| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#29 |
Drives: 2010 MS3
The only downside I have with my BRZ is that too many random people give me thumbs ups.
Weirdos. |
#30 | ||
Trust me, I'm the Doctor
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#31 |
Drives: 16 CBS WRX Limited
#32 |
FR-S's have the same issue, of course.
I think it has something to do with Subaru using "green" processes... Like using better-based paint is more harmful for the environment *cue eyeroll* I sometimes think SOA tries to cater to the hippies waaaaaaaay too much.
#33 | |
| The Following User Says Thank You to AznBRZer For This Useful Post: | SirBrass (03-03-2014) |
#34 |
Drives: UM86 - 6MT
LOL, laziest reason ever... That basically reminds me of those type of people that go to the gym to lift weights, yet can't re-rack the weights that they moved themselves in the first place. The irony.
#35 |
Drives: '13 SWP BRZ-L
Keep your M3, and get a vintage car. Plenty there to keep your hands greasy.
240Z, Celica, 510, 911, MG, Triumph, etc. Pick your poison.
#36 | |
Drives: 2013 BRZ Limited AT
It wasn't always like this. But hey, that's the price you pay for wanting a super light sports car. |
#37 |
What color was your STI? The white paints have always stood up better b/c of the need to put more layers on with that color, thus resulting in a stronger coat of paint.
#38 |
Drives: RX-7 / BRZ
Adding more coats of b/c doesn't make for a stronger paint job. The reason the paint is so thin or "poor" as described is simply due to a minimum being applied from the factory. Less paint per car = less cost to the manufacturer per single car. Relativly thin clear coat plus a cheap product being used is the result of the durability issues. When I relate cheap with clear coat I'm not saying it is poss poor but, not the best. For instance a very common clear coat for manufacturers to use PPG
s Global line which is their high performance line, by no means cheap paint with a gallon of standard clear running usally in the high $470 range, mean while a high-solids clear from the same paint line funs $660-$800 a gallon. |
#39 | |
Drives: 2013 SSM BRZ Limited 6MT
#40 | |
Drives: 2014 BRZ Limited
PDF service manuals are here:
http://www.ft86club.com/forums/showthread.php?t=8374 An ISO of the electronic service manual is here: http://www.ft86club.com/forums/showthread.php?t=35279 You have to either burn that ISO to a CD or load it as a drive and use Internet Explorer to access it. It's not as good as some other FSMs I have used, but the exploded views have been very helpful in seeing how parts come off. Except for those spark plugs. I had heard about the spark plug change and was curious, so I looked at the engine maintenance manual to see if it was really as crazy as people were saying. In the 16 pages of instructions, I noted that you have to remove the header and part of the exhaust, remove the fuel injector ECM, remove the ignition coils and buy a specially designed engine hanger (Subaru part #99099AJ000) to lift the engine. Plus, with having to raise and lower the vehicle with the engine lifted to be able to get to everything, I don't know how you would do it without a hydraulic lift. I can't imagine raising and lowering that thing with a floor jack while the engine is banging all around against all the other stuff you disconnected. When the time comes, I'm not even going to attempt it. But at least the oil filter is easy to change. Quote:
LOL. It is a damned fine looking car and draws a lot more attention than I was expecting. |
#41 |
Look at Miata also
If you enjoy modifying and working on your car, you owe it to yourself to also look at a Miata. The two cars have exactly the same feel while driving or during an autocross, but the Miata has far more paths for extensive modification (up to and including a corvette V8).
I just sold my 1999 supercharged Miata and bought a BRZ Limited, but my wife still has a 2004 turbocharged Mazdaspeed MX-5. We swap cars and get the best of both worlds. Miata is due for a major revamp in 2015 if you can wait that long. In my experience, you'll be equally happy with either one. |
#42 | |
NASA SpecE30 Racer
1. Yes. Expensive is relative, but they are considerably cheaper than M3 parts. 2. I am sure the service manuals are available for purchase. I have a couple versions in electronic form. I am not sure why you weren't able to find one for the M3 3. The downside of the boxer motor is anything having to do with the heads since they are so close to the frame rails. It makes spark plug and coil changes more difficult and the engine needs to be removed to pull the heads, but everything else is easier than your more traditional engine formats. 4. I believe the engine is reliable, but if you have fallen for the "sky is falling" approach over the S65 rod bearings, then you probably won't agree. I have a thread that has compiled the blown forced induction motors. Generally tuning is the cause. 5. You don't need to go internal on these motors. They are knock limited, but you can easily run over 300 whp and 250 ft/lbs and run low 13s or high 12s in the 1/4 mile on a stock 12.5:1 compression FA20 on 93 octane fuel. You can go much higher on power and torque with E85. 6. I can't think of any real negatives. I sold mine to get back in an E92 M3 though.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | SirBrass (03-27-2014) |
