#3277 |
I'm running a Mishimoto PCV catch can. I change my oil every 4000 miles or so and I can pour maybe 1/8" worth of oil from the can at those intervals. No track days, just spirited on ramp and highway pulls. I don't have a can for the CCV breather side though as Mishimoto does not make one. However, when I run my finger inside the intake tract and throttle body opening, I don't seem to be getting a film of oil. Maybe heavily tracked cars would show otherwise. YMMV. |
| The Following User Says Thank You to dj2020 For This Useful Post: | HaloFRS (03-05-2016) |
#3278 | |
I'd recommend temperature over AFR, if you REALLY want a gauge, but you don't need gauges at all with the JRSC. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Bykov (03-05-2016) |
#3279 |
Stealth
Drives: Ultramarine FR-S
Got a p172 code today. The idle was all messed up. Read earlier about the MAF sensor being the culprit. Bought some crc cleaner and problem solved, runs like a champ so far.
#3280 |
Drives: BRZ, 2 WRXs, 818S, motorcycles, etc
Always inspect the MAF extension cable as well. I had the same thing, and it kept happening - turns out it was one of the wires coming out of the MAF extension harness. Replaced it, never had an issue since! :-)
| The Following User Says Thank You to axelthrasher For This Useful Post: | CSG Mike (03-08-2016) |
#3281 |
G20 Guru
I've been getting the same issue with the P0172 - Running too rich code and cannot figure what's causing this? Below is my set up, I've tried cleaning the MAF, the car will run ok for a few days and the problems/CEL will come back. Car will hesitate sometimes going at a constant speed. Coming to a stop or giving it a little throttle from a stop, the car will sometimes want to stall and does every now and then. My gas mileage has dropped to about 20 mpg and the back of my exhaust is covered in black soot. Some days the car will drive better and then a few days later, the problems will come back. I've brought this up to Mike at MotoEast and he's using my current tune on a few cars as a base map with no issues.
2014 - Auto JRSC - C30 kit with engine oil cooler Crawford AOS Omni MAP sensor ECUTEK - Motoeast
Slowmatic Drfiterz, from P to D in a heartbeat. |
#3282 | |
Drives: 2014 Monogram FR-S Whiteout
I feel like I have read about this issue more than once on the competitor thread but I do not remember the solution. How does the O-ring look for the MAF? I think swapping it out would be a great place to start. Then checking for leaks. |
#3283 | |
#3284 | |
G20 Guru
Also inspect the tubing on the MAF and intake side, looks fairly clean.
#3285 | |
Drives: 2014 Argento FRS
Not to hijack or stray, would switching to a Speed Density system such as the one utilized by Delicious completely eliminate the problem of the MAF getting dirty or not sealing properly? Sent from my iPhone using Tapatalk |
#3286 | |
G20 Guru
Only other thing I can think is maybe the 2nd O2 sensor is acting up, but it hasn't given me a CEL for the sensor yet.
#3287 |
G20 Guru
I was actually thinking about that too, or having Moto-East send me a SD tune.
#3288 |
The better question is, how do you prevent your MAF from getting dirty?
Answer: Catch can/AOS. |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#3289 |
Huge shout out to CSG Mike for working very hard with me and putting up with my PayPal nonsense and getting me the JRSC C38 with JROC! It has been an absolute pleasure to work with you and David as well as your ever-patient sales team. Looking forward to doing it again (except without all that PayPal nonsense) as you have earned my business for absolutely everything CSG carries! Btw, my refund from PayPal came through yesterday and my kit will be at my door tomorrow!
| The Following 5 Users Say Thank You to Bykov For This Useful Post: | *LongFella (03-10-2016), Binary_fission (03-09-2016), CounterSpace Garage (03-09-2016), kevin.nguyen (03-09-2016), ScionOfHorus (03-09-2016) |
#3290 |
Drives: Crystal Black BRZ(Sophia)
Lucky guy.
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
