| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
#43 | ||
Drives: car
Here are the basic trends and relationships to understand. 1. Brake specific fuel consumption decreases at higher load and lower speed according to a basically logarithmic-looking curve. 2. Engine output is a function of displacement, brake mean effective pressure (load), and engine speed. Therefore... 3. If we keep the engine speed the same but decrease the displacement, we must increase the brake mean effective pressure (load) to maintain engine output. Lower displacement means higher brake mean effective pressure to achieve a given output, which means lower fuel consumption. 4. If we reduce the engine speed, we must raise the brake mean effective pressure (load) again to maintain a given engine output. Raising brake mean effective pressure due to downspeeding reduces specific fuel consumption again. The boosting system does present its own set of issues but downsizing means reduced pumping loss and reduced cooling loss relative to larger engines with more cylinders. Certain tricks with cam phasing can also reduce pumping loss (late intake valve closing). The use of high levels of cooled external EGR (not sure if this engine uses it) essentially works as knock suppresant. |
| The Following 4 Users Say Thank You to arghx7 For This Useful Post: |
#44 |
Drives: 2017 Subaru BRZ PP
This engine impresses me! If the new WRX and STI have a version of this engine with that rumored electric turbo technology, it could be amazing!
But putting something like this in a light rear wheel drive car like the BRZ probably wouldn't go too well. Too much horsepower for the weight distribution would easily take this car from fun to scary. With all wheel drive on the other hand, it would be excellent. Too bad the chassis they put it in are always big and heavy 4 door sedans/wagons.
Toyota + Subaru =
#45 |
Rocket Surgeon
Drives: PSM GGA OMG
Because turbochargers can only be efficient over a certain RPM range. They wanted to have lots of torque at very low rpm which means having a small turbocharger. The downside to that is that the torque is going to fall off at high rpm, and that can clearly be seen in the provided torque curve. So the desire for low rpm torque indirectly means that engine will be unable to make torque at high rpm. So in order to achieve their power goals at a necessarily lower rpm they needed to run more of boost.
#46 | |
Drives: SSM LT MT BRZ
It appears you are correct, The language didn't specify Direct Injection, But I see linked documents (and now quoted) do specify that it will be Direct injection. |
#47 | |
Drives: Skyline R33 GTR
#48 | |
ZC6A2B82KC7J
Drives: 2002 WRX
This is a twin scroll turbo with DIT, I think you mean twin turbo with DIT
#49 |
#50 |
Rocket Surgeon
Drives: PSM GGA OMG
#51 |
Kuruma Otaku
The infamous 'valley of death' motor. Apparently terrible transition from single to twin.
Because titanium. |
#52 |
Drives: '06 AM V8V Coupe
I was more wondering what the point of this very early peak torque was, because it looks like they're using the wastegate like crazy above 2000rpm.
I question the philosophy behind these very high boost at low rpm motors because it seems to me that they are very low speed optimized which is good for FE test cycles which are mostly looking at low acceleration rates and cruising (low load). I feel like the real world results (where people driving fast cars are more likely to actually use a bit more power rather than try to accelerate at the same rate as everyone else) would not see as much of an improvement. I guess for the OEM, all that matters is the window sticker and compliance with regulation. |
#53 | |
Kuruma Otaku
Because titanium. |
#54 |
Drives: SWP BRZ LTD
Its just there for ease of daily driving. Most new engines make peak torque very early and sustain it for most of rev range. They are trying to create an engine that mimics a large displacement sedan/wagon's driving experience but with better fuel economy. I would also assume it helps with highway gearing on most cars. CVT's are a trainwreck to drive imo though, so I dont even want to think about how that would be affected on this car.
Remember its a Legacy, not a sports car. Last edited by blu_; 05-10-2012 at 12:25 AM. |
#55 |
Drives: Attitude
#56 |
| Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? | HitTheGas | BRZ First-Gen (2012+) -- General Topics | 12 | 02-21-2012 02:24 PM |
| turbo yes | BMWDAD | BRZ First-Gen (2012+) -- General Topics | 79 | 12-06-2011 01:58 AM |
| Legacy low-mounted turbo oil pump | aspera | Engine, Exhaust, Transmission | 0 | 06-16-2010 04:41 PM |
| Geneva Preview: Techart to debut 911 Turbo, Turbo S | vh_supra26 | Other Vehicles & General Automotive Discussions | 1 | 02-22-2010 07:20 PM |
