Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 03-12-2014, 10:57 PM   #43
STV3
Señor Member
STV3's Avatar
Originally Posted by cjsporl1996 View Post
Ummm it turned out that nothing was wrong with my engine. In fact I'm boosting my engine this weekend😊
InbeforehelpIthinkIblewmymotorthread j/k j/k
STV3 is offline   Reply With Quote
Old 03-12-2014, 11:48 PM   #44
DC2R
Drives: 2014 Scion FR-S
I try to hyper mile when I can so I can have fun and not feel the burn.
I don't think I have ever lugged this engine. By lugging I mean high gear, low rpm, and engine hopping.
Will anything less than that cause harm?
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 03-13-2014, 12:02 AM   #45
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
I would prefer a taller gear ratio in this car. Mainly for cruising speeds on the highway. 6th helps yet I would prefer to be turning about 2500 RPMs at 80mph instead of 3200-3300 RPMs.
AVodka14 is offline   Reply With Quote
Old 03-13-2014, 12:25 AM   #46
DC2R
I would like a longer sixth gear. All else can stay the same
Old 03-13-2014, 12:56 AM   #47
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
Your car was "drinking antifreeze like kool aid" and blowing white smoke out the tailpipe, and nothing at all was wrong?
chrisl is offline   Reply With Quote
Old 03-13-2014, 10:00 AM   #48
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
What do you mean by "hyper mile"?
BRZfan is offline   Reply With Quote
Old 03-13-2014, 10:02 AM   #49
BRZfan
BRZfan's Avatar
Possibly a higher torque value at the higher speeds would be needed. Other more informed posters may have a more detailed explanation.
Old 03-13-2014, 10:13 AM   #50
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
No codes, they refilled the antifreeze. Smoke stopped and I'm not seeing anything out of the ordinary as of now. Maybe I was Trippin on acid jk jk.
cjsporl1996 is offline   Reply With Quote
Old 03-13-2014, 11:52 AM   #51
Pegasus
Drives: 2014 Whiteout Monogram FR-S M/T
Originally Posted by PBM317 View Post
^ this
You're flooring it in the top gear. This isn't some CVT. Still need to follow some sort of upward progression through the gears to get you up to speed, and then jump up to cruising gear.
Originally Posted by STV3 View Post
Yeah but flooring your car at 35mph in 6th gear is not good and is definitely not getting you good gas mileage.
I cruise around in 5th at 35mph and down shift to speed up or go up a hill
Originally Posted by BlueDubbinTDI View Post
this just seems fucking lazy
It can be bad for the engine to be spinning extremely slowly with a very high throttle setting (in other words, if you're climbing a hill doing 1300 in 6th while floored), but as long as you aren't flooring it all the time at low RPM in high gear, you should be fine.
Originally Posted by woode View Post
You are.
It sorta makes sense I suppose. I know that doing this in an older car would make it run pretty rich and give me bad mileage. But I would Imagine the computers would give me optimized fuel mixtures in a brand new engine. Nevertheless, I have only 157 miles on it so I probably havnt ruined anything yet. I have seen some break in manuals say top gear acceleration is desirable but I might be over doing it. I am debating keepin on keeping on and see what mpg numbers I get, then try the more traditional method and compare mpg. What type of issues should I expect with this type of driving?
I know right! I want an overdrive/mpg gear. I'm pretty sure that all 6 speeds on this car are for hard driving. As far as I know, if you are running around a track in the new C7 vette. You would never want to go into 7th because it's purely for mpg, 5th takes you to 200mph im pretty sure. I kinda wish we had a 7th overdrive gear too.
Pegasus is offline   Reply With Quote
The Following User Says Thank You to Pegasus For This Useful Post:
AVodka14 (03-13-2014)
Old 03-13-2014, 12:30 PM   #52
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Originally Posted by krayzie View Post
Actually that Accord wasn't bad at all if you ask me (imo it was the first good one, car of the year in Japan when it came out in 1985). It had really cool flip up headlights, double wishbone at all 4 corners, low driving position and the steering felt really good once it stiffened up at high speeds / corners. You were a lucky kid!
Nope. It wasn't that good. Anemic throttle response, it was beginning to fall apart despite religious preventative maintenance, driving position was the same as every other econobox, old stereo with blown speakers.
Hell, I was getting ready to drive my girlfriend home one evening, when I slid the selector into D4 white stopped, and *bang*! Drive axle broke. Car wouldn't move.
After I got my forester in 2005, I got a good comparison & I realized just how crappy the accord was. The thing has trouble just going up a normal incline.
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
^GT5 Replay Photo Mode^
Old 03-13-2014, 12:31 PM   #53
meeskee2
meeskee2's Avatar
Drives: World Rally Blue BRZ Limited, MT
I have always driven manuals (going on 16 years now) and I am no means an expert but I think it mostly comes down to personal preference. I will also add that I have always driven my cars a bit hard. The phrase “drive it like you stole it” has been used to describe my driving style. Haha With that said, I tend to only use 6th gear on the highway or at speeds above 55 mgh. If I’m cruising around 35-45mph I’m usually in 5th, sometimes 4th.
- World Rally Blue BRZ | Limited | Manual -
"Some guys think that having a better car makes them better than other guys, and those guys are right." -Top Gear
meeskee2 is offline   Reply With Quote
Old 03-13-2014, 12:36 PM   #54
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Oh that sucks must be the wear and tear mileage overtime. A friend of mine also had a drive axle break on him with an old '87 Accord. My gf in high school had an '89 Accord with low mileage and it was a real blast to drive (other than the really slow acceleration). I'm saying this even when I was driving my parents' new '96 Integra at the time (still very fond of the handling of this car).
I feel so bad for the younger kids that have to put up with crap like a Toyota Matrix (does that even come in a manual?).
krayzie is offline   Reply With Quote
Old 03-13-2014, 12:38 PM   #55
SirBrass
SirBrass's Avatar
Wrong, wrong, wrong. You are completely incorrect.
6th gear in this car is overly long. It is, in essence, your overdrive gear.
Look at any mapping of the stock gear ratios and you'll see a nice, even curve till 6th when the line for 6th dives down & out, really long.
If you want to know what a 6th great that's meant fire hard driving is like, drive an STi. One of the reasons it drinks gas is because ALL of its gears are very close ratio.
Old 03-13-2014, 12:56 PM   #56
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
You are a facepalm incarnate.
Dear jesus boy...
Thorpedo is offline   Reply With Quote
The Following 2 Users Say Thank You to Thorpedo For This Useful Post:
DC2R (03-13-2014), SirBrass (03-13-2014)
Best cruising speed for highest MPG. BrandonFYIA Scion FR-S / Toyota 86 GT86 General Forum 95 03-29-2015 11:53 PM
High rpm cruising in 6th abutterman Issues | Warranty | Recalls / TSB 12 03-22-2013 08:38 AM
What your favorite cruising song? speedy racer Scion FR-S / Toyota 86 GT86 General Forum 103 11-23-2012 03:07 AM
Fr-S w/ Evo X cruising in SoCal NGabriel89 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 09-12-2012 07:19 PM
Cruising Range? skoodge Scion FR-S / Toyota 86 GT86 General Forum 4 05-25-2012 03:31 AM
