#1793 |
Drives: 2014 Scion FR-S|Whiteout
There's some goodfellas on this thread.
I'll still be around 😉
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt |
| The Following 2 Users Say Thank You to *LongFella For This Useful Post: | 0351USMC (03-21-2015), ScionOfHorus (03-21-2015) |
#1794 | |
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
| The Following User Says Thank You to Jmonty For This Useful Post: | 0351USMC (03-22-2015) |
#1795 | |
Jackson Racing Supercharger Owners Thread
The next toy (aka "Daddy Car") is one of the pre-order launch edition 2015 VW Golf R. I got lucky and was able to get one of the first 500 launched in the US. It's a beast! It has a LOT of potential for some serious power. I have the same forum name on VWVortex and started a build thread there too. Maybe Jackson Racing can get into the VW market? hint hint wink wink 😉
| The Following 3 Users Say Thank You to *LongFella For This Useful Post: |
#1796 | |
Drives: 2014 FRS JRSC'd
| The Following User Says Thank You to 0351USMC For This Useful Post: | *LongFella (03-22-2015) |
#1797 |
So... Oscar Sr and Oscar Jr...
I've got a test car for you 😁 ...can't forget about Church! Want a go at it?
| The Following User Says Thank You to *LongFella For This Useful Post: | 0351USMC (03-22-2015) |
#1798 | |
@*LongFella see? Easy! |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | *LongFella (03-23-2015), 0351USMC (03-23-2015) |
#1799 | |
Drives: Hot Lava 86 MT
I am. But I am also planning to take them off over the weekend. My problem is that they lift the intake to a point where it lightly touches the hood padding and I just do not like it. From what I have read they add no value once you go FI.
JR Supercharger, JR RS Pulley, JR Oil cooler, JDL UEL header, Dual resonated 3" JDL Overpipe Front pipe, Perrin 3" resonated cat back exhaust, Upgraded Koyorad radiator, ECUTek tune, Enkei RS05RR 18x9.5, Bridgestone RE003 265/35/18, KW V3 Coilovers, Valenti sequential taillights, Kartboy short shifter kit
| The Following User Says Thank You to RevoG For This Useful Post: | Jmonty (03-23-2015) |
#1800 |
Does anyone have a definite answer on where to install two oil sensors? I have both the oil temp and oil pressure coming but want to know the best place to install them. Was thinking of putting the temp sensor on a sandwich and the pressure sensor on the block, but would like some guidance in this regard.
#1801 | |
Temp is already available on the car. |
#1802 |
Drives: 2013 Black FR-S
SHARTA uses the oil galley port or whatever it is called on the block.
#1803 | |
Drives: Asphalt Scion FR-S
http://www.ft86speedfactory.com/trd-...late-1740.html If you are using the Mocal thermostatic sandwich plate with spacer, this will replace the spacer and you can order a new shorter adapter screw to mount the oil take off plate to. I found oil temperature readings taken from the sandwich plate were higher than what the ECU reads, as ECU reads post-cooler.
#1804 | |
Thanks Mike, can I use the galley plug for the pressure sensor? I do not want to cut or make changes to the current oil cooler set up. Also, I'm running the Greddy Informeter and it does not show the oil temps. I know the car has this function through techstream but I could not get it to work on the Greddy. This is why I want to install on a sandwich just below the oil filter.
#1805 | ||
Drives: Subaru BRZ
2014 WRB BRZ
| The Following User Says Thank You to Xuningshen For This Useful Post: | CSG Mike (03-26-2015) |
#1806 |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
Random, should I spend $5k on the Jackson racer kit or $5k on improvements to my house that I just purchased 4 weeks ago? Hmmmmmmm. In terms of return on your investment it's a no brainer. House. In terms of pleasure the $5k would bring.. No brainer Jackson. While my goal was to buy a discounted used kit my wife did say that she wants free air miles and so a credit card is ideal for purchase. But then she will want a vacation out of it which means more $$. So that brings up another point. Live in the now or plan more for retitment. I could save all my life then due premature with all this money. These are the questions that haunt me each day. Fuck.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
| The Following 3 Users Say Thank You to Boofneenee For This Useful Post: |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
