#43 |
Drives: 2007 STI Limited / 2014 BRZ Limited
There is no reason for it to hurt the exhaust valves. The unburnt fuel should be igniting in the hot exhaust well after the valves. Its not enough of a back pulse. Again its done in many OEM cars these days in the same manor with no issues long term.
| The Following User Says Thank You to Proof For This Useful Post: | invaliduser (03-24-2014) |
#44 |
Drives: white out project fr-s
here we go.....this video was taken at night so its more of a sound clip than a video but you get the idea =) the first half of the first video is me warming up the car, the second half is me beating on it a little. i was trying to get as much popping as i could so normally it wouldn't pop that much
[ame]http://youtu.be/kKbCCrdqrCI[/ame] and here is the in car video. [ame]http://youtu.be/HmvqDhd2FBo[/ame] Last edited by carlitosway6891; 03-25-2014 at 12:24 AM. |
| The Following User Says Thank You to carlitosway6891 For This Useful Post: | Sargy (03-26-2014) |
#45 |
I wanted to try for something a little more subtle, but still present, so I went with 15 instead of -10 and adjusted the overrun also. Very pleased with the results.
#46 |
Drives: 2015 Trailhawk
I made the adjustments last night and its still adapting. I can make my car sound like its making orville redenbachers in my trunk on command... lol
| The Following 2 Users Say Thank You to Migero86 For This Useful Post: | carlitosway6891 (03-26-2014), mr. slim (03-26-2014) |
#47 |
SoCal86
Drives: '13 Whiteout FR-S
Can some one upload they're files?
.: SUPER KAWAII :. .: BUBSQUAD :. .: LivinLow :. .: FRS86 :. |
#48 |
Erected Member
Drives: frs
The file it self is just the ots map with the added adjustment which takes roughly 1minute to implement. But if you must have it., PM me your email and the ots map that youre currently using, I can send you a moded version.
With that said, I however can not be held responsible for anything that could or may happen to you and or your vehicle by using any files that i send you
| The Following User Says Thank You to shif7i7down For This Useful Post: | mr. slim (03-27-2014) |
#49 |
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
i would do it myself, but i don't understand why romraider dont want to be installed on my pc!
#50 |
Drives: GBS BRZ
| The Following User Says Thank You to bee_are_zee For This Useful Post: | Walla Walla (03-27-2014) |
#51 |
Long Distance Driver
This sounds great. thanks for sharing!
| The Following User Says Thank You to Sargy For This Useful Post: | carlitosway6891 (03-30-2014) |
#52 |
| The Following 3 Users Say Thank You to Migero86 For This Useful Post: |
#53 |
| The Following 2 Users Say Thank You to carlitosway6891 For This Useful Post: | mr. slim (03-27-2014), Walla Walla (03-27-2014) |
#54 |
Drives: frs
Fuck ya! Because racecar
#55 |
Drives: frs
#56 | |
Drives: frs
Have you tried setting the overrun enrich rpm delta activation lower to say, 4k? That should allow for the popping at a lower rpm rev, right? Also, is there a parameter to change how long the overrun condition lasts? That way we can set it to pop fewer times each rev. Finally, can you change how much fuel is injected during the overrun condition? Might be able to get those flames if you set this higher and delete the cats
| The Following User Says Thank You to gonzo For This Useful Post: | mr. slim (03-27-2014) |
| rom tuning for pops and backfires | andrew5826 | Software Tuning | 110 | 12-23-2016 05:39 AM |
| First romraider defs are up | jamesm | Software Tuning | 95 | 01-13-2015 06:29 AM |
| Transient Ignition Retard Tables from RomRaider | Ralph Spoilsport | Issues | Warranty | Recalls / TSB | 31 | 05-24-2014 08:48 AM |
| OFT-Help with Romraider/FFS and Launch Control-issues | continuecrushing | Software Tuning | 9 | 04-18-2014 12:07 AM |
| Possible backfires | Bg8780 | Engine, Exhaust, Transmission | 0 | 05-22-2013 03:12 PM |
