#15 | |
![]() How are you liking that monogram .. ?? Have you attempted to adjust the clutch .. ?? If you have, I'd suggest you put it back to its factory settings. If you haven't I'd suggest you leave it alone. If your clutch is dangerously low on free play, when you are in gear and the clutch is all the way "up", the engine will rev up but the car won't go anywhere .... ![]() Back in the day, when the clutch pedal was "linked" to the clutch fork, one would want at least 1" of free play at the top. Hey, have a great weekend! humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Porsche (02-22-2014) |
#16 |
Drives: 2014 Monogram FR-S White MT
no, i haven't adjusted the clutch. i was going to until i read through the whole thread and saw the potential problems.
the clutch is engaging the flywheel after letting go of the clutch pedal. that's not my concern. my concern is that it is putting unneeded wear on the clutch bearing. |
#17 | |
![]() What road trips do you have planned for this summer .... ![]() humfrz |
#18 |
Drives: old
#19 |
nothing planned as of yet.
but i'm hoping to get some track time in. |
| The Following User Says Thank You to subiestyle For This Useful Post: | humfrz (02-23-2014) |
#20 |
#21 | |
Regular Guy
Drives: '13 FRS '97 Jeep Cherokee
Go out to your car and open the hood. Familiarize yourself with what all you see there. That is how you learn. Not by being lazy and asking someone else to take a picture for you. Sent from somewhere. |
| The Following User Says Thank You to AirborneDeth For This Useful Post: | Ozzman (02-23-2014) |
#22 |
whats with the snobby attitude?
if the question is beneath you just move on. |
#23 | |
Regular Guy
Actually looking, touching, and moving is how many of us learned what is what on/in a car. Maybe you opening the hood yourself is beneath you?
#24 |
Hi subiestyle,
One can take a picture of the clutch pedal and the master cylinder and fluid reservoir but the rest is pretty well hidden and takes dissembly to see the various parts. Basically, the way it works is that when you punch on the clutch pedal it pushes a rod into the master cylinder and fluid is pushed through lines and actuates the slave cylinder which is hooked to a lever that grabs the throw out bearing which puts pressure on the fingers of the pressure plate which forces it away and allows the clutch disk to run free (not smashed up against the flywheel) which is bolted to the crankshaft of the engine ........ or something like that. Maybe these diagrams will get you orientated. humfrz |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | AirborneDeth (02-23-2014), tbertran (02-24-2014) |
#25 | |
Drives: Black Panda BRZ
#26 |
Just drive it
Drives: 13' FR-S
I had some time to read over the owner's manual and there is free play in clutch. Can't remember the exact number though.
#27 | |
Drives: 2013 BRZ Ltd. MT
Every new car I've owned for many decades has typically spec'd 1/2" to 5/8" free play at the top of the pedal stroke. At the bottom of the clutch pedal stroke, it is important that the clutch be fully disengaged. The range of safe pedal "ride height" adjustment may not be as large as some think. Improperly adjusting the clutch pedal "ride height" may result in transmission/clutch problems if the above requirements are not met. |
| Plug N Play Super Bright LED Kits @ JWM- FREE SHIPPING! | JWMotoring | Interior Parts (Incl. Lighting) | 166 | 03-23-2014 09:08 PM |
| ACT Clutch Kits + Flywheels SCION FR-S & BRZ 2013 In Stock - FREE SHIPPING | Import Dynamics | Transmission and Driveline | 40 | 09-25-2013 07:54 PM |
| FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! | Sportsguy83 | Engine, Exhaust, Bolt-Ons | 10 | 08-30-2013 11:53 AM |
| ACT & CLUTCH MASTER IN STOCK & READY TO SHIP, FREE SHIPPING | Import Dynamics | Transmission and Driveline | 12 | 05-04-2013 07:53 PM |
| PTUNING-ACT Clutch Release Special-BRZ/FRS-Free shipping | Mrc@ptuning | Transmission and Driveline | 1 | 11-14-2012 11:27 AM |
