#15 |
Drives: Scion FRS 10 Series AVO Turbo
I'm using PurÖl elite 0w-20 on mine. Till this day I don't believe their enough clearance for anything thicker
| The Following 2 Users Say Thank You to DesertFrs For This Useful Post: | Calum (03-09-2014), MAPerformance (03-10-2014) |
#16 |
Boosted Member
Drives: 2013 SWP BRZ Limited
I'm sticking with ow-20 as well for street.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12 |
#18 |
in orbe terrum non visi
Drives: violent
Amsoil 5w30 dominator. Subaru recomends 5w30 for the turbo fa20dit.
#19 |
Drives: WRB BRZ, Monte Carlo SS
I think the best way to judge the best oil weight is to look at the blueprint of the engine. Someone must know the clearance. Although if they are using 5w30 on the new fa20 wrx that's probably the best way to go.
#20 |
Remember, even with FI, engine tolerances haven't changed. If your oil is properly cooled...
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#21 |
Drives: Hydra EMS Powered FRS Raven Black
We know that any high end synthetic is going to "lubricate" the engine surfaces properly but common sense should lead you to make some judgement calls on the OEM oil viscosity with OEM HP levels of 150 whp on my dyno compared to 400 whp on the same dyno.
The biggest concern in any engine is going to be the force from the piston and rod being exerted on the "oil wedge" between the rod, rod bearing, and the crank. So the force being exerted on that oil wedge at 150 whp is not the same as the force trying to squeeze that oil out of the bearing at 400 whp. So many don't understand the job of the crank and rod bearings is not to act as bearings but to maintain the oil wedge which is the actual bearing. Now track guys are seeing huge oil temps so oil pressure can drop significantly at these temps so cooling and increasing viscosity under these conditions is critical in maintaining high oil pressure so this "oil wedge" is maintained. Look at the boosted guys who have spun bearings and realize they didn't have enough oil pressure to maintain the wedge and that's why the bearings failed so take note of their oil weights. I'm on Redline 40w Race for racing and on a 10w40 for street as I know exactly how much oil pressure is required to keep from squeezing out the wedge on an STi motor. Problem is on the FA the rod bearings are narrower and therefore I know more pressure per square inch will be required than on our STi race engines. Synthetics flow so well these days at cold temps you would be surprised at how a higher viscosity can still work well for street where OEM/EPA fuel/emissions requirements are not your requirement. My 2c. Phil Grabow |
| The Following User Says Thank You to Element Tuning For This Useful Post: | diss7 (05-09-2014) |
#22 |
Junior
Drives: a car
#23 | |
Drives: FRS
#24 |
Junior
Drives: a car
Well, logically thinking after a certain level of power, the OEM oil won't be able to hold up to the increase of pressure and heat, requiring a thicker weight oil. Question is, which is best. No one would know until someone does a tear down of two engines at the same hp driven for the same miles using different oil.
#25 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#26 |
I can't see how a 10w40 in this engine is a good idea at all. I mean I run a 10w40 in my Chevy 350 that puts out 320 whp and 360 pounds of torque at the wheels. We need a engineer on this forum lol.
| The Following User Says Thank You to cjsporl1996 For This Useful Post: | lexusb3 (03-10-2014) |
#27 |
I Love custom Turbo kits
Drives: Limited BRZ
What worries me on this higher weight oil is that engine clearances don't change after you boost it like @CSG Mike said.
It worries me that heavy oil will not be able to make it inside the tight clearances under all conditions. The goal of oil is for it to be present between metal parts and prevent them from contact. The way I see oil is, the thinnest possible that will not break down at the intended use temperature. What benefit is there from running 10-XX from 0-XX when COLD? I see none. The advantage a XX-40 would have over an XX-20 is resistance to break down at higher temperatures which can be achieved with a good oil cooler keeping those temperatures in check. I would agree for extreme conditions, a 5-30 would be an acceptable choice. But why go higher than that if you have an oil cooler that will keep oil temps below 230 at the worst possible? I'm willing and open to reading/learning other people's knowledge on the subject.
#28 |
Junior
Drives: a car
would a 0w-40 be any different than a 5w-30?
| Tags |
| forced induction, oil, oil weight |
| going forced induction | ft86me | Forced Induction | 14 | 02-05-2014 09:23 AM |
| Forced induction for ATs? | Lokutus | Forced Induction | 10 | 02-26-2013 04:42 PM |
| NOS or Forced Induction? | v3rgil | AFRICA | 1 | 11-08-2012 08:17 AM |
| 6AT (+) Forced Induction | RYU | Forced Induction | 18 | 09-10-2012 12:14 AM |
| Forced Induction | Primo86 | Engine, Exhaust, Transmission | 11 | 05-29-2012 08:50 PM |
