#183 |
Drives: 2013 Asphalt FR-S
the easiest way to do ALL scaling is to turn off all fuel trims and run full time open loop, Then you can do the entire maf curve in one shot from idle to the rev limiter. However, this is dangerous for newbies to do since you could end up running very lean if your scaling is way out. Using this method all you need to know is actual afr and target afr and maf voltage. Correction = actual afr / target afr.
~Namaste~ |
| The Following User Says Thank You to mad_sb For This Useful Post: | s2d4 (03-16-2014) |
#184 |
#185 | |
Target/Requested AFR.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#186 |
Drives: UK GT86
AFR is the ratio that is logged. AFRx is the adjusted AFR after taking into account for the trims, ie the AFR that would be produced if the ECU wasn't adding or removing fuel. This allows you to use a log with any LTFT included. Once your LTFTs become zero, it becomes as simple as how @mad_sb described. I did a fair bit of reading into MAF scaling and now have it down to a T. It's simple once you get your head around it, massively helped if you can use macro based Excel as the tools are already out there. I had to build my own spreadsheet as I can't.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | s2d4 (03-17-2014) |
#187 |
Not sure if it's been said on another thread, but the base tune on a completely stock car...how much faster is it to 60? I understand it makes the car "feel" better but I'm curious on how much faster it really is. I had the Unichip about a year ago and I enjoyed that, but ended up selling because of E85. Thanks!!!
PS: I drive a auto
#188 | |
No guarantees, no hard launches. Don't want to destroy my axles. |
| The Following User Says Thank You to Sonolin For This Useful Post: | ScionFrsFan (03-23-2014) |
#189 |
Drives: 2007 STI Limited / 2014 BRZ Limited
Had a chance to really test out the Stage 2 EL E85 flash today. Ran a second full tank of E85 on a nice long road trip. Once at our destination I was able to fill it up again for a 3rd full tank and go on a 3 hour rally. With plenty of time for the ECU/DME to adapt I had a few good pulls with the butt-dyno agreeing that gains were there. No hick-ups at all in starting or running. Torque dip is mostly gone for me even running a stock header and cat.
Best money I have spent on any car I have owned / modded to date. |
| The Following 3 Users Say Thank You to Proof For This Useful Post: |
#190 |
Might be more repeatable just to do a rolling 3rd gear from 2000-7000 log it then find the time and compare
| The Following User Says Thank You to steve99 For This Useful Post: | Sonolin (03-24-2014) |
#191 |
#192 |
Drives: Neptune GR86
#193 | |
Just filled up with gas so plenty of time to get it done before my next tank which will be wonderful wonderful e85 ![]() I'd also like to say I highly doubt the gains are as good as I think they will be. But that's ok because it just *feels* way better than 91, I don't care about the numbers when my brain is telling me YES. |
#194 |
Drives: 86 GT
any way to change the oil temp to read in *c rather than *f?
#195 |
Quick rule of thumb. Minus 30 then divide by 2 will get you very close to degrees Celsius.
#196 |
| Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 | FRSTEVE | Software Tuning | 105 | 08-04-2017 05:48 AM |
| ***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes | Garrett@Openflash | Engine, Exhaust, Bolt-Ons | 54 | 06-11-2014 07:29 PM |
| ***VISHNU OpenFlash Tablet IN STOCK*** | Garrett@Openflash | Engine, Exhaust, Bolt-Ons | 15 | 12-17-2013 02:30 PM |
| Vishnu OFT tablet software mod request... | Tromatic | Software Tuning | 5 | 12-07-2013 08:52 PM |
| FS: Vishnu OpenFlash Tablet - Unused, Mint Condition | AyJay | Engine, Exhaust, Bolt-Ons | 6 | 11-09-2013 12:45 PM |
