86WORX
go_a_way1
Old 01-19-2016, 11:46 PM   #3207
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
Originally Posted by tracerit View Post
Not an owner but I'm now considering the JRSC against the edelbrock.
If I go with the non tune kit using an aftermarket tune but want to flash the carb tune later on (to pass emissions), is the carb tune available for free?
Also is the carb certificate a sticker, something stamped on or a document you would carry with you?
For those who installed themselves, would you say it's pretty straightforward and easy?
The CARB package is available for purchase if you decide to upgrade your TIY kit to a Factory Tuned system. We would need to know your EcuTek Dongle ID. The CARB EO decal is included.
-Oscar Jr.
Jackson Racing is offline   Reply With Quote
The Following User Says Thank You to Jackson Racing For This Useful Post:
tracerit (01-20-2016)
Old 01-20-2016, 10:06 AM   #3208
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
JR system with high boost pulley was installed last week, will share the details later but I did want to address one concern. The pipe to the throttle body runs very close to the top of the supercharger pulley and even with the smaller pulley I have some rubbing issues if the assembly slides back even 1/4 inch. I have tightened the straps down as tight as possible and used a thick sticky felt spacer on the pipe that passes by the radiator fill tube which pushes the assembly away from the pulley.
Any other ideas?
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 01-20-2016, 11:33 AM   #3209
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Any other ideas?
First make sure you have the pipes as far over towards the passenger side as possible. The curved pipe should be almost touching the alternator. Once you do that, if you still have less than 3mm of clearance, you may need to trim the coupler on the throttle body side. These are cut by hand and if it is a little on the long side, it will prevent fully sitting on the throttle body. Just don't go wild with it, cut about 1/4" at a time until you achieve the needed clearance. But DO NOT do this until you've made sure the alignment is correct on the MAF side.
Xero-Limit is offline   Reply With Quote
Old 01-20-2016, 02:01 PM   #3210
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Any other ideas?
In your photo, it's pretty clear that the hose is not pushed all the way onto the throttle body; it should touch the tabs that stick up off the TB inlet pipe. I had the same issue...
Sleepless is offline   Reply With Quote
Old 01-20-2016, 05:28 PM   #3211
Deep Six
Deep Six's Avatar
That's the first thing I saw as well and once it is seated properly on the TB the clearance is there. My concern is keeping it pushed all the way on. I may put another clamp on the TB end of the hose but it appears the spacer between the charge pipe and the radiator inlet is helping prevent the pipe from sliding back off the TB.
[SIGPIC][/SIGPIC]
Old 01-20-2016, 05:30 PM   #3212
Loosen ALL clamps between the throttle body and the 45 degree bend.
Wiggle things around a bit until its all positioned correctly. Then tighten everything.
Voila, zero issues, and perfect installation.
Deep Six (01-20-2016)
Old 01-20-2016, 05:34 PM   #3213
Binary_fission
Binary_fission's Avatar
Drives: FRS
I had issue where it would come off at high rpm, I'd buy an extra clamp and keep it in the car just in case as well as tape.
Sent from my SM-N910T using Tapatalk
Binary_fission is offline   Reply With Quote
Old 01-20-2016, 11:44 PM   #3214
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
I replaced the clamps. Sometimes they appear tight as possible but aren't and the hose pulls away over time.
Also, as @CSG Mike said, it helps to loosen the nearby clamps and reposition the hose, making sure there is no tension pulling on it from the TB. Then tighten...
The Following User Says Thank You to Sleepless For This Useful Post:
Binary_fission (01-21-2016)
Old 01-21-2016, 06:40 AM   #3215
SHWNBRZ
Drives: '08 MX5 6MT & '15 BRZ Premium 6MT
Hope you have enough material on the 45 degree silicone hose to work with. You should cut off the damaged area on the tubing as you shouldn't clamp past it. Just follow Moto/CSG Mike's tips and you should get a lot of clearance.
I had the same issue with mine before re-doing the piping. I ended up replacing the silicone tube as it got damaged...same with the hose clamp and pulley. I have about 3/8" clearance between the alternator-pipe-pulley now and have had zero issues over the past 700 miles or so.
SHWNBRZ is offline   Reply With Quote
The Following User Says Thank You to SHWNBRZ For This Useful Post:
JEFFSTYLE (02-21-2017)
Old 02-01-2016, 11:00 PM   #3216
Tomyum
Drives: GT86
I love how easy this kit can be installed and tuned without the need of visiting a garage, not to mention all the online support well done JR and everyone involved.
Tomyum is offline   Reply With Quote
Old 02-02-2016, 11:59 PM   #3217
Aaronimoe
Any instructions/DIY on how to install an AOS on our cars?
Aaronimoe is offline   Reply With Quote
Old 02-03-2016, 12:10 AM   #3218
Tomyum
Drives: GT86
Go to Crawford performance's website they should have instructions for their AOS BRZ there.
The Following User Says Thank You to Tomyum For This Useful Post:
Aaronimoe (02-03-2016)
Old 02-03-2016, 12:15 AM   #3219
Tomyum
Drives: GT86
I'll make it even easier for you.
http://www.crawfordperformance.com/w...-Version-1.pdf
Old 02-03-2016, 12:18 AM   #3220
Aaronimoe
Can you explain why our cars don't have a bottom outlet for oil? thanks for the link.
Search this Thread:
Advanced Search
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 01:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
