4zjiiCOOOOofMV9dJF/9+vFaJv+nqjl6rfnq71hSy+TR/x92ppbJo/+anatl8ugrOWf7ITtXy1wO33u9+eq/ZAu1TB79LbZYy7wveVxnPVfkceRx5HHkceRx5HHkceRx5HHkce Rx5HHkceRx5HHdRIw8jjyOPI48jjyOPM7DYyJvI5OXX0qT0VJC N7T/vkzVWwIAnCuprfsyDUtGI+RcPL4hLqG8cYy9fpxsF5+4fa/lSfeL+ylnjnGLctaMxXjcgegZvBQtm1QzCWlx76P2LOW7LzOLl 38tfr5G8OEsi+sMyZNZlkI8/q/i9S34CLf8nbjO8FlyOssZkvEsSyEeX1KvH5DGj9jMcQSAdr/Fzlr+1pJ8fYzYnnl4vKRFtyxWSwP3ikfducSdkR2LnsXLC1p0a fwVmzmGANDuN9lZy/9XdHc/wF5yNo9zUx535nvP4uU57cpJy+L2a7Luy9SdR4P3ZWbx8iUtep bFdV6HZ5o65+HxSe11abxFR9cC7CQLWc5r8WyWpVIeOx2ajF4R kBBukZ0mZD8J09Iyj00wp32O+VTdFUU/iUBbp0I8TjnHiTizAaALL/IHE3KLW5Fa6sKLx1KUOuAsxONORPfyWLSIkI0lzA4T3fhzhWTP kttqogiP75GNAHCCzN/FPQA9N+m8a3Gd79FdI/yBbLTeKsTjfyabAOBZcvrvcC9A7yv09D9TtIU/kE3cYjrLJXiWaA8UbfHxO8zjj8hmABgjZz+iu/s1pr7FfwX7eKwvvYV7AXqP07Mfkc38oRCP3dYF0mL15XXw0HuE njVbIBTvqdCp6F4Y/4psBoC95KxF2TfFX6+FWO4GJo+znJvyuGPfuxeWnqYRwmJ1RP5 5epG1bCPROETPmc0nQv0kvLD8KRkAgEfIuZ/S0XX8wbG4ztdxA6AxRbmzfDCc8/D4FhkAgJ1kQQcwfwaHx9L5Cm4ANA7QBddSNY9JkoFjj6Xd/Rbd6e3XZPIYjX+cNl70yuICPF7cilZvSFZ7idiFF4+Z4NxAbhx ji1sRh+WNvUmGMM3L485ED2aVZedEMg16C0W9A6O7pPottpavv ot7ADb+NZsPWBSY6a4RgBF82OSxAe9C+eq/w70Am/4rOy0fXMSaPDZRTdEWTWEXzVdzHvfjmfQZbR7z6WNr6VICAJsv sbMfsQNj4vUS+Wq3rb3VUMjrKZsceFsENuVxx6KHs8q/En/z6TPavNeRvBLGOo+znAvlq6v+3sNZZb2lsSaFB86xc65Fwlt1R HaaMxbKV/9UNNIOWOS8jhsAAy8xi8eNKVqMx5YgXotnJYxdHst5BTcABk6y hYClGh7r7ZyU9EV6MlrqZNmT0bW0i8dWiycTySB1M8d2Ogbxku PfnMc3DuDVkMwYGWOuTS0ciuSwIiLaf4A/pEO+np/HHYse4PGdhyRWlQj+fASZPHaX6KVuGO5O/wCl8tVC+BrodS0OvFP6cmWcBeM8PP5nsokzWOSfFY8txHJBbMF Y4Nw25uexUrps5jiCMeLJV7tL6i0N5yV4bGmyX5LNXiR8YDYaU irNgUohHlcdPczjN3EvQO8xepYnn/cSTwr6V3R3f3JASmqZqfY6F+Jx1d97mMeWGn6PDFgwFqlpxeP1 eEbpYwfnhXgsJW/AoqnkgZfYOV00Z8E4J4+V5KWja5MJKXwzJLWBXtdSGY/NlsaCta6lEzzmqtdtZqxksejAaFma9D/OyhWv3kr1HVwpTKUMDRDRdEb7DxTiceeihwuvtAbGYpO4Gw0bP HaXyDRkwbuQPpYp6IBFz1rzrWWljzOcc+pjqYYDPFb62JTOHNJ ecZyHxzxrzWn6Fu4FtPst3/6xd0nsH/f2o5I85plS63e63uxPGR01JnYxezegkjzuQPSQOBZ/8ymY0e43A/vHGo+bOufhcQe+95A4JgPg0FRvs5jFY23/uLEeleQxZ6ohjh2LK6ZFcrsxRT3J7fw85vTVN4ADPPbuLmftN7 e/nstQygnRMtApdqvLV6sarkG89KXaHs4SzS6wAxvJIR5zEOpj9d b3JfZu7E1MyHkyxtZH+bZyM3ncyehhHjvZaW7xbgnLJZWv/npfAn6JnIvH7MkTZgGXa5GQNou5Nv41m/c6F+AxG38WYAs+EshXK1QLZwnyrGKupjzm0pYXc6W1WvoQ3A0s/Zqd4/lqb0lXmAr8t78sKQoA4ANt19Pr7C0sWg7Rw5lqXsyVVmaZf732 FrLccs7h3JTHnfnew5lqWcyl7E4K2s1XW86jvpIuHj2cqdarsV yL/QqbeARgHZ55KYE0cS0sRXmcJqi1Yq7mPGYTOy1+O5ZKeKz0rXy StVqStUaFl7nU1nqupQWkJ6ulGpYVXhLYylJWHxs8W72V3jhG9 3fZFVWSf/JBCFPlXEofdy565raxLNEyK7MCRVvGkulThMeBMi5P9RZ78gQA oF13RR7bdS7EY1XG5VRmuWrY48zGnwUAhP6OeTLVzeu52IExsH WwVURtlXoZS7IcrFw9FzuwBwDQ7h+LBKlZKGQUHH3gbG0qn3L1 XJ2K7ocxO7DXC11N8lqlXro+brG+umPfux/GbGIUANDoDZGaNku0zFIvo+bL9ClXz8UmHgEANHpd5p9di9C+Z hmX31KsnotN7AQANHqF+Uu3dO0bKOMK8LudPDY2kKXOreO8k7t 5LHl80znvlMpizdI6j5l74kjTo/aJI13jZtQ588Wao/tl8RQeTt9OxbFmSfkqWesutXbe6R47fFP8yKUpaNcieHwX94A2 +Gor553+mR15RcTKOu+kC2XrdJP0tD4hJ4/fMl+XCee8PNZEc4nzTu5Bml+ymSNIffmBmT7VtzA/YOd05xLnnToWPXvb2Pib7ySPO/a9Z28bq7Eez7zHZg4h9aWVuLbOO+nOXnEc5vF1M/o6PONaVHaazUwhZf/Lls87XTFjSYHr5fEtNnsAGZ6upWP56koGAMT7QOqMHs5XVzZ59 HC+urrJo4fz1dVNHj1cz1Xd5NG9v7I7MJdD9HA9V3VzOXzv4Xq u6maAxx2YAR53YEYeRx5HHkceRx5HHkceRx5HHkceRx5HHkceR x5HHt+nPK5v1k3EyOPI48jjyOPI48hjyeNaR808jiOOOOKII46 KRuRx5HEcccQRRxz1j5ivLpKvxs/VMvk/FftotpaZRv9/52qZPPq/s6SWyaP/f+x0LZNH/+/sbC2TR683bxmj1xW93ozx22yxlsmj/4Qt1jLvSx7XWc8VeRx5HHm8Ypi0kqNHHkceRx5HHkceRx4vFya t5OiRx5HHkceRx5HHkcfLhUkrOXrk8f3P41K3Y7b9vkzVWwIAn CuprfsyDUtGI+RcPL49gdcCrN1Gbx9n+Dk2L9qe7hqzPMku8Zc 0fzzLUpjHHz6D+wH6t9MPZzItH82yj2bJXvGt7n0sy1KIx+RI+ ja6Om1Z4MgTWc7J+y8o+9/vQJYlN48/Ez9xO/HhLIvrPEfmLQskT5bg8V+J17fiI9L4L3TXVoCjJMlyBrGqLMn+ Ejy+ol5/Whp/w56bQQBoN2bfL+2ch8fntKsHLYvbt8e6N1F3Hg3emxij1xU9i5 fulZOBSyjlUtEbK7N4mWivSyOmo2sBdpEFyxmn3RWVs/f1/Dye017nlsvir3cHWchylkvu61Xy2OgMIbtHIEyt7hHNLO3Tx7J XhLSo7oqin0SgrVMhHtOJLgDB41e2IQ7X+X4wKUsnugC68Ct8q Qu/cty1lOAxPd4NYNDXtbCPZtnFfoBufGuGXewHgOTijMdSiMfvPw wAyfsv0KvdAN34719g7z+sPRiU9fgIGEMpHv+ZbASAOTL/De4B6HmTzrsW6Wz6uA8K0jl5/C9kIwAcJck/4B6Anh/QRMIYHB7/CzvyA2RwV76exe8wj39DNgPAY+T7v6G7HwJ4jKRAxfx+YxOxvy GbAXpn6PflWwHnPDz2NA8QFqsz7s/TC41lO4HGIXrObEIQ6isQo9cV3QtL2YnBbGJoWFxns5FDI09HB y8sOV93kQUdwPwZHB5LH/UWGQBoPEOVpRCP3yQDHK5v0tE16qHxNF14kwwANJ6mCsmXcQPM JfPBw+8289jtl5inu2K7+i2609uvyeQxGv84bbzolcUFePzKNr S2PxH6mE50AfST2x6ykl2QLt0eSwDQxIRrKczjW9tRf3+iq2HX 4uFxxkOpfDW92g3wMKEWjwV0lTh+mNAXGH0i4XpawLgcj03Wbv yMzQcsnyXALX9mT84B7MSHXTCXy1f/A+4B2PhXLJEw9vF4/9EM6PK3dIVdKF/NefwQfi59RpsfcySvyePeGfr9gHOhfLXbWF522XMtEiGqM67Tp C+nRozRq44ezipz+hpNiB2LnNdxI210aPC4MUWL8dhi7Vo8K2H s8vUqbgAMJGzBxLnkceMZWozHCsx0dA3AGjx7GTcABuaYIrQpj gfm2MKbbGIHwBo864K5eh4jpKeepU6WHRjzWNrFY6vFk4lkkLq ZYzsdg3jJ8W/O49sTeC0k8ypfTSe6YG1X+ldh5quVGn5lGwJAExOupRiPP3wG9 0NyUctOuxbd/yJPpGvodS1Fefz+wyloNdFswdjQx3+/A0keH3nCVdKFePxnstFCr2sx9DHdtVNks7kyzoJxHh7/C9nIYZySNdkvha8L3XSgXf/A1Kour0vwGOPelLXsuRkEjxF/CporYwXjoHN+Hlua7D0yYCHh576+9EqlOVApxKQYvbroYR5LyR uwaCp54CXZDzHNIfthnJPHV3EjJSsdXZtMePXuVdwA1EhpLbLT IoPth3FOHkvtq6ArCO3Rx9rSmyK6F8Zt5jFJwOp/XCOPuep1mxkrWSw6MFqWJv2PszLVa7dRbf+Y7IIAYsVucRdamy 65lvw8pse7oX871XaLXYtHH9/ajqx8tbSUq+eSe8BSFvt2hcX+cTfaqvabW+Txv7OEI1ZPOLsWb be4Zycy9bHPOb8+thLOfh6TjRy6lhrmzl5xnIfHnLJcHGPcC2g 39m0JK30sktsB5/w85plS63e623zepcLP1S5mYz0qyaQYvdLoIXFMBsASx47FFdMi ud2Yop7kdn4ec6auxbNuHtvZaRbM5mJa6uOM/eY8POZM5XwN8FjbLW6sQaY+dsR01fnqFLKdzFerGq5BvPSl2h7 OEs0usAMbySEecwzrY+2238l89e2xBDwlXQw/x5eMAi7X0pTHHLr62DDwqmXRkEz2AkA/+XCGffhYAoCOP+NaSvJYpKA9SekMZwXg1nksUtABi7U0R+bdDH ZJHrP9Rx3EelPT1kZyKpozirma8pjDlddnpZVZ+tAoeyUBgM1X 2Pd/w55+DKD/9kTAOSeP+a94WVKk7E4i1M2aWs7ewqIYvd7o4Uy1Xo3lWuxX2M QjAOvwzEsJpIlrYSnK4zRBbVZjZepjGEjYAmYTuwAgmUgS0C06 0XPymKPULOby56vVK2xiB8AOsuBmsDtQz6X0sajnkhVe5lLA0g 59vLSA9GS1VMOywksCW1nK6mNPffUr25Cmj5N5X4WXrN5yLW2v rxbalx7vtqq3XEshHpslWm5hFyTvv2BKZ1NDt8bjQBmXtEjtqy xCFrvOhXgs88wWgPUvpXRWzkIfc4pbuesC9Vzs6cd8HNVLpg01 7KvnKl1fzX+bAxq9IRKkZqGQWXBkVB6ZPuVqmmL06qMHyApo9L rMP7sWoX3NMi6/pVg9FycrGr3KFrJ4rMq46OhaUw2rLHe5ei42sQMA0OhltqDjeQ dZcLWvKv4SS2aFV/X6WApjgJrPO7mbx5LHN53zTqks1ixt4LF73knyWNPTqRR2LZXx uP3nneg0FvuimeedJI81Z4O+ZXn8Z3b4TaHz0v1g1yJ5rC215b xTqnQBwDrv5OOx7swF8T/gHtBG0XqutDRaDJ6yzuKxkMg8ehvOO8lTNHysxzPvsZlDSH35c zN9ap260Z1LnPmJ0TsQPXvbWI11eMa1qOw0m5lCyv6XLZ93umr GkgLXy+O3233e6bIZnQtc67yT4jGbfVp87zWdd6p4AEC8D6SWm UYP56srmzx6OF9d3eTRw/nq6iaPHq7nqm7y6N5f2R2YMXq90cP1XNXNAI87MAM87sCMPI48 jjyOPI48jtHt6JHHkceRx5HHkceRx8uFSSs5euRx5HEuHtc3I4 8jjyOPVxCTVnL0yOP7g8e1jpp5HEccccQRRxwVjfuLx3HEEUcc ccTxYI77K18N7G9ma5kxOrt3spbJo9ebr/5XdrqWyaP/mp2rZfLo/4Ut1DJ59HqzpvVG/xlbqGUuh3/3GjPGAPAGW6plRh7fV0SMPI48jjyOPI48jjyOPF7p0SOPI48jj yOPI48jjyOP648eeRx5HHkceRx5fN/w2LkvkzFmdW5q7b7MIJM+fQY/DPDwdvrpDPubWbIv/bOg55+xPOUS7HvMsrjOeYn4wEfP4CWZFa+/Mc3unaRv9IA2uNGYX+1AAMknc9broBnz81heeCm7QbgW17nofZ lZvPxQvL4NH5HGP9Bd2wCOkSTLGZL9WZZCPL6kXj8gjR+xmeMI AO1+i521/K0l+foYsT3z8PiMdvlflkXOa+JaQUTOWc7r8EwJHrvXLgYuYnx Ji9XUOQ+POxM9i5dntdezLHz+yLlcU3fmXxblcWf+3bN46V45a d1Y6XUudGMlZPN4Vr0+yS1LIvp2shh2XjL/LVbj5yvmsdEZwsEt57HsOWH0kzAtZXlMn+8GEEy61g8AybUZ+n w3QDf+6YzyvNafWoRPyDk3ER/86F4ef/IwACSfzNE3egB68FcKqK5Fwhgkev80jUcAZp8op48DbSSkRTqb Pu5DqJ+EF5Z/IBsB4BhJ/pfoFSFhDA6P/yD6Lcq3XEshHn9ENgPAGDn7Ed3drzH1LX6vtY/H+tJbuBeg9zg9+xHZzB8K8fgdMgAAiJx7h46u4w+ORTnT0XXQm KTcRz4AIueu4Qa3FOKx7EZgNvIzLK6z2cygkaerQb3RvbC8QwY AYDc5d4eOrucPjsV960e4AdCYpspZWgrxuGP/7l5YqiYN8ppoOrpGNWkw+gqb/Rvch8yODpDB49fJIABsJ4uv00dXq4fGfrr4OhkEaOyniwFnubS EG5ZzJTz290ukGKEkQWA1cyrbbzGbST/djh7uTzSNqIGqn3yaxSSDQB7nnERcCdGDWWX6Rg/Aw+RPczp3bXEsYKzx+IkkQxYXyld/g3t458SAxe2u6IK5XL76f+EegI0fskTCuBmP/Q/l8tWcx/14Jn1Gm8d8+thaupQAwOZL7OxH7MCYeL1Evpr/Fta1jmu5hhsAA2eY51e2XCqqj1PaiVgBi5zXcSNt9mcQsTFFi/G4Y9HDWeU7oqVxwBKw/wg3AAbOsmI87ti/ezirLPsNBzoeuv0NXTCXy1dzxK7Gzy/hBsDgLPNA13X2flkxjxEyU88UI9EHWWpgjb4IU9dShsefPoMfh uSakbMV+PEx5hpvvuRqRz+QmhBxhUQP8PiThw0Yp1low5LyePY JKaktQsPIDvqnwvlqoZIN9LoWQx/TXTtl9yeyEQCyYJyHx38gGzmMU3Gc7M/Su38QsSR6XUsJHiuly2aOIxgjnny1u6Te0nBegseu0HEtZxLQf y/LX9nvkIGsX8o5eSxFZ8Ci6dSBl2RPwLTzjx+HOXlcdfQwj12Bm yV5zyZgofcOGciCcU4eV/3vHuax1L4KuoLQHn2sLb0p/ua9MM7JYylwZxPQeeylrKWG5SuV85gkoKtghKlIRVfOY/p8Nzy8nX7qMIlrR56YdTWiu+RachBxpUQPF17pu8J/eiLx7hybKW7x3IO/mvPr6dz6WDZVDFi03eKencjUxz7n/PrY2jD28lipYeHsWkrwmGetOU3fwr2Adr/l2z/2Lon9495+VJLHPP1oiCTHEvi9LEWVrpzy8/inIlbA4spZkV5uTFFPejk/jzsQPSSOyQBY4tixpHY2sTtbNHuT28vh3z0kjskACL4GeKztFj fWIFMfO2I6P495IpqjtymPdec32NLrbHJ7tjiuLl9NEgCYfx8r 7QMAAAj/rop8NUeRPnQsffpYYlYqkX2QakFnyWNpSsSVEz3MY53BOnHDPF avZ24k8+hNeCxS0AGLtTRH5t0Mdkkes/3HtJIuL48/TCDNaQtn11IOM+q4AAAgAElEQVSUx1za8mKutFbL+M8t5W5g6d fsHM9Xe0u6uG84Y6mX8LiWpnnLd9gEyijt4dHDuWK9Hsq12K+w iUcA1uGZlxJIU8fCUpTHnYkezlTrpVuuxd1vzsnppjzuzL97OF NtFnP589XqFTaxA2AHWXAz2EV5zLlrFnNl5qstZ31TuRM8VpVZ Nlk15WvUfJnOLddz6TXGqjpJFi4J/ecueZyLKNSVEj1z27gHfzWnU9a7l6wAbHuW18eBMi5pkdpXWYQ sdp0L8ViWcVkA1r+U2td1zno9bz0XOzAGtg62iqitUi9jSZaDl avnYhMIANDoNZF19FhkyY9R+9OYpKqcRxb4FOIxJxmg0esyA+x ahPo0C6n8lkI87lh0P4zZxG4AQKM/Etlmj0XTvtY+sVvYVYjHHft398OYTewAADR6mS3oeN5BFlztq4 q/xJJZ4VW8notNbgcA9OiSyDarwi5Rz6UsjrPO747wWAhjgGVw3k kTjqnm0/Kx9pkf17k1Ij6Y0f2yeBqPiNcFTe3N42we669nVVnzxQxZfPhN ofzS/WDXInmsLbXlvNMf2JEfiA80zjv5ePyv7T7vlBZLiyETznl5rIn mEued5DkWPtbhGdeiqyLr3Ms7bGYSKU9vCL7qJeJ1J5ZrUflhN jOlxeKf0Mp5p45Fz942VmM9nnEtOo+tzeM7bGYaKc+i+8cd+3f P3jZWgwtc67yT4jGbfVrEast5J++BJeu8k+Sx1zm8eVwBj6sc/BsLManKGaM3yVdXNnn0cL66usmjh/PV1U0ePVzPVd0M/F7uwOTRs9K/Vc/lED1cz1XdXA7/7uF6rupmgMcdmJHH9xURI48jjyOPI48jjyOPI49XevTI48jjyO PI48jjyOPI4/qjRx5HHkceRx5HHi8rHscRRxxxxBFHHG0fkcdxxBFHHHHEUf+I +er7J2Mc89U15av/Dztdy+TR681Xv80Wa5k8er1Z03q/97fYYi2TR/8xW6xl8ug/ZEu1TB79Kjtfy4w8vq+IGHkceRx5HHkceRx5HHm80qNHHkceRx 5HHkceRx5HHtcfPfI48jjyOPI48vi+4bFzXyZR95Ollg7dl6ld DOleA2nfGRl0zkvEBz56Bi/JrHj9jWmWXkmthudKavP6TPk6ZLSg4EtZvJQXXspuEK7FdS56X 2YWL38jXt+Oj1gWSPZnOQPADEnCznl4fEm9fkAaP/L1d/IuydfD92VmMSPRrh6URkxH1wLsIguWM0773Cln7+v5eXxGez3L Iqd1a6PuHL61sd7vPYuXJ7XXpfEWHV0LsJMsZDmvxbNZlkI8Pq FF55bz4q93hCxYzje17z3r9aI8vk4fXQ2wjSzyL4+LD5QWOY9r/8VtI4tnnTssS/D4VbpnFcAWssS/PKy+nUnL01o6Y0ZfhV+omMdGZwizRYS0yJ4TRj8J01KWx/T5bgDBJLdfgvSUPQdlB4WAc24iPvjRvTwWl1GrzhBiybVIGIN1 f3XGzdVNeRxoIyEt0tn0cR9C/SS8sPw3shEAZkjyj7gHoOc1mkjLv9Fd2wV0U2d25DVkcPffyEb rrUI8Vg0hzEuq03utfTzWl1T/42b9JLzA4IzZRRZ0CPFncJgkfdRbZACg8QxVlkI8lt0IzI4Fhk U509F1qoeB0czAbdmbh8cd+969sLxFBgBgJ1nQAXxLRLd4LJ2v 4AZA4wBdcC2FeMz5OkIWbtLRNeqhMU4XbpIBgMY4VUhWPvIt5/WiPOYwBkHfs7gB0PgeXbxOBvmD8mTPfw8BJJPuh8i3ivKYwxgE j18lgwCNx+nSq2QQNEiHl87gBl+qlseefokGj2Un5Hb3W+Tzp9 vRw/2J0wOYPt+ddhj0M8kgkMc5JxFXQvRgVtnb08kWxwLGGo+fSAKd GXPnq7/BPbxzYsDidld0wVwuX/2PuAdg42+YRl+6a7smmv8PO/1vbP+MRWiDxz2v0WI8VmCmu/tFP4mP6O5+tHnMp4+tpUsJAGy+xM7yPlGB/sfhzCrnzVo8K4HkMuYqbgAMJGzBRJpkUuMZWozHJms9jXV1S6D rn1wql6+u+nsPZ5Vviei3tOiuPubzCm4ADJxkCwFLoXz1TdFv+ DxuAAycYB7EyqXA64V4LGEseXw8AYDB42zxOpvcZkpebnFF83X Rq7hovlrCOIPHBmKzlviHeMVxBTxGyE49pwnrVPhKnSx7PrmWM jz+9Bn8MCTXjJytwI+PMdf6AcCnHf1AakLEFRI9wONPHjZg7LZ 4kjyefcLo76QRGkZ20D8VzlcLlWyg17UY+pju2im7P5GNAJAF4 zw8/jey0YKxILSBWE7odKBd/8gSqbCzYJyTx0rpspnjCMaIJ1/tLqm3NJyX4PFV3EjpQkfXJhNezXcVNwA1UmaIDK3I4vqBlJPHr sB1LWcS0HksUf0OGciCcU4eV/29h3msJC8dXZtMSOGbIakN9LqWojw+jxtcDZ9IQOexjtjzuAGo sUZ8797XC/M4mbxOBsHVxw5ldXgDevQs0/Pbg8eZRxw353Eyaeld/qVX73qXDicAMHiYecRxm3lMEtBbGiNM3SbHFfGYPt8ND2+nnzp M+huj1aCtEd0l15KDiCslerjwSt8V/tMTSUYzYz3FLZ7L9z9WABZNFQMWbbe4Zycy9bHPOb8+trLTnLK 6ODbUsJDOlqVovlrPWnOavoV7Ae1+y7d/7F0S+8e9/agkjzlX1uJZN5eruyUJKG5xQSk14v/f3vm8xnFle/z8JUbQQ4yNFwFlIcOMiVrEFWgPz2APhkxHEIfEJFJrNLgSTCJL CyeM9fwyxAqe4VUcMsu3MgHLs0z9ASHgeDOrUNtMApY3b5dHvc Wte++5P7uqukutlr6Hu2ide26frmrZH51zT90T2HOtw2ORdjaC Y0cT4fFXrFNvCx4fwrXHgmPp3U1NR4JpPhvab67DY5F2FuiN8H iUkoCuNcWXt9k/Zjxmm8S904nJY5nB5qh2w+jG+8eMxzoINjeVQ1N/KVd/Fw6Ou8tXV5DVrJVk7iRfzTr4VsKx9ORyalYq5VeoigWdKY9mLB FPjvc4jzmDOXHjPNbLgxvJwvsYHssUdERjTW3mN90Mdksel9fW JICrODhQn8U3kr9JSQTWfHkjHovQVhRz8X7GlUjuRqYelR+LfL W3pEvYxrO1VkVSMEakpbTcysrhRSJKh2lKXMOpVpPHAqW8dMvV jM1XPyyHSaCk6yhcezxTzYu5xvO4HL5m8dvR1OSxgKtZzDUmX7 1XDvtyibV8ch7Hs9PWRrJ3bWseq2DXBa13yt1L7rqey4iGdcRr 1HOZpV6upnl8bMBpcbl4wqqTVOGSjP/cKY9xkwj1pHgPbhsvZE83OWW9e8kawLZl+/g4UsalNCr21RoZFrvGjXjsKeMqr62RTkfz0Fkby/jYXd6snqv843+QHQdbRdRWqZcxpcrB2tVzCbokg7vlVohJupSp GJw1I0Kd6W1Xz1UOEyJKBrsy2+zRqFIvo+art1roMi5V2NWsnu uwrj1CVkoGn5T+0i0e+0bKuCL8jvC4Imsy2JG7wmbRlo6GjVIv pXGWT8hj9dqKhmU1tR0ff5T1IsnqpjxWlVlKqaJhd0raB5PV0+ axDIyJjsDzTixwrGI+lo+1n/lxjScj4vH07g+Lr2d9uVzS1N48DvOYLw9VWYvJQFj8zgMZ+VX7 wa5G8ZhNTeV5pyrSJSIZ3X6fLRCT5exdxWNurKLnSZ53qoqlpa iEc10es6C5xfNOd82HN1SQ52XSl9N+3mnX9H4uW3M1PBq2nnd6 WK6tJtqy6f7xoV17eNvY8B7h8d/L9T8mhqWracTjHdO7yDlbzzvxQNl63sm7fCIei9iXSGskj/mUqrKObx435fFd56Emnp12H4WKbx53wOMuRVxajEldDngfk6/ubAjv8Xx1d0N4j+eruxvCe7yeq7shvIdytl0P4T1ez9XdOArXH q/n6m5EeHwIYyyPOx1jedzpAI/niojgMXgMHoPH4DF4DB6fdO/gMXgMHoPH4DF4DB7P3jt4DB6Dx+AxeHykeAyBQCAQCGTqAh5DI BAIBDJ7Qb56fjLGyFefyHz1P8qtmQzh/STnq/9W3p7JEN5nmzG+X27PZAjv/1luz2QI7/OUrwaPT6h38Bg8Bo/BY/AYPAaPZ+8dPAaPwWPwGDwGj8Hj2XsHj8Fj8Bg8Bo/ngsfq2Esh4ijqOqdjdnJeJjsY0j0G0j4zMmpcl4jH3nuAl/m6XH7/elkdSc1+Ddwjqc3jM9VyCrSgEFMhXqoDL1U3CFfjGk/lvMxf2IGXqhtE5AhMPSVPq655XmaIl7fYsYshjWt8Llsba1yHx 95DH0M9i6Z7XuZXVdemanlIo4Z1XiY3jp+XGeLlJvMlNHeki5V 8K2SsptzljXg8YsuFxjqxkg/rxErv8kY8XmfHQArNtvS+nN+OG2+b52WezjZa8Hi3uPQS0YX8t vjxhnShNGrcYN5DmqY8tlo5uYdiqmFNfWheu7fLE3URH+s2Eqr DhNE9YpymLY+LjVNEkkluvwRlqXoOqg4KEePaRDz+3r08lodR6 84QcsrVKBiTdX514OTqsTyOtJFQGmVs2rgvGveTUH0gPI0lnBa Kqq2TubxWPwkvLL/Ol4jo9fzjr4vBOfHC0bjG97IeUe+tQhirF4ZxHR6rs5qNg5pF3 yGHx7q5glqleg626ych+0CYvSIMjTYuBud09wijjYTbLLkOjx/kS0S0km89KAZn9IveG8XWg3yJqPdGoZF8J+uROWW+8PA7zmPB1 37ua9sgOzpoY6PZg/nCacdUh8ef5+eJaDm//Xlx6bR+0btW3P48P0/Uu1bcjhirqe2sZxnX5LGAMUn63sp6RL0rxe3d/Lx4oS3z88JM8dvVNOWxgDG5/Radxk2RKdVq4lB4zNoY1+muOIV+i2J8vZwsvpw6PYCLjVNVh0E/kwwCeYxrEvEkeI9mlb09nezgWMKY8fhqGunMWDtf/a9sQXROjGjc7ooumNvlq7/PFkTnRM1a2cSJ8fjamkVog8cLfy2a8VizVrb1jWjUuJf1iJZul RaPe28VzXhssfZstq5g7PJV9Rw0ca543HuzaNP/WLLW09KYayL9FtVUu3z1A9nW907WI1raLDWhzeB4abPcelAOV4 jOZOsumNvlq1VT4TodDyPL2+WrP5dNk7azHtH59dIDXdfY+2N9 HisYKx7fSIno/I3y9m65eoHopWwjtIpPuZo6PFYwDvDYQGxoSrxJqAXy9HnMeh6 z1xLSdTRtePzkzWyR0l0jZyvx42PM7stE5Isd/UAaQ8QT4j3C48eLBozdFk+Kx+tXjf5OjNDUXymeN85XyyjZQK+ rMeLj4uJrqvtT/goRhWBch8c/569YMP6FtWK0CF2JbMj4s/TuhXFNHquQN6JhUfLSrfJjHjSHYFyTx7p7YDE4mw6DPYCTXkVr mZ2WGWw/jGvy2A1wXc2HKXEeK1Q/zJdCMK7JYxX7auhKyHniYzb1QF67F8Y1ebyT9UQ0PEqJ85gjdi frUdI7I++8d3k7HqsAdz0lzmMvZa1oWC1pw+N0VYW5RnwcRqyy iWjq8jhdteJd8aM33vVOxVs8TZ3HRtL50HhcbJyixeXiicOkfx qtBu0Y0Z1yNTWIeFK8xwuv+K7w86tpoJkxT3HL1+37H2sAy6aK EQ3bLV54LTHjY59x/fjYyk4LyvLg2IiGZehsaZrmqzlTjeDY0bjBtExu994qPMnt+jw WTFUNB780ew6aO826B/DZbF3Hx4H95jo8fiivNKKJ8Pgr1iO5BY8FUwVfIzxmu8W9M4kZ HzvBdH0e70nvcj/Yz+NRSrwnsZriy1vwWCSiBXrH8pgb3y+3Py9Xl8PBca39Y8Zjt iXceynx8FgYG8Gxo2m2f8x4rINgc1M5NPWXcvV34eC4Ax7z6Pj Q8tWsg28lHEtPLqdmpVJ+hapY0JnyaMYS8eR4j/OYM5gTN85jvTy4kSy8j+GxTEFHNNbUZn7TzWC35HF5bU0CuIqD A/VZfCP5m5REYM2XN+KxQCmvxnI19pJy+DrRuWztVkpV4lpqmvK4 SlCb1VjB+JiW0nIrK4cXiSgdpilxDSd6TR4/lFca0YzNVz8sh0mgpEt4j2eqzWIuf75aLymHK0Qr+ZabwW7K4z 3p3UpKR/LVe+WwL5dYy5vyWHDXLOYK5qstY76pPC0eV8py9YKrFPltVrrl aibhsQp2XdB6p9y95G55bCNV/WxUb43TNI+PDTgtLhdPWHWSKlyS8Z875TFuEqGeFO/BbeOF7Okmp6x3L1kD2LZsHx9HyriURsW+WiPDYte4EY89ZVzlt TXS6WgeOmtjGR+7y5vVc5XD14koGdxT+WdXI2Nfs4zLr2lWzyX ImgzullshHusyrmJw1oyGdZa7XT1XOUyIKBnsymyzR6NKvYyar 95qocu4VGFXs3qucrhCRMngTrnF8bySb7mxry7+klNmhVfzei5 B1mSwI3eFzaItHQ0bpV5K4yxvVs9Vri4TUXJpW2abdWGXrOfSG seY83sqPNYlWrKeS1dvlasXiCi5dKu8zZnNNRPyWFVmKaWKht0 paR9MVk+fx2Z4rIhMXHtIzzuxwLGK+Vg+1n7mxzWejIjH07s/LL6e9eVySVN78zjMY748VGUtJgNh8TsP5P5ztR/sahSP2dRUnneqIl0iktHt99kCMVnO3lU85sYqep7kead75uMT5 7I1V6Oz0+XaW4nW/2Pi553umr5UgOvl8ZfTft5p17lSV8OjYet5p4fl2iq7G033j++ YvkSAaz3vpHlcrr8hfU3leacdx/sXzvNOPFC2nnfyLq/PY+8DS9bzTorHXuP45nFjHpcbV+TtrTSSx7fs54s2XM2EPL7rP NTEs9Puo1DxzeNO6rm6E3FpMSZ1OeB9TL66syG8x/PV3Q3hPZ6v7m4I7/F6ru6G8B6v5+puCO/xeq7uhvAer+fqbgjv8Xqu7kaEx4cwxvK40zGWx50O8HiuiAgeg 8fgMXgMHoPH4PFJ9w4eg8fgMXgMHoPH4PHsvYPH4DF4DB6Dx0e KxxAIBAKBQKYu4DEEAoFAILMX5KvnJ2M8W+///vNMhvB+kvPVs83ZIl+NfPVJy1d/Wu7MZIDHc0VE8Bg8Bo/BY/AYPAaPT7p38Bg8Bo/BY/AYPAaPZ+8dPAaPwWPwGDyeCx6rYy+FsKOojc5NeaptxAGZnZyX yQ6GdI+BtM+MjBrXJeKx9x7gZf6+XP7Z9fLffy4+WzB+DT677j Wm96/aGqL00WZTHqsDL1U3CFfjGk/lvMxf2IGXqhtE5AjMb9hvvjituuZ5mSFmfMiOXQxp1LDOjOTG8 TMjQ7z0HngZ6tc03fMyD+3aQ7x0D7y0zsv0Gk/lvMwvqq5N1XKhsc7L5MM6L9O7vBGP19kxkEJjnZcZMfaeoNmUx +pETPGj7O9kN5PgU6qBhKtpyuNPit//hui3+bb48W32hpbl2+zfu7CPGHcYH1uNEyvcVgqni1ORJWJu4n 4SxcYpIskkt1+CslQ9B1UHhYhxbSIef+9eHj9aJKL00Wbx2QLR QvadBqqrKR8tVhq5qvzperas2dw0Po60kVAaZWzauC8a95NQfS A8jSWcFoqqrZO5vFY/CS8wVC8Es1+CodHGxeCc7qBgtFJwGwbX4bE6p9o4pFp0fHJ4rB tLqFWq32K7fhKHde1eWOoWEeqQ6mJwRreIMLoam90j3BfN+0nk S6R7RZhNI2Q/CW1stJowXzjNoOrwWHVn0k0jikunRRsJ2U8iYqymrI7I9XlcNW hy+x/LfhLaUrWaUB0mHE1THgsYK75+kp8n6l0utj/JzxOD9Kflziflny4nBneVjUX0jnns0jhJU63KUxfHE/ZbFOPr5WTx5dTpAVxsnKo6DPqZZBDIY1yTiCfBezSrXHy2QLSY/yTp+91K4gTHJo8Xsu82y5+upoGwuFG++l/ZguicGNG43RVdMLfLV3+fLYjOiZq1sokT4/G1NYvQBo8X/lo047HJG09bX66J9BxUU03jY87as9m6grHLV9Vv0cS54nHvzaJ N/+NDuPZ4Vll1O470W3S7K7pgbpevVi2N6/RbjCxvl69W3Y7j/RYtY++P9XmsYKx4fCMlovM3yqqbk7dFhFhltEB2NHV4rGAc4HH vcsF5vPrbAHTF+/wm+9Nh8NjtgJzmDNE8qa2iYsbjSIAcY9KTN7NFSneNnK3Ej48x uy8TkS929ANpDBFPiPcIjx8tGjCustCGhsfTOm7+bkX/PiyvFK59DR7/b/6KhV5XY8THxcXXVPen/BXxebwwrsPjn/NXLBj/wloxWoSWv/lVQ8afpXcvjGvy2A3yXM2HKXEmKVw9zJdCQKrJY905sRicTYfB/sdJr6K1zE7LDLYfxjV53PW1x3msYl8NXQk5T3zMph7Ia/fCuCaPd7KeiIZHKXEec8TuZD1Kemfknfcub8djFeCqfk0RylrR cLzFk/Ae5HG6yvs76fg4jFhlE9HU5XG6aoXC4kcLxha8Kfl9WurZNOu5 9h3x2Eg6y1Q0I63Z9jjJiqnwuNg4RYvLxROHSf80Wg3aMaI75W pqEPGkeI8XXn23kqhI96erqRsc8/hYGZsaz5J68bFqqhjRsN3ihdcSMz72GdePj63stKAsD46NaFiG zpamab6aZ26NANHRRJj0FesT3ILHgqmq2eKXZr9Fc6dZ9z8+m6 3r+Diw31yHx4dw7bHgOF8iydcIj9luce9MYsbHTjBdn8d70rvc D/bzeJQS74ispvjyFjwWiWirf2KIx9z4vuygHAqOa+0fMx6zLeHe S4mHx8LYCI4dTbP9Y8ZjHR87KWhrSkXDYrk3OO6Ax0Z0bBV4Wb Ct0tNTyFezDr6VcCw9uZyalUr5FapiQWfKoxlLxJPjPc5jzmC1 Peyp/FrMf9r0ADu8kSy8j+GxTEFHNNbUZn7TzWC35HF5bU0CuIqDA/VZfCP5m5REYM2XN+KxwAkvX3I1Y3O2D8thEihrEt7jmWqrGisY H9NSWm5l5fAiEaXDNCWu4USvyePDufZ4ptos5vLnq/WScrhCtJJvuRnspjzek96tpHQkX71XDvtyibW8KY8Fd81irmC+ 2jLmm8rT4nGlLFcvuEqR32alW65mEh6/nRLR+bfLbZGd9lKWbyRXQXOgmGv6PA4gVUe+nldqzcT1XLzGWF cnqcIlGf+5Ux7jJhHqSfEe3DY2S7QCe8lGzZdbBdYqPo6UcSmN in21RobFrnEjHnvKuMpra6TT0Tx01sYyPnaXN6vnKocJESWDXZ lx9WhUuZNR99RbLXQpkypuasTjiqzJ4G65FeKxLuMqBmfNaFhn udvVcx3WtfthXA5XiCgZ3Cm3OJ5X8i039tXFX3LKrPBqXs8lyJ oMduSusFm0paNho9RLaZzlzeq5ytVlIkoubctssy7skvVcWuMY c35Phce6REvWc+nqrXL1AhEll26VtzmzuWZCHqvMs1urpadkfC yYbeWuu+WxuXns4bERNDtx9DSfd2KBYxXzsXys/cyPazwZEY+nd39YfD2T+6KKpvbmMUtl2887seWhKmsxGQiL33k gf52q/WBXo3jMpqbyvFMV6RKRjG6/zxaIyXL2ruIxN1bR8yTPO6lneIScy9ZcDY8IrWd+HpZrq4m29L oQs+FtYy0qwPXy+MtpP+90aNce3jbWIgJc63knzeNy/Q3payrPO+043r9wnnfigbL1vJN3eX0eex9Ysp53Ujz2Gsc3jxv zuNy4Im9vpZE8vmV6fynbcDUT8vhT5xEmxeMqLGZTqen9kOq5u hNxGTEmdTngfUy+urMhvMfz1d0N4T2er+5uCO+hnG3XQ3iP13N 1N47Ctcfrubobwnu8nqu7IbzH67m6G2N53OkYy+NOB3g8V0QEj 8Fj8Bg8Bo/BY/D4pHsHj8Fj8Bg8Bo/BY/B49t7BY/AYPAaPweMjxWMIBAKBQCBTF/AYAoFAIJDZy5zlq//r/8qZDHiHd3iHd3iH9069g8fz8T3BO7zDO7zD+/H2Dh7Px/cE7/AO7/AO78fbO3g8H98TvMM7vMM7vB9v71PjsdU+gvU7JqLY6ZiNzsus eWEfyfd89VvP7L0fs9Ns6r2b8kPfzKfyPcE7vMM7vMM7vDf1Pv 342GoaIXtFUJrrFoxm40VTMzGP7/2YnabkDz+W975NiZI//Oi5Teom3vs2Fa+t29f6e4J3eId3eId3eG/hfdo8Zs0j3HZPbnfFpv0W69ypj7KEKH3vV8/Fq9tEzk0RU6ezYsLvCd7hHd7hHd7hvYX3KfOYt3gqsoSShCej9 azEtquZnMfv3SR+p/jF3/sxO30zV3+tOPfX/jOnxfcE7/AO7/AO7/Dewvt0eWwknfOUrG7HM+dxdb+cOyU0oT9bpvU9wTu8wzu8wzu8 h7xPlcdmA2SWga4mustXq611upi9/9/BTIL3TlXphfA2+9jvCd7hHd7hHd7hfULv0+SxjVRVq6UmjAovt +ZrivVc9Oq3eqfdumX8Tt37NX+ViC5mH/0ae094h3d4h3d4h/dOvU+Tx2Z4rFXE1DN53ilyp/SfPEQ0jX1+eId3eId3eIf3Ft5xHkitAe/wDu/wDu/w3ql38Hg+vid4h3d4h3d4P97eweP5+J7gHd7hHd7h/Xh7B4/n43uCd3iHd3iH9+PtvTGPIRAIBAKBTF2a8RgCgUAgEEgXAh5DI BAIBDJ7AY8hEAgEApm9gMcQyEmRg4Nne32i0b7WPNvr9/eeHRzM8FNNIgf7I6L+3rN5/fwQCBfwGDLfIhCjZLQ/0X/N7N1G+zUopXjmvqjr0boAIiJa3t6JvElriD7b63MYT/JWrcW63PXHT/2XH/hOD/ZHfKLSzPOfFBCIEvAYMt/CiTIVurR7k8ldd43GAwmuw3Tq+RiB7yv2WiJZvqw+7f5otH8g/gKa9O8wCOQoCHgMmW8x/rY7KaEAAAKJSURBVO/eH4mYicVgFYG0RkWxpoH/DXkw19/74en9fn9vb6TCsyoa/uG5DvJUaGuF2sKSr41diHjbp/f7/dGoL+yrt9NOnQ/jfmAOWh5HumbuDQlfu7ycoL3/nke+L+/lW0t+eP5UaN3fAWE+yW8RBHIUBDyGzLeY+U8HrvsjGu3LCOrgx YsX+6PR4+ePR/JHN0DUmeeD/RHnnGCS0uyPFKXcfPUPzx+PeFRXfQZjrRWV+nks7OQuKXfq+TD MqXtdClqe63JuiPtWhrvqtkbf4el9fs/3OVx931eMxwf7Ixo9Zm9o/w4wrkMg8yvgMWS+xfv/uB3bPX88krHlC2cL09oq9u4E85DUq7F5bFkKnETz6hF33jePfB ivC81jP/iNG+J+WueKHHtLY97z+PcVef2C8ziQWp/3qjQIRAh4DJlvMf4f14EUS6IaszZsIm9oJ3iPPo8fr1NrHseT2 +NgHyKiuudGfGx+X26iIpCvfuzuf+tPi/gYMv8CHkPmW+z9SJMcz/b6QjOqUrXP9vr9+z/oZGzkDXkBVC0es31if766ax4zYnmQKRHLr6u6P8/tGzLm2lnGm9mbmmd7/J7789IO9T2v2Tt767leYP8YclwEPIbMt5i5U7VhKXPVo1Ff56u rHUt7lRWKsbcynq4ZlyIWtvF6rk55/Mz5wAaPOWKlmbg/bobffSsrho5WhPE9An3PI9+X5/LNy1DLrdUvKt6jvhpyHAQ8hkDGy9xlRL0f+Jnz/HHrtzo6guePIcdGwGMIJCgsRKx1PMjMJf6B3fO5Wr/VERGczwU5TgIeQyAQCAQye6l4/D8QCAQCgUBmKh988AF9AIFAIBAIZNZCEAgEAoFAZi7/D+SUbLk4q6AuAAAAAElFTkSuQmCCAA==[/IMG]
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact |
#628 |
Drives: Toyota 86 Turbo, Lexus NX300H
it works great .
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
#629 | |
Drives: White brz
Thanks |
#630 | |
this is assuming your using V4 tune for 2012-2016 car and using the appropiate auto or manual def |
| rom tuning for pops and backfires | andrew5826 | Software Tuning | 110 | 12-23-2016 05:39 AM |
| First romraider defs are up | jamesm | Software Tuning | 95 | 01-13-2015 06:29 AM |
| Transient Ignition Retard Tables from RomRaider | Ralph Spoilsport | Issues | Warranty | Recalls / TSB | 31 | 05-24-2014 08:48 AM |
| OFT-Help with Romraider/FFS and Launch Control-issues | continuecrushing | Software Tuning | 9 | 04-18-2014 12:07 AM |
| Possible backfires | Bg8780 | Engine, Exhaust, Transmission | 0 | 05-22-2013 03:12 PM |
