| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#57 |
Drives: 2014 Scion FR-S
#58 | |
Trust me, I'm the Doctor
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#59 |
http://www.wikihow.com/Hypermile
These are pretty basic tips but there are guys in stripped out 80's Civics and Geo Metros getting 50+ mpg without too much sacrifice. Standard sedans and such can usually achieve 30+ with just a change in style and some patience (i.e. drafting a truck at 55 mph, cruise control, coasting down hills). Personally it's a really interesting subset of enthusiasts, the name of the game is self control compared to forums like this where a lot of people try to outdo each other. http://ecomodder.com/ http://www.aerocivic.com/ Edit: Hell if someone is dedicated I wouldn't blink twice at a Toyobaru pulling 40+ mpg on a tank with some of the tips above and a forgiving route. |
| The Following User Says Thank You to strat61caster For This Useful Post: | DC2R (03-13-2014) |
#60 | |
Drives: 2014 Whiteout Monogram FR-S M/T
According to this thread, there is very minimal difference between 5th & 6th. Also, from my personal driving impressions the rpm only jumps like 1k down shifting into 5th from 6th. If my numbers are correct, the differences are % wise. 1st-2nd. 41.775% I think these are all wrong btw, lemme try one more time. 1st-2nd 52.808% 2nd-3rd. 31.845% 2nd-3rd 37.875% 3rd-4th. 28.7% 3rd-4th 33.611% 4th-5th. 28.7% 4th-5th 33.4895% 5th-6th. 18.373% 5th-6th 20.232% From these numbers ( My personal calculations ) 5th and 6th are the closest gears. Compared to a C7 the difference is 16% between 6th & 7th & 5th-6th 33% & 4th-5th 26%. So it seems to me that 6th in the FR-S is NOT an overdrive. But my #'s are not 100% reliable, feel free to prove me wrong. There is also this review of the C7 and they mention the massively high 7th gear spinning 1,600rpm @ 80mph is crazy. Say's it @ 8:20. And that's how they got 29mpg out of a 6.2L V-8 IMO. And why I drive everywhere in 6th. [ame="https://www.youtube.com/watch?v=RmfKDOOv1OA"]Corvette C7 Stingray Review - Everyday Driver - YouTube[/ame] Last edited by Pegasus; 03-13-2014 at 03:06 PM. Reason: Numbers were wrong |
#61 |
*facepalm*
Uh, you don't know much about how gear ratios are even listed, do you: Here's what the brz 6mt has: 1st: 3.626 2nd: 2.188 3rd: 1.541 4th: 1.213 5th: 1.000 6th: 0.767 Final Drive: 4.100 An aside: AFAIK, those ratios are the ratios between flywheel speed and the final drive ratio. You then take that speed, apply the FD and you then get your axle rotation. Apply equations for what that speed with a wheel of diameter matching that of your tires is, and you get your road speed. So, percentage listings between gears is actually useless. /aside That's actually quite a long gear for 6th if mapped out for rev range (y-axis) vs. speed (x-axis). See how it suddenly goes long for 6th, whereas 1st-5th progress steadily up, till 6th just nearly flattens out? That's your economy gear. Much like 5th gear in the WRX: http://www.ft86club.com/forums/showp...4&postcount=14
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ Last edited by SirBrass; 03-13-2014 at 03:42 PM. |
| The Following User Says Thank You to SirBrass For This Useful Post: | sshole (03-13-2014) |
#62 | |
Drives: Scion
Yes, you can use a top gear to get good mileage, but that's ONCE YOU GET TO CRUISING SPEED. They don't say to jump to top gear immediately and just floor it to get to that speed. |
| The Following User Says Thank You to PBM317 For This Useful Post: | SirBrass (03-13-2014) |
#63 |
Drives: 2013 FRS
This shits half the reason why car manufacturers don't make manual cars anymore. This dudes cruising 60 MPH in 4th.
Sent from my SGH-T999 using Tapatalk 2 |
| The Following User Says Thank You to Slash For This Useful Post: | DC2R (03-13-2014) |
#64 |
Edit: oops. Realized you were quoting a different poster. I just saw ratio numbers and assumed it was my post. My bad.
I apologize for not making that clear. I NEVER jump to 6th just for economy. That's dumb. You'll lug the engine or simply end up being too slow to accelerate for traffic. Maybe I should have called 6th 'cruising gear.' That's what I use it for AT CRUISING SPEEDS. What I was trying to disprove is the mistaken notion that in this car, 6th gear is a close ratio performance gear. It isn't. If you're in 6th for anything, you are almost guaranteed to need to downshift for anything if your revs in 6th when you need to pass are below 4k. Above that? Good luck. It's one reason why the top end feels weak at high speed: it's the gearing, not the power (well, not necessarily). Going FI will solve that issue, b/c FI LIKES longer gears in general. But NA at this power level, 6th is anemic, and is meant to be so. It is why this car can be peppy and get into it rev-wise, but still get good gas mileage: 6th gear at cruising speeds. Btw, cruising speeds is where you're just holding speed with light throttle at 55mph or higher. YMMV as positive elevation changes may force you into 5th for certain speeds.
#65 |
Drives: 2013 DGM BRZ
The sweet spot in our cars seems to be 45mph in 6th gear for fuel economy assuming you're not trying to accelerate more. If you're shifting into 6th at 35mph you're lugging the engine and will get worse fuel economy than were you in 5th while putting more wear on the engine.
If I could drive 45mph all day I'd be sitting around 40MPG! My current average in mixed driving usually sits around 32. |
| The Following User Says Thank You to Akari For This Useful Post: | Pegasus (03-13-2014) |
#66 |
I never shift to 6th at 45 mph. Maybe 5th gear if the road is flat and there's no traffic ahead, but not 6th gear. It's just too long, and if I lose any speed, it's impossible to get back if I'm geared to 6th.
45mph isn't even a cruising speed. It's a street speed. So is 50mph. (at least here it is)
#67 | |
#68 |
I'm saying that if I'm in 6th at 45 mph, and I lose speed due to traffic or whatnot, I must downshift. On the street this happens often enough that it's just not worth it, as I'd be constantly be shifting in and out of 6th. And if the street is empty enough that that's not an issue, then I'm going to be going about 10-15 mph faster than 45mph anyway.... in 6th gear.
#69 | |
| The Following User Says Thank You to Akari For This Useful Post: | SirBrass (03-13-2014) |
#70 |
The long roads of constant speed traffic I see are generally going varying speeds of between 60-80mph on the freeway. I'm in 6th gear for that anyway for cruise, and 5th for passing.
| Best cruising speed for highest MPG. | BrandonFYIA | Scion FR-S / Toyota 86 GT86 General Forum | 95 | 03-29-2015 11:53 PM |
| High rpm cruising in 6th | abutterman | Issues | Warranty | Recalls / TSB | 12 | 03-22-2013 08:38 AM |
| What your favorite cruising song? | speedy racer | Scion FR-S / Toyota 86 GT86 General Forum | 103 | 11-23-2012 03:07 AM |
| Fr-S w/ Evo X cruising in SoCal | NGabriel89 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 4 | 09-12-2012 07:19 PM |
| Cruising Range? | skoodge | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 05-25-2012 03:31 AM |
