#939 |
Drives: 2013 CBS BRZ
Since you guys are on the topic, how necessary is the oil cooler for just DD. I kno its a must for track but can i get away without for Highway and city driving?
#940 |
#941 |
Drives: 2013 Subaru BRZ AT JRSC
Another happy owner of the JR Supercharger here.
Installed this beauty on the last weekend, now I'm learning to drive again. ![]() I did some testing with Virtual Dyno, just to have some numbers to compare. It does confirm the increase both in power and torque, which I obviously can feel myself. Here are my graphs for stock BRZ and after supercharger installation: ![]() I found the graphs for the stock car are pretty close to reality - I've seen very similar results from a real DynoJet on the forums. After the upgrade I see the increase both for power and torque, but only for about 30%, which seems quite low (the numbers claimed by the manufacturer are 50% increase in HP and 45% in torque). Of course these are "virtual" numbers, and they may be way off. So I'd like to check with other owners. Anybody used VD with this kit? What "virtual" numbers do you get? What should I check to make sure I'm not losing power anywhere? I guess the first most obvious thing to check would be the air leaks on the way from intake to the engine. What else? |
| The Following User Says Thank You to alpax For This Useful Post: | voyager2285 (04-08-2021) |
#942 |
@alpax, are you using Canadian 94 octane gas? That could be one of the issue of power loss..
| The Following User Says Thank You to coolaron For This Useful Post: | CSG Mike (09-16-2014) |
#943 | |
I know the CARB tune is for 91, but it was mentioned it adjusts to the higher octane, and I thought 94 should not hurt. The manufacturer actually recommends 100 octane for track, but that's a different thing of course. |
#944 | |
That Guy
Drives: 2013 asphalt FRS MT
#945 |
Drives: 2015 Series.Blue BRZ
Is that 94 AKI or RON?
#946 |
#947 | |
Drives: lexus
#948 |
#949 |
I've noticed that now the car is a bit more sluggish at the lower RPMs. After a slow turn in a 2nd gear it doesn't move at all, and pressing the gas does almost nothing. I guess it's the added load of the supercharger, which needs power for its operation, and at the lower RPMs it doesn't yet give enough boost to counter that.
Do you guys see an impact at the low RPMs (around 2000)? |
#950 |
Mr. Cranky Pants
Drives: 2013 Argento FR-S
I doubt that it's parasitic drag from the supercharger causing it to stumble at low RPM. The supercharger will spin quite easily when it's not doing any work, just like an alternator spins freely when there's no load on it. The power soaked up by the supercharger will increase as the load on it increases.
At idle it will be nearly nothing, and at redline (peak boost) it will be a lot. |
#951 | |
That's just called 2000 RPMs. All cars are sluggish at that RPM. |
#952 | |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
