#309 |
Senior Misanthrope
I meant from the extra rolling resistance of a 245 or 255 tire vs stock 215.
#310 |
Drives: Nothing yet!
#311 |
Drives: 2013 Ultramarine FR-S
#312 |
Drives: It alls slivery blue.
Ahh, yeah, well you get that even if you go 215 and a tire that has grip haha. But yeah I am sure my 245 PSS have a shit ton more rolling resistance than my 215 Eco tires did =)
#313 |
Canada Eh!
Drives: '13 FRS
![]() ![]() ![]() ![]() - 17x8 +45 Enkei RPF1 (12mm spacer in front) - 245/40/17 Nitto Invo - TRD Lowering Spring - -2.2* Front Camber and -1.8* Rear Camber Last edited by Joe-G; 08-24-2016 at 02:01 AM. |
| The Following 6 Users Say Thank You to Joe-G For This Useful Post: | 86geek (08-24-2016), brz11b (09-29-2016), dattran86 (10-04-2016), KidRich (08-23-2018), mgarcia707 (03-13-2019), mmmcambelsoup (08-24-2016) |
#314 | |
Drives: 2013 "Hot Lava"
Acceleration will be effected. If you've done bolt-ons you might be at a wash or maybe still slightly ahead, relative to a stock car, after moving up to either a larger wheel or wider tire. Basically, without mods to get significantly more power out of the car a stock car with a better than stock tire, but in the same size as stock, will likely both out accelerate in a straight line and get a faster lap time at a twisty track or auto-x than a car with a wider 17" rim (even if it's lighter than stock), and wider 17" tire, or 18" rim if the tire is also wider than stock. Those skinny TRD or STI forged rims are likely performance upgrades even on the stock car because despite being 18" they're lighter and the tire is likely lighter than stock as well, by virtue of having shorter sidewall and no significant increase in rubber width for the same diameter, if that makes sense.
2013 Hot Lava FRS :: OFT Stage 2+ :: JDL UEL Catless :: JDL Over-Frontpipe :: GReddy Evolution RS Catback :: Enkei "Tarmac Black" RPF1 :: Tein Flex-Z Coilovers :: 245/35r18 Conti DW :: RS*R R-LCA :: Racer-X Fab R-Toe Arms :: Mishimoto Intake Tube :: Mishimoto Oil Catch Can :: JDL FSTB :: Raceseng "Slammer" + RLO :: Diode Dynamics HID + Tail-as-Turn + DRL :: 5:AD Spoiler ::
#315 |
Drives: '22 BRZ
Versus stock tires, my car was ~5-10 mph faster exiting "Big Bend" (onto the longest straight at Shenandoah Circuit @ Summit Point) with 245 RE-71Rs but was only ~1mph faster at the end of the straight, plus I was braking ~50 feet later... It's a short straight too, right around 1/4 mile from corner exit to braking zone.
I'd say the wider rubber makes a VERY noticeable difference.
#316 |
Drives: 2014 GT86
Versus stock sized RE-71Rs or versus stock Primacies? There is BIG difference, to reason with just tire width.
#317 | |
Drives: '22 BRZ
I see why Mike says 225s are the way to go.
#318 |
Drives: Toyota 86
#319 |
I am using a 5mm spacer up front...and my car is not stock. The offset/spacer choice is based on the recommendation of the previous owner...I think the front wheel was contacting the swaybar or some other suspension component at full lock without the spacer in there.
#320 |
18x8 +35 up front and 18x9.5 +38 at the back
2013 Toyota 86
Sterling Silver Metallic IG: @pcuerpo.images |
#321 |
Grip>Drift
Drives: FRS
What's up with the MASSIVE stagger??? That's gonna make your car handle like shit! Sent from my iPad using Tapatalk
#322 |
Drives: 2014 GT86
It doesn't matter to those that choose staggered.
| Wheel Directory: Enkei RPF1 17x9.0 +35 | D1cker | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 800 | 10-22-2023 01:00 AM |
| Wheel Directory: Enkei RPF1 18x9.5 +38 | FRS8SIX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 297 | 02-15-2018 04:50 PM |
| Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel | Infamous Performance | Wheels and Tires | 122 | 02-13-2014 12:34 PM |
| Enkei RPF1 17x7.5 +48 5x100 SBC and wheel/tyre question | Victor Draken | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 12-19-2013 02:28 PM |
| Track wheel Enkei RPF1 in 16" ?? | stockysnail | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 42 | 08-07-2013 10:13 AM |
