Old 03-23-2014, 09:00 AM   #15
Muskokan
Drives: white Sport-tech
Only one winter on mine and I have this shit too.
Might mention it when I hit the dealer next time.
Muskokan is offline   Reply With Quote
Old 03-23-2014, 09:04 AM   #16
KPR10
KPR10's Avatar
Drives: 2013 Scion FRS - Asphalt
I have an appointment with my dealership next Saturday to have the service manager inspect this rust line on the window pillar post. I will post the results in this thread, but I expect them to be pretty resistant.
KPR10 is offline   Reply With Quote
Old 03-23-2014, 09:33 AM   #17
ZionsWrath
Thanks
ZionsWrath's Avatar
Hope they dont blame tinter cuttinv it with his blade.
Old 03-23-2014, 09:42 AM   #18
Burrcold
Drives: Subaru BRZ Limited
It's on the outside, why would a tinter be touching the exterior? Even if that happened, I can't imagine everyone here had a dumb tint person.
I think it's a design flaw, where the weather strip should have either been completely water tight, or allowed water to channel through. From looking at my own, there is a tiny gap that allows water to sit (fine for the rubber portion of the weather seal, but bad for the metal window splitter thing).
I'll be bringing mine to the dealer as well with this thread printed out.
Old 03-23-2014, 10:21 AM   #19
ZionsWrath
Thanks
ZionsWrath's Avatar
From what I've seen tinters measure and cut from the outside. Not sure if that's how it is supposed to be done or not I haven't seen that many tint jobs
Old 03-23-2014, 10:24 AM   #20
CruiseZen
CruiseZen's Avatar
Drives: 2014 Ultramarine 6MT FR-S Monogram
I feel sorry for you guys who are having to drive your car regularly in winter weather. I hate to see salt all over any of my vehicles. I remember well the toll salt took on my cars when I used to live farther north. Since you can't do much about the weather, I'd try cleaning this spot regularly with some detail spray to remove salt accumulation. A little spray wax after cleaning might also help add some additional protection to this area.
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
CruiseZen is offline   Reply With Quote
Old 03-23-2014, 01:43 PM   #21
cycleboy
Drives: 2013 Scion FR-S - Argento
I assumed at first this was just a snow area issue due to the salt.
But, I got intrigued and decided to go look at my car.
IT HAS RUST IN THESE AREAS! This is a So Cal car, just under a year old, and has probably seen rain less than a half dozen times in its life. Never been in snow at all. So we can rule out this issue coming from road salt. I do drive along the ocean daily, so there's some salt in the air. My guess from the photos I'll post below is that the hard rubber seal has a little bit of motion as the car moves and any grit that gets in that spot then causes the paint to rub through.
I'm concerned about this because as Rust-O-Leum says, rust never sleeps.
Driver's side as it looked without touching it.
Driver's side after I pushed the rubber seal down a bit.
Driver's side after I cleaned it with rubbing alcohol on a q-tip. Definitely a line of rust!
[IMG]https://farm8.staticflickr.com/7273/13357565234_395d140***.jpg[/IMG]
Passenger's side after cleaning.
cycleboy is offline   Reply With Quote
The Following 3 Users Say Thank You to cycleboy For This Useful Post:
Burrcold (03-23-2014), DAEMANO (05-25-2014), radroach (03-26-2014)
Old 03-24-2014, 09:10 AM   #22
KPR10
KPR10's Avatar
I'm surprised you are having the same problem down in So Cal. This rust problem is really surprising and not just a result of the winter road salt getting stuck in that area...
It looks like we will just have to routinely clean that area to ensure salt and moisture isn't trapped there. Hope this isn't going to be a big issue where the rust expands so that it becomes quite unsightly.
Any idea how much it would cost to replace the entire external metal pillar on the window?
Old 03-24-2014, 10:00 AM   #23
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Checked mine, both were rusting. replaced under warranty.
I will be keeping an eye on this in the future.
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 03-24-2014, 10:12 AM   #24
KPR10
KPR10's Avatar
That is good to hear, did the dealership give you any hassle when trying to get the metal pillars replaced? Did they agree to the warranty repair as part of the 3 year comprehensive?
Appreciate your feedback, this is the first I have heard about dealerships addressing this problem. I am seeing my dealership this Saturday and hopefully will get the same outcome.
Old 03-24-2014, 10:16 AM   #25
Deadspool
Much title. Wow.
Deadspool's Avatar
I didn't need to hassle them at all. Amazing dealership.
Every little problem ive had, has been addressed with out question. They even replaced my DI pump after I installed the FBM kit.
Any rust on these cars should be covered at any rate, I paid a little extra for their 6 year rust warranty. If it rusts, they fix.
Old 03-24-2014, 10:30 AM   #26
KPR10
KPR10's Avatar
Awesome, I paid for the extra rust protection and warranty as well, but I think it only applies to the body. I am not sure if these metal pillars would be considered part of the body or not? Either way, I hope my dealerships agrees to fix it as well.
Do you know if there were any issues with replacing these metal bars, or was it simple enough?
Thanks again for your feedback so far.
Old 03-24-2014, 10:36 AM   #27
Deadspool
Much title. Wow.
Deadspool's Avatar
Do you know if there were any issues with replacing these metal bars, or wa sit simple enough?
It took a little extra time, because the little triangle window is part of the trim.
I would 100% argue the trim being part of the body, your dealer should have no issues replacing them.
Old 03-24-2014, 02:39 PM   #28
microbionic
microbionic's Avatar
Drives: 2013 Subaru BRZ
Both mine had this issue, just stopped by the dealership, they will call me when they hear back from Subaru. .. I am at ~28,000 miles
microbionic is offline   Reply With Quote
Minor Plastidip on 86 lokvo Cosmetic Modification (Interior/Exterior/Lighting) 14 08-14-2013 04:36 PM
minor scratches..... jazztennor Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 10 02-06-2013 01:01 AM
First Minor Problem jpit BRZ First-Gen (2012+) -- General Topics 3 08-17-2012 10:38 AM
Three minor improvments FRSowner Scion FR-S / Toyota 86 GT86 General Forum 24 08-07-2012 12:39 PM
minor, but.... pr086 Scion FR-S / Toyota 86 GT86 General Forum 6 07-17-2012 12:35 AM
