#575 | |
Drives: 2014 BRZ - WRB
Updated B01C
Thanks! |
#576 | |
Drives: frs
#577 |
Drives: BRZ SWP Limited -6MT
you're in luck. I have b01c as well. I took the def Steve posted to first page of V4 release thread and adjusted to allow me to modify the generic v4 tune.
#578 | ||
Drives: Toyota GT86
B01C V4 def But it's probably the same as bababooey's upload. Same principle, only for V4 tune and remove any other B01C def.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
#579 |
Thank you!
#580 |
Drives: 2016 Subaru BRZ Series.Hyperblue
Any way to get the car to pop with the overrun method while in neutral? i changed base idle timing (neutral) to -8 from 2500 onwards, but no pops
#581 | |
#582 | |
Drives: 2013 Subaru BRZ Premium
If not, can't i just change the calid in hexeditor/dreamweaver, save it, and use that as the definition file? Do I have to change the "make" "model" in it as well or can i just leave it as Toyota GT86?
2000 BMW 323i 2013 Subaru BRZ Premium Last edited by MrStickers; 04-11-2018 at 12:25 PM. |
#583 |
Drives: 2012 GT86 EU-spec
I've been running +5 from 2500 rpm for the last 6 months, works like a charm and produces a nice pop. However friends tried the same, but got almost nothing (on stock exhaust) or super loud pops on exhausts with less dampening, so it really seems to depend on setup, I have a video somewhere, will share it soon
| The Following User Says Thank You to Vin For This Useful Post: | D_Thissen (04-11-2018) |
#584 | |
#585 |
#586 |
This is -5 , higher frequency of pops and also the sound is higher tone, popcorn:
https://photos.app.goo.gl/4liEBWosYpzRdEFK2 This is +5 on a dyno, lower frequency and a lower tone, more a burble/fart than a pop: https://photos.app.goo.gl/w4IYkqxjd7nPwEqC3 Results will vary per exhaust setup. I'm using a catless UEL and a high flow cat in the front pipe, resonated mid pipe and aftermarket (custom) axle back.
#587 | |
Drives: Toyota GT86
If editing a def file, use notepad++ . It has code-coloring, makes it easier to read and edit. Make and model doesn't matter, you can put in "Pink unicorn" and it will work. As said before, only for V4 tunes and remove old definitions in RomRaider or you will brick your ECU.
| The Following User Says Thank You to elBarto For This Useful Post: | MrStickers (04-11-2018) |
#588 | |
@bababooey I've noticed the negative values at higher rpms produce a sharp pop. Similar to a gun shot.
| The Following User Says Thank You to D_Thissen For This Useful Post: | Vin (04-12-2018) |
| rom tuning for pops and backfires | andrew5826 | Software Tuning | 110 | 12-23-2016 05:39 AM |
| First romraider defs are up | jamesm | Software Tuning | 95 | 01-13-2015 06:29 AM |
| Transient Ignition Retard Tables from RomRaider | Ralph Spoilsport | Issues | Warranty | Recalls / TSB | 31 | 05-24-2014 08:48 AM |
| OFT-Help with Romraider/FFS and Launch Control-issues | continuecrushing | Software Tuning | 9 | 04-18-2014 12:07 AM |
| Possible backfires | Bg8780 | Engine, Exhaust, Transmission | 0 | 05-22-2013 03:12 PM |
