#506 |
Huge E85 fan!
Drives: 2016 Scion FRS
The OEM muffler will completely kill any sound you get. I did it with the OEM system and a Berk muffler delete with the cats gutted and it worked great. I don't know how much sound you'll get with the cats intact- you'd damage the cats eventually anyway.
#507 | |
Drives: frs
| The Following User Says Thank You to Totalrecall For This Useful Post: | guybo (12-07-2017) |
#508 | |
Drives: FRS-Released Series 1.0
https://imgur.com/1sfuqLd Is this file broken something? I did flash it in my car before and it was fine. Thank you! |
#509 | |
Drives: Toyota GT86
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
#510 | |
#511 | |
If your using OFT its not going to be that easy as the defs those guys did are for B01D not D00D. If you had tactrix/ecuflash you could just use B01D rom and def. Otherwise your doing to need a hacked rom and def to fool oft defs are here but they are incorrect calid for you http://www.ft86club.com/forums/showp...&postcount=411 |
#512 | |
Should pop fine doing just base B are you putting in negative numbers ?? you will need to feather throttle on overrun for more pops |
#513 | |
Proud of BOXER
Drives: Subaru Boxer
Nice username.
#514 |
Drives: BRZ SWP Limited -6MT
@guybo - u still running this feature? did messing with the values ever change anything?
ive got -6 plugged in down the line in first column. while i usually get a nice pop (not shotgun bang) between upshifts, the popcorn off throttle is growing old, especially in first in parking lots. stock FP, aftermarket all components. anyone know of a way to retain the upshift pop without going catless FP? |
#515 |
Huge E85 fan!
I kept dialing back the timing (retarding it less) until I got the sound to where I wanted it. I think I actually got into positive territory before it was unobnoxious enough to run. I wanted burbles, not pops or shots.
Right now I'm on the pretty much stock Stage 2, but I still keep the other tune in my back pocket, I may go back |
#516 |
Drives: 2017 BRZ Performance Package
So right now I have -15 in the .15 column and I get some pretty solid burbles, though I want gunshot style pops. Should I go down to -5? For some reason the louder pops are completely unpredictable...
I have a Borla UEL, invidia resonated catless front pipe, and an n1, though my pops aren’t as ridiculous as I want them . |
#517 |
ive got -6 and similar results to yours on decel. no shotgun blasts, but a nice pop on most upshifts. im willing to give up the burbles for a single pop.
#518 |
Huge E85 fan!
Are you guys catless? Because even at -5 I got gunshots sometimes. Hell at -9.96 I got AK47 gunfire!
I went back and re-did my tune (changed FFS and LC too) and I changed the B table some and I'm popping again. not a lot of burbling though (my new Works axleback really changes the sound from when I had a Berk dual exit). It sounds good now. Between 2800-4000 RPM I advanced the timing because in that range it gets obnoxious |
| rom tuning for pops and backfires | andrew5826 | Software Tuning | 110 | 12-23-2016 05:39 AM |
| First romraider defs are up | jamesm | Software Tuning | 95 | 01-13-2015 06:29 AM |
| Transient Ignition Retard Tables from RomRaider | Ralph Spoilsport | Issues | Warranty | Recalls / TSB | 31 | 05-24-2014 08:48 AM |
| OFT-Help with Romraider/FFS and Launch Control-issues | continuecrushing | Software Tuning | 9 | 04-18-2014 12:07 AM |
| Possible backfires | Bg8780 | Engine, Exhaust, Transmission | 0 | 05-22-2013 03:12 PM |
