#57 |
much slow
Drives: 13 Raven FRS, 05 Rio Yellow S2000
There are pictures on the first page, I would rub on hard turns. I'm running 245s again since 255 is a little too much rubber for 200hp. You will be limited on front camber with stock struts with lowering springs since the tire is very close to touching the spring perch
#58 | |
Drives: 2016 Scion FRS
| The Following User Says Thank You to 86ish For This Useful Post: | BAMF86 (10-12-2015) |
#59 |
Drives: FRS innovate supercharged
Bought a set of 4 of 17x9 et38 with 245/40/17 tires
My local shop tells me with the stock shock they think it will rub, and wouldn't even mount them to the rims. Do y'all think they are being too cautious? Or do you think it would rub. After reading I've the thread it looks like most are running similar set ups! So I was unsure. Thanks in advance |
#60 | |
Drives: 2015 WRB Limited BRZ
| The Following User Says Thank You to Legionsk88 For This Useful Post: | Jeremiahlee34 (05-16-2016) |
#61 |
#62 |
#63 |
They fit!!
I found a shop that mounted them and I was prepared to get some spacers but they put one on the car for the hell of it to see how bad it would rub and they actually fit perfectly! Can't even fit a finger between the rim and shock but it doesn't rub at all. And I put it through the paces today sliding sideways and over bumps, with no rubbing. Very surprised but thankful! These are 17x9 et38 with 245/40/17 tires ![]() ![]() ![]() ![]() ![]()
#64 | |
Drives: 2012 BRZ....finally
For a pure sports car, it must be internal combustion-Mazda Motor Corporation’s sports car chief Nobuhiro Yamamoto
#65 |
#66 |
Lol no worries, I liked the colour combo of gold wheels on black, stoked for you the they cleared!
#67 | |
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Looks MEGA! Wonder how they'd look on my white one ![]() I'd dig these in black/a dark grey for mine!
I like driving!
#68 |
Drives: gt86
#69 |
Drives: 2016 Series.HyperBlue BRZ
Hey all, Just got mine in.
Like an idiot I didn't order Lugs. I also have the weight at ~19.4. I had to hold the wheel with a pinky so i'm sure the weight was affected a touch. ![]() Thanks Last edited by PlaidCat; 03-11-2017 at 11:39 AM. Reason: adding photo |
| The Following User Says Thank You to PlaidCat For This Useful Post: | Aaronimoe (04-23-2017) |
#70 |
Drives: 2016 Oceanic Blue MT Scion FRS
Picking these same wheels up 17x9 +40. Can any of the owners care to share what size hub centric rings are needed?
| Wheel Directory: Gram Lights 57DR 17x9.0 +38 | mr. slim | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 179 | 12-07-2021 08:07 PM |
| Wheel Directory: Gram Lights 57Xtremes 18x8.5 +45/18x9.5 +40 | WorkoArt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 02-18-2017 07:46 PM |
| Wheel Directory: Gram Lights 57Getter 19x8.5 +35 | adprokid | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 26 | 08-20-2015 12:44 PM |
| Wheel Directory: Gram Lights 57Xtreme 19x9.5 +43 | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 31 | 12-04-2014 11:56 PM |
| Wheel Directory: Gram Lights 57Xtreme 19x8.5 +43 / 19x9.5 +45 | 86 FRS | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 35 | 05-19-2014 01:28 AM |
