Old 07-15-2018, 09:32 PM   #113
Jasonb
Drives: 17 Series Yellow BRZ
Didn't read through this entire thread, but has anyone used spacers with the 2017-2018 BRZ with the performance package wheels? Do 15 and 20mm spacers work on these cars with these wheels?
Jasonb is offline   Reply With Quote
Old 08-12-2018, 03:20 AM   #114
jflogerzi
jflogerzi's Avatar
If they don't have pockets like the old stock wheels, my guess yes but in the back I would get some longer aftermarket studs...
2013 Series 10 FRS #553
Old 09-13-2018, 10:53 AM   #115
qcbaker
Shitpost Generator v8.6
qcbaker's Avatar
I am planning on running a 20f/25r setup. I am planning on getting the Eibach spacers from ft86speedfactory. Will these work with the stock wheels on my '13 fr-s?
Front: http://www.ft86speedfactory.com/eiba...cers-20mm.html
Rear: http://www.ft86speedfactory.com/eiba...acer-1126.html
qcbaker is offline   Reply With Quote
Old 09-13-2018, 11:23 AM   #116
Icecreamtruk
Drives: Track preped NA FRS
Yes they will. 25mm will completely hide the stud and 20mm will leave a little bit of stud poke out, but the oem wheels have wholes on those areas and will fit. I ran my FRS during winter time on stock wheels and 15mm/20mm spacers and they fit no problem.
The Following 2 Users Say Thank You to Icecreamtruk For This Useful Post:
Leonardo (09-13-2018), qcbaker (09-13-2018)
Old 10-24-2018, 05:02 PM   #117
drunkninja13
Drives: Scion FRS
Do you have to cut studs with 20mm spacers or will they fit fine without sticking through the spacer? I have 25mm in the back now
drunkninja13 is offline   Reply With Quote
Old 10-24-2018, 05:15 PM   #118
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Welcome to the forum!
Yes you will have to cut them, unless your wheels have holes or "pockets" for the studs to stick into. For stock wheels, just go with 25mm front and 30mm rear spacers. Then they will just bolt on.
I used a hacksaw to cut 10 studs. It took a solid hour of hacksawing. It's not on my list of things to do again!
I'm on my 5th set of spacers...
Good Luck!
I LIKE TIRES!
Old 04-23-2019, 01:58 PM   #119
NSBRZ
Drives: 2017 BRZ
Originally Posted by Aipex8 View Post
Don't think I've seen any 2017+ wheels in this thread. Here are mine with 20mm front/25mm rear, lowered on TRD springs, no other suspension mods:
Hey @Aipex8 Did the 20mm hit the oem wheels did you need to trim lugs? what brand were they?
NSBRZ is offline   Reply With Quote
Old 04-24-2019, 12:49 PM   #120
Aipex8
Drives: 2017 Toyota 86 860 Special Edition
There's enough of a cavity on the backside of the OEM wheels that you can use them with 20mm without any trimming. I used Eibach spacers.
Aipex8 is offline   Reply With Quote
Old 06-18-2019, 03:53 PM   #121
Jonboy73
Jonboy73's Avatar
Drives: Toyota GT86 GTS
For people who have fitted 15mm on the front (OEM wheels with standard suspension) did you have to trim the stock studs or did they bolt on with no issues.
Jonboy73 is offline   Reply With Quote
Old 06-19-2019, 09:57 AM   #122
xenarc
xenarc's Avatar
Drives: 2017 SUBARU BRZ
@Jonboy73, 15mm spacers are too thin. I had them before. Go with 20mm-25mm to be safe.
The OEM wheels have deep pockets and I can see a 15mm working. Here is a pic of them.
"My teacher tells me real beauty is on the inside." "That's just something ugly people say."
xenarc is offline   Reply With Quote
Old 06-19-2019, 01:13 PM   #123
Jonboy73
Jonboy73's Avatar
So will 15mm work with the OEM 17" wheels or are they too thin ?? The first part of the answer contradicts the second reply????? For me 20mm brings the wheels out too far on the front hence the need for 15mm.
Old 06-19-2019, 01:21 PM   #124
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
If they have pockets on the mounting face, then yes.
Edit: Going back one page in this tread, shows pockets. http://www.ft86club.com/forums/showp...&postcount=112
BigTuna is offline   Reply With Quote
Old 06-19-2019, 02:43 PM   #125
BcRuZn
Drives: 2017 Brz Series Yellow
I have 20f 25r
I would have probably preferred 15/20 but my spacers came as a set so I went with these..
BcRuZn is offline   Reply With Quote
The Following User Says Thank You to BcRuZn For This Useful Post:
steel86gt (06-19-2019)
Old 06-19-2019, 03:10 PM   #126
Jonboy73
Jonboy73's Avatar
Thanks for the confirmation. Much appreciated
Best springs+spacers for stock wheels? retrosmiths Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 09-22-2015 09:52 AM
Spacers on all 4 corners / stock wheels (20mm/25mm) zoltiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-14-2015 12:43 PM
Spacers and stock wheel studs solidONE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-31-2013 09:55 AM
Stock Wheels Need Spacers? theom Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-17-2013 12:49 PM
Spacers with Stock Wheels Starscream15 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-05-2012 02:31 PM
