#15 |
Crickets...
Drives: FR-S 10 Series
Hey Guys,
I've attached 2 pics of the exhaust. Everything seems to be running fine, but I think I need to take it to a shop or someone really experienced to fix a minor issue. The right side is vibrating while the left side is not, and as you can see from the attached pictures the left side sticks out more than the right. The guy that installed it for me was not very experienced and at first it was rattling and the positioning/alignment of the exhaust was much worse, took him a while to get it to where its at now. It no longer rattles and the car sounds/runs good, except the positioning is a little off and the vibration issue. Any suggestions on an affordable place that will be able to take a look at the positioning/alignment for me, and to see why the right side is vibrating after the engine has warmed up? Already spent $900 on the exhaust and $100 for the install, so I don't have much left to spend obviously, but if I could get this minor problem sorted out at an affordable price that would be awesome. Thanks guys! ![]()
Smile on every turn.
#16 |
JDM JUNKY
Drives: NSX
Auto innovations in milpitas
Next time don't go cheap on car stuff. Do it right, do it once. |
#17 | |
Coffee Snob
Drives: '14 SWP BRZ Limited
I think an easy solution is to bring it to Pit Row and throw it up on the lift and just fix it yourself.
#18 |
Coffee Snob
Also forgot to mention, it's a pretty common issue I've noticed - a lot of exhausts on the FR-S/BRZ do not line up properly. Try turning the short bent pipe after the axleback and before the midpipe. It's a matter of loosening the v band clamps and rotating it. Don't secure everything until you've aligned it the way you want. Trust me, it's not going to be perfect. I've had two different exhaust systems from two different brands, and they both didn't line up despite my best efforts. As for vibrations you might have something loose. Check to make sure all the little bits and pieces are tightened up. Where's the sound coming from?
#19 |
#20 |
Drives: Black 2013 BRZ Limited M/T
just like @leicaboss said just take it to pit row on lafayette, lift it and take a few minutes to line it up and make sure its even.
#21 |
Original 2013 Owner
Drives: 13 BRZ, Galaxy Blue Silica
I have a full Perrin headerback system. I can't comment on the vibrations you're seeing since you don't have a video up. In order to get the tips aligned, you need to loosen the two v-band clamps on the s-pipe, and rotate the s-pipe a bit until the tips align. The system is able to fit perfectly if you do it right.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα |
| NYC Exhaust Installation | dad&sonFRS | NY / NJ / CT / PA | 11 | 03-29-2014 06:00 AM |
| Exhaust Installation | congee | CANADA | 6 | 03-12-2014 02:00 PM |
| Coilover / Exhaust installation: 818 | KONVERTER | Southern California | 6 | 08-13-2013 05:51 AM |
| Nameless Exhaust Installation | Mach5 | Mid-Atlantic | 10 | 06-18-2013 10:40 PM |
| Exhaust Installation in Adelaide | yomchi1989 | AUSTRALIA | 2 | 12-06-2012 03:38 AM |
