#29 |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
Wasn't I there when we were trying to fit the damn thing and the fitment was over an inch off? We had to pull the radiator hoses really hard to slip it on lol.
#30 | |
Drives: 2013 Black FR-S
@ImperiousRex regularly tracks his greddy kit. I would ask him questions about his experience. I also think @CSG Mike has had lots of seat time in this car. The avo kit is being tracked hard on the AVO car in Japan and also a shop car in the UK (the name evades me). No one has been pushing the ptuning kit on track, to my knowledge (which may change since I am installing one on my car). The only track footage released by ptuning is AutoX. Element tuning is tracking a FA20club kit hard on track (or was, until an unrelated engine fire stopped them). Team VCMC is tracking the full blown turbo kit still as far as I know. |
| The Following User Says Thank You to sw20kosh For This Useful Post: | ultra (03-19-2014) |
#31 | |
Track Junkie
Drives: 2013 Subaru BRZ Limited, 2005 S2000
The main issue with the kit is managing heat soak since the turbo is front mounted and the engine intake piping is surrounded by the turbo and the exhaust manifold. @CSG Mike had been complaining that on track my car felt like it was like stock S2k power and there was no way it was making the numbers that were achieved on the Evasive dyno and I personally felt like the car was making quite a bit of power on the street. So we had the car tested at multiple dynos to verify and we had some interesting results. I'll post on my member journal regarding the numbers soon. But let's just say neither of us was wrong... Regarding the Robispec cooler though, it's been up to the task for the most part. The coolant temps typically level out at about 190 (since it is water cooling the oil) and oil temps on the street range from about 180-205 depending on whether or not I'm running WOT. On track oil temps reach 220-230 and coolant temps get up to about 210-215 but they stay pretty stable at those levels. I did have a fan fuse blow out though and had to replace the stock radiator fans when they melted from not running and being in close proximity to the turbo manifold. So I used the opportunity to upgrade to Spal fans with a @Carolina Dyno shroud. After fixing the fuse and upgrading the fans, the car has been pretty stable. My biggest lesson with tracking the car with FI though is that you need to be religious with the routine checks and maintenance. There are many things that can build up over time and a failure at any one point could chain reaction into other issues.
| The Following 8 Users Say Thank You to ImperiousRex For This Useful Post: | Draco_PR23 (03-20-2014), glamcem (03-19-2014), OjiGeorge (03-21-2014), Sportsguy83 (03-20-2014), sw20kosh (03-20-2014), ultra (03-21-2014), wheelhaus (03-19-2014), WillRacer1jz (03-22-2014) |
#32 | |
I Love custom Turbo kits
Drives: Limited BRZ
I kept V. 2. Thanks for mentioning it as I had completely forgotten.
| The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post: |
#33 | |
| The Following 2 Users Say Thank You to sw20kosh For This Useful Post: | CSG Mike (03-20-2014), Sportsguy83 (03-20-2014) |
#34 |
Drives: 2022 BRZ Limited
wow, that bad huh?
#35 | |
Drives: 86
There may be heat soak still, but I'm definitely faster on the straights now. It's not a huge difference, and it doesn't seem like I pull that much harder, but it's definitely more than it was before. |
| The Following User Says Thank You to TemeCal For This Useful Post: | ImperiousRex (03-21-2014) |
#36 | |
#37 |
#38 | |
Turbo advantages: - Makes more power at the given boost level (more efficient) ** actually this is not true...because the rotrex's high rpm capabilities, it can run compressors with the same efficiencies as turbos. however, at the same boost levels and same piping and intercooler configurations the rotrex should make more power because the charge air temps should be lower. the Rotrex has a maximum operating oil temp of 180F, so compared to the exhaust side of the turbocharger there should be less heat bleeding over to the compressor side. with the rotrex there will be a few hp used to turn the blower, so the question is if the power lost in turning the blower greater or less than the power gained from having cooler charge temps. -More low and midrange torque ** this depends on the size of the compressor housing. the power on a smaller turbocharger may come much more dramatically at lower rpms, but may also run out of air on the top. but generally speaking the power of a supercharger will come in much more linearly than a supercharger. Turbo disadvantages: - A bit more complex project since it generates more heat which requires more heat insulation to prevent heat soak issues (wraps, turbo blankets, hi-temp coating ..etc) ** yeah...turbos run hot hot hot...protecting and managing against the additional heat is paramount - Possible lag and unpredictable power delivery (may not be the case for smaller turbo setups) -Transient response is somewhat delayed even with smaller turbos ** yes..the sc responds instantly Rotrex disadvantages: - Lacking the advantages of the turbo ( see above) - Possible belt issues (I think it's addressed on the newer kits though) ** this is more a possible kit developer related issue and not inherent to the Rotrex itself. on the KW kit, the sc belt drive is independent from the engine accesory belt, so even in the case of breakage, you can still drive the vehicle. |
| The Following User Says Thank You to gmsii For This Useful Post: | glamcem (03-20-2014) |
#39 | |
Living the dream
Drives: Fensport AVO Turbo GT86
http://www.fensport.co.uk/FensportCars/GT86_Race.aspx |
| The Following User Says Thank You to Pitman For This Useful Post: | ultra (03-21-2014) |
#40 | |
#41 | |
11 psi GT3076R 93 octane
#42 | |
With that torque curve? Saying superchargers are *more efficient* than turbochargers is stupid... Yes the IAT will be lower but that doesn't mean its more efficient in terms of a power adder. Its a trade off, either way. Yet another reason *not* to buy KW. |
| Transient ignition and knock count | brn12345 | Software Tuning | 19 | 06-11-2014 12:46 AM |
| Transient Ignition Retard Tables from RomRaider | Ralph Spoilsport | Issues | Warranty | Recalls / TSB | 31 | 05-24-2014 08:48 AM |
| Avo turbo heat management on track | ICantAffordAnLFA | Forced Induction | 18 | 09-09-2013 12:00 PM |
| MP3 management software for PC? | mit_peid | Electronics | Audio | NAV | Infotainment | 9 | 06-08-2013 09:14 AM |
| ROTREX SC Brainstorming | MANDALAY | Forced Induction | 61 | 12-11-2012 06:57 PM |
