#4481 |
Drives: 2015 Scion FR-S 1968 Camaro BB402
This thread is going cold...
How is everybody’s week going eh? Almost Friday... ________ ~refer to username~ |
| The Following User Says Thank You to idkwhatimdoing For This Useful Post: | weederr33 (05-03-2018) |
#4482 |
Drives: 14' Raven M/T - 02' is300
I want a JRSC... anyone regret this for their DD
#4483 |
Drives: frs
I've had the kit on my dd for the past 8k miles. No regrets and I enjoy the car everytime I'm behind the wheel.
| The Following User Says Thank You to amcp1 For This Useful Post: | Jackson Racing (05-17-2018) |
#4484 |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Jackson Racing (05-17-2018) |
#4485 |
Drives: 2013 FRS
My only regret was that I couldn’t/didn’t do it sooner.
2013 FRS - JRSC CARB
"Use all of the track" they say |
| The Following User Says Thank You to milanojess For This Useful Post: | Jackson Racing (05-17-2018) |
#4486 |
Drives: 2013 FRS
#4487 |
smh ya’ll can’t even say good mornin to a real 1
![]() ________ ~refer to username~ |
#4488 |
Drives: 2014 BRZ Limited
I just noticed that I have a nice little dent in my inlet pipe. I have seen others mention clearance issues between this pipe and the rotrex unit on this kit.
What are some possible solutions for this that others have tried and can I order a replacement for just that one dented pipe? ![]()
#4489 | |
#4490 |
Drives: 2017 Subaru BRZ Limited
Is C30 a better choice for me than C38 if I have no intention to upgrade the pulleys? However, I do have intention to use my tomei EL header with custom tune with the JRSC. Is it true that C30 has more power down low than C38? I just don’t want to spend the same amount of money ($100 difference or so) for a less capable/ older version supercharger.
#4491 | |
Just get the C38. You won’t regret it. ________ ~refer to username~ |
#4492 |
#4493 | |
You should probably think of it this way: two motors make the same power, but one motor has half the displacement and half the number of cylinders than the latter. Which one will be more reliable? An eight cylinder cranking 400 pounds at the flywheel will, generally, be working a lot less than a four cylinder making the same figures, under the same aspiration. The C38 has plenty of potential (most of the time the unit is under-spun) and I don’t think anyone on this forum has even hit the ceiling with one. ________ ~refer to username~ |
#4494 |
They make the same power. The Dyno's are nearly identical. Just get the C38, so if for any reason, in the future you want to upgrade.
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
