#2059 | |
Drives: 2013 Black FR-S
You are thinking "the needle is moving through the RPM range so FAST! Surely it wont just stop instantly". The reality is that when the RPM needle stops, it doesn't mean velocity of the crankshaft is 0, it means the acceleration of the crankshaft is 0 and velocity of the crankshaft is whatever it stops at. If the needle stops suddenly at 7,000 rpms, the crankshaft is spinning at 7,000 rpms. It cannot go any faster unless it has a force acting on it (ie combustion). Simply: A. Watching the needle sweep through the rpm range means the engine is accelerating (engine speed is changing) B. When you let off the gas, the needle will stop moving. This means the engine is not accelerating (engine speed is constant). C. needle will start to come back down. This means the engine is decelerating.
| The Following User Says Thank You to sw20kosh For This Useful Post: | 0351USMC (04-09-2015) |
#2060 | |
Drives: Subaru BRZ
2014 WRB BRZ
#2061 |
Regarding the figure skating analogy...
If we cut her in half while she's spinning, aren't we reducing her effective mass, consequently instantaneously reducing her moment of inertia and providing a means for increased RPM? |
#2062 | |
Now if the elephant is initially on the outer edge of the marry-go-round, and he now moves closer to the center, the marry-go-round will spin faster.
#2063 |
The thing people are getting confused by is that when you are comparing the:
RPM needle moving up the rpm range vs. Ball being thrown up into the air The RPM needle moving up the rpm range is a representation of acceleration. Acceleration can absolutely become 0 instantaneously. When the throttle plate shuts (when combustion stops) = acceleration becomes 0. Acceleration needs a force and when you take away that force acceleration becomes 0. This is why the needle stops moving instantaneously. Velocity stops increasing. You can use the ball analogy but you have to take gravity out of the equation. If you are standing in space and you throw a ball towards the moon. The moment it leaves your hand, acceleration becomes 0. This is exactly like taking your foot off the gas and watching the RPM needle stop moving. The velocity of the ball remains equal to the velocity it reached right as it left your hand. The RPM of the motor remains the RPM of the motor right as you let off the gas until other forces (friction) pull (decelerate) the RPMs down. If the ball in space traveling at a certain velocity now entered a cloud of space debris, friction would slow it down too and its velocity would decrease (ball would decelerate just like an engine would),
| The Following User Says Thank You to sw20kosh For This Useful Post: | Thorpedo (04-11-2015) |
#2064 | |
But what if the elephant is the same diameter as the merry-go-round? We're effectively changing the moment of inertia because mass is being removed where r>0, relative to the CoG... |
#2065 |
Drives: Subaru BRZ
Isn't acceleration the rate of change? Can an object with mass and inerta who's rate of acceleration is "pretty fast" (I'm so scientific and eloquent) become 0 instantly?
2014 WRB BRZ
#2066 |
Yep. Think of throwing a bowling ball down a lane. The ball is accelerating super fast while it is in your hand but once it leaves your hand it's acceleration is 0 and then starts to decelerate due to friction. If there was no friction it would maintain a constant velocity (no rate of change).
#2067 |
driving smoother faster
Drives: Sold
Let's derail this thread by writing something about Jackson Racing SC
| The Following 7 Users Say Thank You to dp1 For This Useful Post: | 0351USMC (04-09-2015), CSG Mike (04-08-2015), Dream20b (04-11-2015), drewbot (04-29-2015), HaloFRS (01-20-2016), PikachuBRZ (01-22-2023), Xero-Limit (04-08-2015) |
#2068 | |
Drives: 2013 FR-S Argento
| The Following User Says Thank You to bfrank1972 For This Useful Post: | 0351USMC (04-09-2015) |
#2070 |
Drives: 2013 BRZ Limited M/T
Someone send me the link to the thread that continues this conversation
#2071 |
Drives: 2014 FRS JRSC'd
Yeah I think we can end the whole side convo of the physics and mechanics of the engine as it relates to the seconds after you clutch in.
A tame rev limit is in order, so let's put the analogies to rest. |
| The Following User Says Thank You to 0351USMC For This Useful Post: | dp1 (04-09-2015) |
#2072 | ||
The thing I was most nervous about the install was the computer flashing. In the end that was the easiest part, took five minutes with no drama. Car starts, idles drives like stock except for the extra power. My mileage has not been affected more than 1-2 MPG at highway speeds over 70 MPH, other than that it is the same. The system is very quiet, which I like. There is some minor whooshing sounds from the blow of valve and a faint whine under hard acceleration. Most average people would not even notice the extra sounds. I did quite a bit of research and am very happy with my purchase. I would highly recommend this kit. I bought mine from CSG and both CSG and Jackson have been very helpful with all of my questions before and after the sale. ![]() Pat |
| The Following 6 Users Say Thank You to fasteddy For This Useful Post: | *LongFella (04-11-2015), 0351USMC (04-09-2015), CSG Mike (04-09-2015), dj2020 (04-09-2015), dp1 (04-09-2015), Jackson Racing (04-09-2015) |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
