#281 |
Just a note: you definitely want to put the check valve between then intake manifold and the can. If not you'll have more potential for a boost leak.
These do the job great and cost all of $0.75 a piece. Even if you're not running a catch can you'll still want to put one in-line with the stock PCV (which leaks badly). |
#282 | |
![]() Precisely |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | *LongFella (04-04-2014), jamesm (04-04-2014) |
#283 | |
Drives: WRB JR BRZED
Sent from my Nexus 5 using Tapatalk |
#285 |
Drives: Asphalt FR-S
Ay recommended catch cans?
And Jezza spake unto them and proclaimed that he who shall be last, shall be sideways and smiling.
#286 |
driving smoother faster
Drives: Sold
#287 |
Isn't it better to have to empty because the oil that hits the catch can is contaminated oil? Or am I way off? (I honestly know very little about this)
#288 |
Drives: Sold
#289 |
Drives: 2013 Black FR-S
Since the PCV is connected to the Intake Manifold, isn't it of much less concern to have a catch can for it due to the boost pressure in the intake manifold inhibiting any gases or oil from coming up through the PCV hose while under boost.
I guess it is still useful if you want to prevent ANY oil from going into the cylinders under vacuum. |
| The Following User Says Thank You to sw20kosh For This Useful Post: | CSG Mike (04-07-2014) |
#290 | |
Drives: DAT Rally Blue BRZ
#291 |
#292 | |
#293 | |
Drives: 2014 Scion FR-S|Whiteout
No issues for me. I've got almost 3k miles since my install and they have all been worry free
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt |
| The Following User Says Thank You to *LongFella For This Useful Post: | sklimo (04-09-2014) |
#294 | |
Jackson Racing Supercharger Owners Thread
Correct. I never replaced or removed anything. I simply added the metal one that came with the kit to the location ensuring it is faced/positioned the right way. Your just removing the hose, cutting at the specific location, placing the metal PVC valve, making sure it blocks air from the correct side when blowing into it, and re-installing it...
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
