#5027 | |
Now, once you add the supercharger to the mix, the supercharger is literally shoving more air into the engine, and it has to go somewhere. This extra flow, is what truly allows the Ace to shine. Even with stock cam timing profiles, if you tune on an Ace header + C38/C30 HBP + pump gas, if you swap on another header with just that ignition timing table, you'll knock before you can redline; the Ace just flows that much more and allows for more cam timing. Here's an example. ![]() JRSC C30 + Ace header + flex (E70)+ HBP
#5028 | |
pessimistic skeptic
#5029 | |
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | HachiRokuX (07-23-2019) |
#5030 |
Drives: Q5 + BRZ + M796
People blow built motors too at less power. Shit happens. I think JR is trying to suggest that the setup is clean for the stock block for practical applications for most people.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | HachiRokuX (07-23-2019) |
#5031 | |
#5032 |
I have been at 12.5-13psi (85mm pulley) on a Harrop SC and E85 for over 6 months with a conservative tune as well. I haven't blown anything. The Edelbrock kit comes with a pulley that is smaller than mine, and the Edelbrock kit comes with a warranty, so I am not surprised JR assured him all would be ok. Adding E85 makes more power, but decreases the risk of knock and keeps temps down, so it is more of a trade off, and it gives room for a conservative tune.
#5033 |
Drives: '14 BRZ Limited
So far my only regret is using 1,200 cc injectors, too much fuel when driving slow in the city. Other than that it drives great, seeing AFRs under 11.2 at full boost which is only reaching 10.7 PSI. Going to Daytona next week, we'll see what happens then.
| The Following 2 Users Say Thank You to peaches For This Useful Post: | HachiRokuX (07-24-2019), sroby (07-23-2019) |
#5034 | |
Drives: 2017 BRZ (Sold), 2023 GR86
All of my worries about not feeling enough power down low were put behind me after I finally installed the kit alongside my existing A350. It pulls hard from 3k and up, even at partial throttle! |
| The Following 3 Users Say Thank You to mistople For This Useful Post: |
#5035 | |
Injector size doesn't affect MPG on this car, as we have both DI and PI, and the DI is used under light throttle condition unless you have an unusual tune. |
#5036 | |
The other thing I was advised of but haven't experienced yet is that if I have to use pump gas (93) instead of E, the car will have a hard time starting because again, too much fuel and the timing on the injector can't be reduced further. If all this sounds like a bunch of crap, please let me know and I'll find a different tuner. I can take a log and look at the real numbers, the 11.2 was me just glancing at my gauge quickly while driving. I have a track day scheduled next week, if you don't think the car is safe to drive hard based on what I've said let me know. I can get a log once it stops raining. |
#5037 | |
However, street driven GTRs and such, all drive just fine on injectors larger than 1000. 2000cc injectors on street driven cars is not rare nowadays, with how much development there's been. If you're on ID's, then the injectors are already pre-measured to make the tuner's life super easy. Give your tuner the opportunity to make it right first. If they can't or won't, then Zach (CSG) can tune your car. |
#5038 | |
#5039 | |
Drives: brz 2017 hksv2
what do you repute a good afr for Supercharged car? catted or uncatted? thanks |
#5040 | |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
