#1779 | ||
Drives: 2013 Subaru BRZ AT JRSC
I do have HID lights, but they are stock, so probably shouldn't cause the same issue, or is there still a chance for that? |
#1780 |
This is an interesting new detail for me. Can the MAF rotation make a big difference? Maybe I should try that? How do you do it? The sensor housing/connector is held with two screws, so there is no play there. Do you rotate the sensor itself?
#1781 | |
PhoneFlash by EcuTeK
Sincerely, Zach Delicious Tuning |
| The Following 3 Users Say Thank You to DeliciousTuning For This Useful Post: |
#1782 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Infamous Performance (03-19-2015) |
#1783 |
The MAF should be pointed "straight up".
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: | alpax (03-19-2015), Infamous Performance (03-19-2015) |
#1784 |
Drives: 2015 Series.Blue BRZ
You rotate the entire section of tube the MAF sensor is located on.
| The Following 2 Users Say Thank You to ScionOfHorus For This Useful Post: | alpax (03-19-2015), Infamous Performance (03-19-2015) |
#1785 |
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
OEM units are "insulated/shielded" and do not emit RF interference like the aftermarket kits do. The OEM units are tested for this exact issue.
| The Following User Says Thank You to Infamous Performance For This Useful Post: |
#1786 |
You rotate the entire length of tube that the MAF housing resides on. The MAF sensor should be flat/parallel to the ground for optimum accuracy.
| The Following 2 Users Say Thank You to Infamous Performance For This Useful Post: | CSG Mike (03-19-2015) |
#1787 | |
Many, many of our customer use DDM Tuning HID kits. They are scary cheap and DDM is 2 exits down the road. Not saying the kits are anything special or even "good", but I had not seen this happen before. You learn something new every day and thought sharing might help others. We will have to meet up sometime sir. We are separated by far more traffic than miles. A meeting of the "Mikes". |
| The Following User Says Thank You to Infamous Performance For This Useful Post: | CSG Mike (03-19-2015) |
#1788 |
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
I thought I might ask if anyone is Crawford Billet Power Blocks with their JRSC kit?
#1789 |
From what I've read, they're not anywhere near as effective when you have FI.
| The Following User Says Thank You to ScionOfHorus For This Useful Post: | Jmonty (03-21-2015) |
#1790 |
#1791 |
Has to do with runner length not being really relevant with the amount of air being forced through.
#1792 |
Drives: 2014 FRS JRSC'd
Well since Im buying @*LongFella 's JRSC'd FRS I went thru and read the full 82 pages of this thread. Definitely learned a a lot and prevented a fair amount of Noob questions I would have ended up having. Looking forward to getting this ride and bringing it up North. Hwy 1 will be a fun drive from SoCal up here to the Bay Area.
| The Following 3 Users Say Thank You to 0351USMC For This Useful Post: |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
