#5209 | |
Drives: White 2018 BRZ
#5210 |
pessimistic skeptic
Passed 30K miles with JRSC. Anybody else with more miles?
#5212 | |
pessimistic skeptic
Jackson Racing C30 Supercharger + JR factory tune STI OEM oil cooler PCV and crankcase oil catch can STI PCV Valve RKX recirculation valve (stiffer springs) AEM Dryflow air filter Fluidampr Crank Pulley Braille 21 battery 2017+ improved header HKS dual resonated front pipe HKS Hi-Power Spec-L catback |
#5213 |
#5214 | |
Drives: '14 BRZ Limited
HBP 1,000 cc injectors Nameless headerback JRDROC fluid dampr E-85 as much as I can, sometimes have to go back to 93 Delicious flexfuel tune I've put 10k miles on it since June, bought it used with alleged 5k miles. Tracked @ Sebring, PittRace, and Road Atlanta. BTW, the vibration issue I posted a while back was due to the cf driveshaft. I replaced it with a stock one and had no issues reaching 140 at Road Atlanta. The manufacturer is checking it to see if it's out of balance or if my drivetrain is too stiff for it. |
| The Following 4 Users Say Thank You to peaches For This Useful Post: |
#5215 |
Drives: frs
JR C30 kit, 91 octane standard tune, JR oil cooler and Rotrex cooler. No other engine/exhaust mods.
Its been on the car for 20k miles. Its my daily and occasional DE car. Only issue I've had with the kit was the supplied diverter valve which I replaced with the RK valve after the 2nd one failed. Its been exactly what I hoped for. Reliable and gave the car some ass. |
#5216 |
Drives: jrsc_brz
jr c30, no oil cooler, invidia n1--- installed 3/22/2016~15k-20k miles on the kit
262wheel /198ftlb car is dd, did one track day no problems, just changed the s/c air and fluid filters last year |
#5217 |
Drives: 2017 Subaru BRZ Limited
my '17 BRZ is back to bone stock. i'm still waiting on the JR comes out with CARB legal tune for the '17+ models. until then i will be on the sideline looking in LOL
#5218 |
Drives: 13 White MT FR-S
Hey guys, just got a kit used. I was wondering if one of you long term jrsc guys could give us the high points of this 373 page thread? TL;DR of sorts for the c30/c38 kits?
#5219 |
Drives: jrsc_brz
tl dr= forced induction does not make your car a time bomb. replace the kits air filter and inline oil filter every two years or 50k miles. oil cooler is A MUST if you track if you track more than once a year.
#5221 | |
pessimistic skeptic
Perrin Pulley Unichip Injen Intake Stabilus hood Props Your injane intake will be replaced. Perrin pullley does not do much more than looking good. A damper pulley would help better with FI. I don't know what is unichip. You will need either factory tune from JR or CSGMike can also help you with etune. Like HaXx wrote, getting an oil cooler is a very good idea if you will ever track the car, even once. If you install yourself or get it installed at a shop, pay attention to pipe/hose joints for boost and vacuum leaks. Also, the EVAP purge solenoid under the intake manifold is known to leak, clamp both ends of the hoses connected to that solenoid Since your kit is used, you will probably need the followings which are available from JR or CSG. - Rotrex sx150 traction fluid and filter - Accessory belt specific for JRSC - Air filter - Plastic Check valve connected to vacuum hose on the intake manifold (good idea to get a new one) - Recirculation valve (if too old) Also, I would replace the MAF sensor with a brand new one since your car is 2013. |
| The Following 2 Users Say Thank You to mrg666 For This Useful Post: | HaXx (12-19-2019), Milhouse86 (12-19-2019) |
#5222 | |||
I already have the kit installed, and the car is dedicated track car My Build thread I guess just looking for anything in the thread that needs to be pointed out after so many people have ran the kit for years now, like "tips and tricks" kinda info. I have a catch can, and everything is running great right now.
| The Following User Says Thank You to ML For This Useful Post: | HaXx (12-19-2019) |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
