#5741 | |
[jay-kuh-meh-low]
Drives: 2016 FRS RS2.0 #293
Yeah, I'll just do this. Thanks. I don't need to be since I'm not in Cali. Then again, I don't like the uncatted smell...
IG: @appamatic
#5742 | |
Weight Weenie
Drives: 15 FR-S
They do stink There's no point in paying the extra money for a CARB legal supercharger when you can get the same JR kit with the "tune it yourself" option and save 1k https://jacksonracing.com/product/fr...harger-system/ |
#5743 |
Drives: 2018 Subaru BRZ
As I plan on getting this kit, I want to get some information as far as what mods are compatible-ish.
First off, going off from the CSG website, which JRSC kit is the one I'm supposed to get? I drive a 2018 Manual BRZ. I see a C30 and a C38, then there CARB tunes, tune it yourself, and factory tuned. Second, I have a full exhaust with JDL UEL Catted headers, and I quote "Built for Turbo and Boost applications with GESI High Performance EPA Compliant Cat" rated at 500HP with the new GESI Cat. Will this compatible with the JRSC? Third, Is it possible to tune with OFT? I would still be okay with getting ECUTek and working with CSG. Aside from an oil cooler, maybe flywheel depending on how pedal happy I get, what other supporting mods are recommended? Other than gauge pods and what not. I have read here and there that belts tend to snap, any recommendations on that? How rough is this on a stock suspension, adding more power, as far I can understand, can have effects on the behavior of the vehicle, I am planning on upgrading my suspension too, probably before thinking about pulling the trigger on a supercharger. I normally pump 93 fuel on the vehicle, I'm assuming is probably best to keep it that way, or is there a benefit to use 91? 85 is out of the question as Connecticut is very scarce, and 85 quality is very questionable. Thanks!
| The Following User Says Thank You to spcmafia For This Useful Post: | alphasaur (11-19-2021) |
#5744 | |
You need Ecutek to tune. The header is compatible with the JRSC, as long as you get the right tune. You will also need a MAP sensor. 93 only please. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | spcmafia (11-03-2021) |
#5745 | |
Thank you!. What is the difference between C30/C38?
#5746 |
#5747 | |
You're definitely right. I would just stick with the C30 in that case. I have no intentions of making a lot of power.
| The Following User Says Thank You to spcmafia For This Useful Post: | CSG Mike (11-03-2021) |
#5748 |
#5749 |
Drives: 2015 midnight blue limited edition.
Is this the end of my baby boxer :(
So I finally decided to give my 100k old boxer the JRSC +CSG tune treatment. I finally got around to installing it on Halloween, but couldn't get around to driving until Monday this week. I just had the first iteration of the map. Did a pull in third gear from 2.8k to around 6, and 'explored' around the 3.5k - 6k rpm range in 4th and 5th gear as and when the opportunity presented itself on the drive. Clearly, I was rather eager in my exploration and soon after the boxer started complaining with a rattling noise.
Man, the car had never felt this good before and then the next second, the sound of :brokenheart. After that I went straight home. Here is the video of it sitting in the driveway and reving up to 5k. So I have stopped driving it now. Plan is to drain the oil and get the possible glittery bits analyzed. I'm hoping against hope its just rod and the crank. Current spec: Stock engine/internals. JRSC C30 with engine oil cooler. Running pump gas only. CSG tune. Xcedy stage 1 clutch. Stock everything else. My goal was to put the least amount of stress possible and after having spoking to many wise people I thought this would work. Yet this happened..which is why this hurts so much... . Anyone here knows a reputable engine builder in Charlotte, NC area ? And if there is forged internals kit for FA20 please let me know. Trying to keep the cost to a maximum of 3k. So yeah IAG is out of the question at this price point. I knew this day would come....I'm just heart broken it happened on my second drive. And yes I know I shouldn't have driven that hard,may be... But here I am...asking for help.. Thanks and Cheers!! - Arun |
| The Following 2 Users Say Thank You to dynarun55 For This Useful Post: | alphasaur (11-19-2021), BrahmaBull1990 (11-25-2021) |
#5750 | |
Sent from my Pixel 3 using Tapatalk |
#5751 |
friendly
Drives: 17' 86
Ah man, that fucking blows. Hope you get it sorted! good luck! ~3k is going to be tough as that's near what used engines are going for.
Seek comfort in discomfort.
#5752 | |
Drives: WRB Brz / SR S14
However, speaking from experience with a current engine build (not FA, but EJ in my STi), for 3k you're far better off getting a used long block from a wrecker. All the parts required to rebuild this engine to OEM spec would be closer to 6k including labor. Anything that runs off oil pressure or has oil that flows through it in the engine will have to be replaced (oil pump, AVCS hardware etc) and definitely adds up at the end. Last edited by drew_kar; 11-22-2021 at 01:47 PM. |
#5753 | |
| The Following User Says Thank You to dynarun55 For This Useful Post: | alphasaur (11-22-2021) |
#5754 | |
Drives: 2015 FR-S
By the sound of your engine it sounds more like spun bearing/rod knock which is more of an oil starvation issue that all FA20s have an issue with. Did you have an oil pressure gauge? |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
