86WORX
MisterSheep
Old 01-11-2018, 04:34 AM   #533
stefodrom
stefodrom's Avatar
Drives: GT86 AT 2013
Originally Posted by Evangelion View Post
In paddle shifter mode? And does it pop only when downshifting? And what do you mean .20 column?
Yes, you need to go in paddle shifter mode, otherwise the at transmission is shifting into the next gear before any pop sound. Because you ned to feather the throttle just a little bit.
But the good thing on an AT car with this tune is, you're still be able to drife completely normale without any pops in AT mode.
I'm using the tune for about an half year now its awesome.
Your can also recieve pops on downshifts if you got the feeling for the throttle. Put it in the right position for pops and downshift after.
It may take some time to get used to it, but you'll see its easy to controll.
stefodrom is offline   Reply With Quote
Old 01-11-2018, 07:19 AM   #534
steve99
Would you by chance able to do backfire tunes on the 2017 86 models? If so I would be interested in buying considering I can't figure out why it won't work for me.
If i have a working definition for opensource tuning i can do it for oft tactrix.
If no defs then only option would be ecutek or brzedit
messsge me and we can sort something out
Old 01-12-2018, 09:00 PM   #535
Evangelion
Drives: 2017 GT86
Thank you, I will try this- maybe this is why I couldn't get it to work originally. Do you also feather the throttle? And what gear/rpm does it normally work better on?
Evangelion is offline   Reply With Quote
Old 01-15-2018, 07:28 AM   #536
stefodrom
stefodrom's Avatar
Yes, you need to find the correct throttle position while the engine rpm's are "going down" it sounds best between 3k and 5,5k Rpm for me.. It works in every gear, but i like to do it in 2nd or 3rd the most so i for example accelerate to 6k in 2nd gear and then just press the trottle so slightly that the rmp's are going down and feather a little bit to find the sweetspot. Its takes a little bit of pracitice but you'll learn it
Its also nice to hold the correct position and on 2-3k rpm press the left paddle to do a downshift in a tunnel does some nice bangs
Old 01-16-2018, 03:51 AM   #537
GT864lyfe
Dk8six
Drives: Scion FR-S
Originally Posted by SmsAlSuwaidi View Post
@nelsmae @jamesm
You guys should check out my instagram and see my flame thrower map! It's getting a lot of attention right now and my tuner is local to az! Check it out on instagram: @DK8six😎
GT864lyfe is offline   Reply With Quote
Old 01-16-2018, 10:23 AM   #538
stefodrom
stefodrom's Avatar
can you post your settings pls?
Im trying to get flames for some time now but still have none...
Wich exhaust setup are you running? full straiight piped?
I only got the rear silencer left, everything else is piped^^ but still no flames, so probably i got wrong settings.
Old 01-16-2018, 10:07 PM   #539
Evangelion
Drives: 2017 GT86
Thanks so much man!!! I've struggled with this for 3 months now, and today I can finally say, my car can pop!
Old 01-17-2018, 02:51 AM   #540
stefodrom
stefodrom's Avatar
Nice dude! Im glad to hear that!
Wish you a lot of fun
Old 01-24-2018, 02:30 PM   #541
D_Thissen
D_Thissen's Avatar
I just want to be sure I'm doing this correctly. I load the AO1C def from here, http://www.ft86club.com/forums/showp...&postcount=411, and then open my AO1C bin from the OTS v2.076 downloads folder.
Old 01-30-2018, 11:05 PM   #542
Alysa
Alysa's Avatar
Drives: Whiteout '14 FR-S Monogram A/T
Anyone know if e85 or being boosted effects the values I should put in for the overrun stuff?
Alysa is offline   Reply With Quote
Old 01-30-2018, 11:28 PM   #543
eddieflyinv
eddieflyinv's Avatar
Yessir, looks good
Sent from my SM-G950W using Tapatalk
eddieflyinv is offline   Reply With Quote
The Following User Says Thank You to eddieflyinv For This Useful Post:
D_Thissen (01-31-2018)
Old 01-31-2018, 01:55 AM   #544
D_Thissen
D_Thissen's Avatar
Originally Posted by eddieflyinv View Post
Yessir, looks good
Right on, thank you. Might try it out for a few days this spring.
Old 02-07-2018, 08:51 PM   #545
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Has anyone tried this with E85? Is it the same procedure- changing the 1st column of Table B?
Old 02-12-2018, 06:32 AM   #546
guybo
Huge E85 fan!
guybo's Avatar
I trried it, just like you do with regular tunes by changing column 1 of table B. I didn't even retard the timing, I just used a lot less timing advance- just to be safe. Wow did it suck. It made the car way too jerky when I shifted. It was impossible to do a smooth up shift if I was getting on it. So I canned that idea, and the default E85 tune is very quiet, so I don't know what to do to make this tune a little more poppy/burbly.
rom tuning for pops and backfires andrew5826 Software Tuning 110 12-23-2016 05:39 AM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 06:29 AM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 08:48 AM
OFT-Help with Romraider/FFS and Launch Control-issues continuecrushing Software Tuning 9 04-18-2014 12:07 AM
Possible backfires Bg8780 Engine, Exhaust, Transmission 0 05-22-2013 03:12 PM
