#43 |
The compressor may be more efficient, but at what point in the RPM band?
#44 | |
KCCO From Canada
Drives: Asphalt FRS
Theoretically the airflow would be similar (looking at both compressor maps) to a gt30r but i doubt it would make the same power. thats just my assumption though. |
#45 | |
if you read what i wrote, i said the rotrex is going have lower temps which will make more power, but the trade off was that it would also take a few hp to turn the supercharger. |
| The Following User Says Thank You to gmsii For This Useful Post: | glamcem (03-23-2014) |
#46 | |
#47 |
Drives: 2022 BRZ Limited
That's what I figured, worst case scenario I think I can use a slightly smaller nut/bolt with a lock washer.
Thanks
#48 | |
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
SOLD THEM BOTH
Hers: 2007 987S Mine: 2012 991S That was fun, thanks Hachi ![]() |
#49 |
I Love custom Turbo kits
Drives: Limited BRZ
Agree. Already been done by others, limit has yet to be found
#50 |
Drives: 13' Scion FRS Track car
I am curious to hear more forced induction track guys.
What's the verdict on the most reliable/cool kit for road course endurance ? I think a modest amount of additional power is ok if it can be sustained. |
#51 |
I have been tracking my Kraftwerks powered BRZ for a while and happy so far, I have been pushing really hard too.. I snapped my belt at the last event but since it's a separate belt design I was able to drive with no problem.. hopefully I will get my replacement belt soon and will attend a few more events before October
#52 |
@glamcem, did you had any trouble keeping it cool ? or the combo radiator and oil cooler did the trick for you since day one ?
What's your take on the difference between the supercharger in the market: Vortech / JacksonRacing / Kraftwerks ? |
#53 | |
For any FI system, you will need an engine oil cooler. Jackson Racing provides the one of the largest (if not largest), by volume, plug-and-play oil cooler kit on the market which has shown to maintain oil temperatures to a good level. Radiators are not absolutely necessary with SC, but fans are recommended with SC. With the Jackson Racing SC kit + Oil Cooler kit, we have found that the system maintains power even with 16 consecutive pulls on the dyno with the dyno fans on, hood closed, zero cooldown, zero ramping, etc. The back-to-back pulls without the oil cooler kit showed massive drops in power with each pull. The turbo setup showed significant power loss after 3 pulls (% same as 11 pulls on the SC w/o oil cooler) with good cooling setup. The Vortech guys are using oil cooler kits + aftermarket radiators + our recommended fan setup to keep things cool. It also helps to have a good vented hood to help draw out the heat. With any FI kit, the proper preventative measures should be taken. @King Tut has been able to provide information on how to develop a very reliable and powerful turbo setup. We have also made the Greddy Turbo Kit a success without overheating issues after some extensive cooling modifications. It's all in how much prep you put into the car as opposed to the absolute power gain you're looking for. Hope all this information helps you out!
| The Following 3 Users Say Thank You to CSG David For This Useful Post: |
#54 |
I wish all kit manufacturer would offer a road and a track version of their kits as obviously the road version really doesn't require that much cooling.
I am glad to see people here having good experience, so it seems to be doable at least ![]() Does anybody knows here why nobody followed the TRD twin scroll supercharger design ? too expensive to build ? Because it seems that the solution all manufacturer are using, from GM in the z28, to Chrysler in their latest Hellcat engine. |
#55 | |
After I read the horror stories of the Vortech units I would stay away from it ..maybe @Wonderbar can chime in and share his own experience with them.. It seems like for the extreme heat conditions JR and KW kits are better since they both utilize the same Rotrex unit ( there are some differences in detail and some prefer the other ) I would definitely read both of the threads of the owner experiences.. in my case being able to drive when a belt snaps is a big plus since I want to be able to drive home especially when I drive down to Oregon Raceway Park, also bigger IC on the KW might help for recovery too but by how much I don't know.. my experience with KW customer service is also great..good luck finding the kit that suits you the best..I think you can't go wrong with either Rotrex kit
#56 |
NASA SpecE30 Racer
If you want a positive displacement blower, then go with the Innovate kit. What you will find though is that the blower is very small and will heat soak very quickly. The intercooler solution is too restrictive to make big power on 93 octane as well. The reason nobody followed the TRD supercharger was because it was expensive and only designed for racing teams, and they had no real success with it.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| Transient ignition and knock count | brn12345 | Software Tuning | 19 | 06-11-2014 12:46 AM |
| Transient Ignition Retard Tables from RomRaider | Ralph Spoilsport | Issues | Warranty | Recalls / TSB | 31 | 05-24-2014 08:48 AM |
| Avo turbo heat management on track | ICantAffordAnLFA | Forced Induction | 18 | 09-09-2013 12:00 PM |
| MP3 management software for PC? | mit_peid | Electronics | Audio | NAV | Infotainment | 9 | 06-08-2013 09:14 AM |
| ROTREX SC Brainstorming | MANDALAY | Forced Induction | 61 | 12-11-2012 06:57 PM |
