86WORX
Old 02-17-2014, 05:42 PM   #15
dssence
Drives: Toyota FT/MT 86
Originally Posted by sdemo View Post
Was it winter?
This is about the dumbest thread on the internet. If the vent is on and A/C is off, your "cold" will only be as cold as ambient temp. As you move towards hot, it will pass increasing amounts of air past the heater core.
This is how every car has been made since the beginning of time.
Correct, and that's not happening. COLD is not blowing as ambient temp but as ambient as you may name but coming from the engine bay itself which by the way it's not COLD. Like why the hell it's not taking the air from the outside instead of the inside of the engine bay.
dssence is offline   Reply With Quote
Old 02-17-2014, 05:46 PM   #16
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
Do you also expect your air intake temps to be the same as ambient? The pipe through which the air is traveling has been heated by the engine. When you first turn on your car, I guarantee it's damn near ambient coming out of your vents.
EDIT: To be clear - red is hot, blue is cold.
sdemo is offline   Reply With Quote
Old 02-17-2014, 05:53 PM   #17
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
What is the ambient temp you experience this at?
chulooz is offline   Reply With Quote
Old 02-17-2014, 05:57 PM   #18
fistpoint
Drives: Supercharged Golf Cart
Originally Posted by dssence View Post
FInally whenever I shift the knob on the HVAC system without air conditioning on instead of COLD air getting inside the cabin I feel the air getting inside is totally warm like if I was using the knob for heating. Like the only way for cold air to get inside is turning on AC totally odd.
Is this a factory issue ? what should I do
Oh boy...we've had huge arguments on this forum about the "warm air from vents, even on full cold" issue.
Some of the lesser intelligent posters insisted all cars do this, while numerous others(myself included) have never owned a car that did this and we aren't retarded. Vent on full cold always equaled cool/cold air inside, as expected...not on this car.(OF COURSE WE'RE TALKING ABOUT COOL WEATHER!)
The only solution I have found is to tun the temperature setting all the way to hot, then turn the vent selector all the way over to one of the last 3 settings, any of the three that has the defog icon(the little windshield icon). Then turn the temp to cold and wait a few seconds, then return the vent selector back to the setting you want.
1) temp all the way hot
2) turn vent to 1 of the 3 defog settings(last 3)
3) temp back to cold, wait a few seconds
4) vent back to...
It usually works. This is the result of a cheaply designed A/C system. And when the people come in claiming all their previous cars did this too, my response is that those were also cheaply designed A/C systems. Hondas haven't done this in the 20+ years I've driven them, so obviously an A/C system CAN be built/designed where warm/hot air doesn't come in when on the full cold setting...unless of course it is hot outside, not the 60F degree or less outside air we are talking about.
fistpoint is offline   Reply With Quote
The Following User Says Thank You to fistpoint For This Useful Post:
blunova (02-17-2014)
Old 02-17-2014, 07:39 PM   #19
sdemo
sdemo's Avatar
You realize defrost runs the A/C compressor, right?
Old 02-17-2014, 08:11 PM   #20
fistpoint
Of course, that's why it is important to use one of the last 3 vent settings to activate the process. Doing this somehow closes the "leak" that is allowing engine air instead of actual outside air into the vents and also obviously cools the air still inside the plumbing since the compressor has come on temporarily.
I've been doing it for the last 2 months, it does work and something is definitely happening in the process. However, sometimes it requires a couple attempts, but when it works the air has clearly gone from warm to cold, and yes, the vent is now on a setting that does not have the compressor running. I only use the first three(face, face/floor, floor).
In the other threads about this, the people that acknowledged the issue but didn't dismiss it like the foolish ones suggested a valve that isn't closing that is designed to prevent this. All that info coupled with my own experience since then suggests to me it's simply a shitty design in this vehicle and any vehicle that exhibits the same behavior. That and the simple fact that all my previous vehicles of the same make as well as all the other people who also never had this issue before on similar makes to my cars is all the evidence I need.
Some cars do it, some don't. Those that don't simply have a better design. It shouldn't be an argument. We aren't retards who forgot to move the temp dial or didn't know that red is hot and blue is cold. It's the design, period.
The Following 2 Users Say Thank You to fistpoint For This Useful Post:
dssence (02-18-2014), nalc (02-17-2014)
Old 02-17-2014, 08:13 PM   #21
Ozzman
Drives: old
My 19 year old Honda does this too.
Ozzman is offline   Reply With Quote
Old 02-17-2014, 09:23 PM   #22
blunova
"Slyde"
blunova's Avatar
Drives: 2013 SWP BRZ
4) vent back to...
Thank you for saying this. I am so damn tired of hearing people say "that is how every car on the planet is made, and if you don't understand it, you're an idiot. BLUE MEANS COLD HAR HAR!!!"
No. That is not how EVERY CAR EVER is made, and I am not an idiot. My Ford Focus did not do this and that was a very cheaply made vehicle. This is one of the things that really bugs me about this car, because in the winter I like to get the cool fresh air from the outside without having to run the AC.
OP, ignore these people telling you that you are an idiot, and this is how all cars work. It might be normal for some cars, but not all cars. I hear you. It sucks - but unfortunately that's how the 86s are
blunova is offline   Reply With Quote
The Following User Says Thank You to blunova For This Useful Post:
Old 02-18-2014, 02:20 AM   #23
fistpoint
I should add this: the trick isn't 100% effective during those few weeks/months we have in Texas where we used to drive with no compressor on because it was just barely cool enough to not need it. The solution unfortunately was to begin using the compressor sooner in the season than I'm used to(last 22 years).
Where this trick comes in useful now that I've had the car almost 1 year, is when it is actually cold outside(60F and under is cold by Texas standards). Without this trick we would be using the compressor when it's 60F outside, which is absurd.
Shitty design overrides vent method during warm/hot climate.
Vent method overrides shitty design during cool/cold climate.
We win one, we lose one.
Old 02-18-2014, 03:17 AM   #24
dssence
Ambient showed 27C outside , but the air coming in was far hotter than 27C , and the shift knob was in cold blue
Old 02-18-2014, 03:22 AM   #25
dssence
Wow thanks GOD I finally come across someone who do understands I'm not crazy or dumb talking about this. To me it's plain not acceptable this is happening, my previous car an ancient toyota celica liftback GT 1979 year whenever I shift the knob to cold pumps cold air not Hot or warm. And I'll tell you even more the AC gets even more freezing than on this car.
By the way can you explain me more in detail the process. What should I do to get cold air blowing shifting the knob cold blue. And why is tihs going on. Didn't get it quite clear. Thanks !
Old 02-18-2014, 03:24 AM   #26
dssence
THANK YOU ! TOO I'm not alone. Any fix to solve this? I'm waiting for the other guy to explain me the procedure to get PURE COLD AIR!
Old 02-18-2014, 03:37 AM   #27
humfrz
DANG, dssence ...... allow me to say again what I said in post #6.
"So, @dssence, you can either open the window, turn on the A/C or ..... punch the recirc button, to shut off the vent (which helps somewhat)".
I had a miata that did this same thing and in 88,000 miles, I couldn't get cool "fresh" air through the vents. I've driven my FR-S for about 8,000 miles and I can't figure out how to get cool "fresh" air through the vent system.
I suggest you quit beating this dead horse/vent thing and get on with enjoying your fine machine......
humfrz
Old 02-18-2014, 10:58 AM   #28
w.k.s.
Drives: 14 SWP BRZ, 07 SWP STI, 05 LGT
humfrz
He's not going to listen, no matter how many times anyone tells him. All he wants is the PURE COLD AIR! without running the AC
w.k.s. is offline   Reply With Quote
The Following User Says Thank You to w.k.s. For This Useful Post:
humfrz (02-18-2014)
Best cold air intake natesparxxx Engine, Exhaust, Transmission 31 05-31-2021 06:04 PM
How cold is too cold to seal and wax? Jertronic Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 11-01-2013 12:20 PM
cold air intake? carbonBLUE Engine, Exhaust, Transmission 72 09-30-2013 01:56 PM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 06:05 PM
it to cold Pekingduck Southern California 9 01-05-2013 09:08 AM
