Old 07-23-2014, 01:35 PM   #127
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Originally Posted by MokSpeed View Post
I buy my polo shirts from Target for $15 instead of buying the real deal at Lacoste for $80 a shirt. I guess that makes me a terrible person for promoting "knock offs" and I am hurting the industry.
Nah, you just just bad taste in clothing.
The Following User Says Thank You to Turbo95eg6 For This Useful Post:
AznKirby (07-23-2014)
Old 07-23-2014, 01:38 PM   #128
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
It's a proven quality brand and costs less with the same style.
MokSpeed is offline   Reply With Quote
Old 07-23-2014, 01:45 PM   #129
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Not sure why people get so worked up about wheels. My $.02:
If you can afford that set of BBS you've been looking at, get them. If not, check the used market, save up, or accept that you can't afford them. It's not like you have to pay $800/each for good looking, durable, lightweight wheels...
xxBrun0xx is offline   Reply With Quote
Old 07-23-2014, 01:49 PM   #130
Kotu100
Kotu100's Avatar
Drives: Supra, 2014 BRZ
If they made knockoff sa3r you best believe i woulda got those instead of the real thing.
Its still a cast wheel thats redonkulously overpriced.
If i can buy a knock off that does the same job as the "real" one just as well at the "real" one, why should i waste my hard earned money on markup?
Kotu100 is offline   Reply With Quote
The Following User Says Thank You to Kotu100 For This Useful Post:
MokSpeed (07-23-2014)
Old 07-23-2014, 02:03 PM   #131
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
Because then you won't get the street cred bro! Don't you want the respeckt of the scene?! You gotta look hella dope fresh ballin and you can't do that with fakes.
The Following 2 Users Say Thank You to MokSpeed For This Useful Post:
Rampage (07-24-2014), xxBrun0xx (07-23-2014)
Old 07-23-2014, 02:28 PM   #132
Kotu100
Kotu100's Avatar
As sad as that is it's soooo true.
I got more comments the 1st couple times I drove with the Advans then i ever did with the xxr's.
Unfortunately they wont fit the brz
Old 07-23-2014, 02:36 PM   #133
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
Because we have the "special" lug pattern now?
Old 07-23-2014, 02:41 PM   #134
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by AznKirby View Post
OEM > replica
Any day of the week. That being said, some companies, like BBS, make OEM wheels.
Millions of dollars in R&D is better than knock offs from Taiwan/China.
Counterpoint from personal experience. I've bent and cracked OEM wheels made by Enkei. I've tracked and drove on the street with Rota slipstreams for far more usage without a single bend.
No company or product is perfect, you can bend/crack/break anything.
I've run expensive wheels (BBS, SSR and Rays [all forged examples] - and some 5Zigen forged wheels I forgot about before) and plenty of cheap wheels. Some of the worse incidents have been some of the SSR wheels, some are great, some are complete shit. I've known multiple people who have bent their Rays and Desmond wheels and went back to cheap wheels afterwards.
I only run cheap wheels now myself (Enkei's, Kosei's, no Rota currently but I'd run them again on the track car and race car if I needed more wheels).
It comes down to what your goals are and how much you believe the internet hype that all of the "knock-off" brands are shit.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 4 Users Say Thank You to Dave-ROR For This Useful Post:
fstlane (07-24-2014), Manic (07-23-2014), Rampage (07-24-2014), wheelhaus (07-23-2014)
Old 07-23-2014, 11:31 PM   #135
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
Originally Posted by wheelhaus View Post
You're correct, ANY wheel can crack, dent, break, etc. There's loads of evidence that every possible iteration of wheel manufacturing is still susceptible to damage. No wheel is invincible. Some are more durable than others, but there's no guarantee a forged wheel is stronger than a cast wheel. To me more specific, forged is stronger metallurgically, so they can be made lighter and achieve the same strength. Being made lighter makes them weaker. So, forging ultimately nets you lighter weight and more propensity to bend instead of crack, but they can still crack. Cast wheels usually need to be made a bit thicker, and some wheels combine the two methods (e.g. cast spokes and roll-forge the barrel) to control costs and still get some lightness from the heaviest part of the wheel.
On the other hand, some ultra cheap aftermarket wheels are made to such garbage standards that they will be damaged more easily than the majority.
This is a blanket statement that isn't necessarily true in all cases. OEM wheels still break. Some aftermarket manufacturers are OEM manufacturers. Some aftermarket manufacturers (I'm not sure if they're required to) pass all the same safety tests that OEM's do.
Manufacturing processes can be copied as well, so just because product A comes from a big name and Product A1 comes from WTFBBQ, doesn't mean it's instantly garbage.
In many cases knockoff companies only care to make a quick buck and will copy any popular design and make it as cheaply as possible with the cheapest alloy possibly. THIS is where the problem is because now it's a real safety concern. (i.e. a thin-spoke forged design that's copied directly to a cast production, will most certainly not be as strong as it needs to be, but this is just one example).
I don't get it. When did I say any set of wheels were indestructible?
I can't say I care for the "authentic wheels bend too" argument.
That's not the point - of course everything breaks if you hit it hard enough.
With the same situation, a "replica" wheel would bend the same, or worse.
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 07-24-2014, 12:20 AM   #136
wheelhaus
wheelhaus's Avatar
I never quoted you as saying "indestructible" did I? No, it was only a statement, and it wasn't even directed toward you because it was a response to Nevermore's post.
I understand your faith in OEMs, but if OEM is always the best, why do we have recalls, lemon laws, and a multi-billion dollar industry of repair centers and garages mostly funded by people who never modify or work on their own cars?
Of course a replica will likely not be manufactured to higher standards than the original it copies, but the same standards, that is certainly possible. To say that "OEM > replica" is a biased statement, if the replica is made to the same standards then they are equal, unless one costs less. Again, I agree that many replicas or counterfeits are made improperly or with inferior alloys, but to say that is a comprehensive fact with all aftermarket wheels is hearsay.
Simply because a wheel is supplied to OEMs, does not mean its the pinnacle of wheel technology or wheel strength.
wheelhaus is offline   Reply With Quote
Old 07-24-2014, 12:35 AM   #137
AznKirby
Are you 20/20?
AznKirby's Avatar
In response to my post, you said:
" OEM wheels still break. "
2014 FR-S Monogram
IG: @MonKehC
Old 07-24-2014, 03:02 AM   #138
trd_kid
13anned.
trd_kid's Avatar
Drives: Firestorm FR-S
the way I see it is would I buy myself or a loved one a folex ?!? no so I'm not going to buy myself rota's,xxrs, etc there are other alternative options instead...
Originally Posted by Rocket.Brz
She was not and never was 13 years old during the prom thread.
trd_kid is offline   Reply With Quote
Old 07-24-2014, 03:50 AM   #139
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
Of course because that's the definition of a replica. I feel like most people who complain about "replica" wheels are trying to argue against counterfeit wheels because they don't know the definition of the word.
The Following User Says Thank You to MokSpeed For This Useful Post:
wheelhaus (07-24-2014)
Old 07-24-2014, 12:33 PM   #140
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
So true. So sad! Just like you gotta have Nike or iPhone to fit in.
"He can't be a man because he doesn't smoke the same cigarette as me."
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Search this Thread:
Advanced Search
FS: Modellista rear caps replicas aSaki Canada Classifieds 12 02-08-2014 01:50 AM
Vossen CV1 Replicas cncnjn Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-30-2013 11:48 PM
Gold BBS LM replicas (RIMS ONLY NO TIRES) Mr.Frs Wheels and Tires 12 08-06-2013 08:32 PM
Wheel Directory: ESM 004 18x8.0 +40 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 06-13-2013 03:43 PM
ESM 004s in 18x9 with Continental DW - (BBS LM Replicas) seven Wheels and Tires 2 02-24-2013 11:28 PM
