#15 |
Drives: car
Just enjoy the stock tires while they last, they perform great up to a limit, and the limit is pretty high.
I've taken mine on road trips and DD on them and they're still in good shape: http://www.ft86club.com/forums/showp...&postcount=231 |
| The Following User Says Thank You to radroach For This Useful Post: | Chattanooga FR-S (03-12-2014) |
#16 |
Drives: RV-7
My local Americas Tire Co. gave me $400 credit for OEM takeoffs and there was another Bridgestone spiff in play then for another $100 for a total $500 credit toward a set of RE-11A's that I since sold and replaced with Michelin Pilot Super Sports that had another $75 spiff going, both sets 225/45-17 on stock rims. The math worked out so that it's only cost about $200 to play with two sets of max performance tires during the past year, well worth the experience and dramatic improvement they made to the car in both road and track conditions. Highly recommended, the stock tires are merely adequate in the dry, incompetent in the wet. Do it!
#17 | |
Time Traveller
#18 | |
humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Chattanooga FR-S (03-12-2014) |
#19 | |
Drives: RV-7
The RE-11A's have phenomenal dry grip when temps are +50°F, otherwise it's on tiptoes as the VSC gets active in Sport mode. And their stiff sidewalls and tread transmit every road imperfection into annoying jolts and shocks felt through the steering and seats. The PSS's are 4 lbs. per corner lighter so turn-in is noticeably improved, acceleration seems quicker and ride quality is relatively plush. Wet grip is in another league, very confidence inspiring. I only have 150 miles on them and need to test pressures, the rear is definitely loose compared to the RE-11A's. I've read that grip improves after 150 miles so we'll see. I think 28-30 psi might keep things planted better than 32 psi now, much how the RE-11A's responded. So I wouldn't call it a downgrade but I've yet to track the PSS's. I'll know better soon but for now call it a change for the better with the bonus of a 30,000 mile warranty. Check the reviews and ratings on both at tirerack.com and it's a coin toss unless you live where it rains. |
| The Following User Says Thank You to torqdork For This Useful Post: | DAEMANO (03-12-2014) |
#20 |
Drives: 2014 Ultramarine 6MT FR-S Monogram
When I bought my Monogram, I talked the dealer into swapping out the OEM Michelin Primacys for a set of Michelin Pilot Super Sports. All I had to do was pay a $65 labor charge for dismounting the old tires, and mounting and balancing the new tires.
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
| The Following User Says Thank You to CruiseZen For This Useful Post: | AznBRZer (03-12-2014) |
#21 | |
Drives: 16 CBS WRX Limited
#22 |
Drives: (formerly) 2013 Raven FR-S
I used the stock tires for 8000 miles and then upgraded to PSS's at a Discount/America Tire. They still gave me I think a little over $100 for the tires even with mileage on them. Learning the car on the stock tires was interesting, but it feels so much better on the PSS's. Of course, if you start off on sticky rubber, you wouldn't know the limits of the car before the swap.
#23 |
Drives: 2013 FRS / 2013 427 Vert
My originals are stacked in the garage used as "wets" when rain threatens to ruin the weekend.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
| Stay safe in snow 86ers. Don't go out with crap stock tires, only snow tires | stockysnail | Northwest | 36 | 12-19-2013 02:12 PM |
| Building your Credit? | Drifty86 | Off-Topic Lounge [WARNING: NO POLITICS] | 55 | 08-07-2013 12:20 AM |
| FS: Stock Wheels+Stock Tires+TPMS sensor | Pin Flare | Wheels and Tires | 1 | 03-26-2013 12:07 PM |
| Sonicelectronix.com credit | abutterman | Miscellaneous | 2 | 03-23-2013 06:28 PM |
| to those of you with good credit... | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 100 | 12-12-2012 02:01 AM |
