86WORX
Old 03-04-2014, 02:09 AM   #43
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
Why BBK for front only
Man, I still have a lot to learn I guess.
I was always taught that a tighter suspension can help keep the back end from "pulling up" since the fronts compress less. This helps keep better contact/friction with the ground, making rear brakes more effective.
I was also taught that friction produces more heat with more pressure than it does with greater lengths of time if the difference is only a few hundred feet.
I guess I need to recalibrate my thinking a little someday I will get this stuff down.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
The Following User Says Thank You to enwave For This Useful Post:
yomny (03-04-2014)
Old 03-04-2014, 03:36 AM   #44
mfbmike
Drives: 2013 FRS, 2008 R32
Originally Posted by mrk1 View Post
Actually dragging your brakes for longer is worse then a quick harder burst.
Can't stress this enough.
Get on em hard, and get off.
mfbmike is offline   Reply With Quote
Old 03-04-2014, 08:28 AM   #45
wparsons
wparsons's Avatar
It all depends on forces involved, but the only thing missing from looking at it this way is time between braking applications.
Braking harder for shorter might build a bit more heat at that time, but gives the brakes more time to cool before you're on them again.
You're probably dead right for a single stop, but over the course of a lap you'll see that being too light on the brakes will actually hold more heat.
One thing being a better driver WILL do is maximize corner exit speeds, so you'll be scrubbing more speed off for the next turn.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
enwave (03-04-2014)
Old 03-04-2014, 12:31 PM   #46
There's a lot of bad information on the internet... remember, this is all just physics and chemistry
Old 03-04-2014, 12:32 PM   #47
That's generally correct, but it depends on the corner and the car. In the case of the FRS/BRZ, because we're so low on power, this isn't always the case...
Old 03-04-2014, 03:08 PM   #48
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Or technically, on soft, then add force to threshold, then ease off
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
ajc209 (06-19-2015), mfbmike (03-04-2014)
Search this Thread:
Advanced Search
FRS ChargeSpeed & BRZ STi style Front Lip / Side Skirt Extensions JonMotoring Exterior Parts - The Rest 480 01-05-2016 04:51 PM
WTB: BRZ PS headlight, hood, front wide fenders, front bumper/ body kit Guildjs Want-To-Buy Requests 5 10-31-2013 09:35 PM
Stock Front Seats (Front/Driver/Pick up only) For Sale Sehwan Kim Interior Parts (Incl. Lighting) 2 10-24-2013 01:09 PM
Wtb brz headlights and a white front frs front bumper post to Australia. jet86 Want-To-Buy Requests 0 08-20-2013 09:27 AM
Perrin Front Front LCA Bushes Zero Offset SOLD Captain Snooze Australia Classifieds 0 05-05-2013 05:14 AM
