#15 |
Drives: 10 series FRS
Totally reversible. What you do is unplug the turn signal harness (the three wire harness that connects to the actual bulb). Then take out the locks that hold the wires in the connectors (should be white plastic pieces). Then pull the green wire out. The green wire is what powers the parking lamp to stay on. Without that wire, it is simply a turn signal.
| The Following User Says Thank You to Knshro13 For This Useful Post: | subiestyle (02-21-2014) |
#16 |
Drives: Neptune GR86
#17 | |
Drives: 2014 Monogram FR-S White MT
would you say you follow these instructions for removing the pins? |
#18 | |
maybe the monograms are wired differently for the front turn signals, or I didn't jam it in hard enough? are the pinouts the same for 7444/7443/7440 bulbs? |
#19 | |
Drives: waiting on a 2021...
http://www.clublexus.com/forums/ligh...7740-bulb.html
2016 4Runner Tail edition
2020 Camry 2020 RAV4 2013 Chevy 3500 4x4 Duramax 1999 Ford F250 Powerstroke, the tow rig 1969 Mustang, the fast car....(: |
#20 |
I'll go ahead and remove the metal contact points for the parking lights filament. Which one would you reckon is it? Top or bottom filament?
| Turn signal question | OMGreta | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 01-27-2014 03:06 PM |
| Is it possible to change turn signal to drl? | Enraged21 | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 02-22-2013 01:52 PM |
| Does 6k HID's Go well With the Turn Signal Switchbacks | J-Money | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 01-29-2013 11:41 PM |
| Anyone seen these turn signal/drl less? | djliquidsteele | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 07-15-2012 04:32 AM |
| Turn Signal Repeaters | Ben_G | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 06-22-2012 11:26 PM |
