Old 02-08-2014, 02:20 PM   #1
iamdaspoon
iamdaspoon's Avatar
Drives: 2015 Subaru WRX
Brz navigation issues.
Last night I was driving and twice within a 5 minute period my head unit shut down while the car was still on, the screen still had some backlight but was definitely off.
It seemed like it happened when I hit a bump in the road, not a serious bump at all though.
Any ideas?
iamdaspoon is offline   Reply With Quote
Old 02-08-2014, 02:30 PM   #2
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Sounds like something came loose back there.
^GT5 Replay Photo Mode^
Old 02-08-2014, 02:31 PM   #3
iamdaspoon
iamdaspoon's Avatar
How can I check? Or do I have to bring it in?
Old 02-08-2014, 02:33 PM   #4
Burrcold
Drives: Subaru BRZ Limited
Just pop off the console plastics, unscrew the headunit and push all of the connections in on the back.
Old 02-08-2014, 02:34 PM   #5
SirBrass
SirBrass's Avatar
Remove trim panel around the head unit. Then with a 10mm socket (you'll need a 4" extension minimum), remove the 4 10mm bolts that hold the head unit brackets to the mount. Gently lift and pull the head unit out. Check to make sure all connections in the rear are firmly and securely in their sockets. Reverse steps.
Old 02-08-2014, 09:07 PM   #6
iamdaspoon
iamdaspoon's Avatar
Thank you guys, will have to do that this upcoming week. Do you think it might have anything to do with the cold? It was around 6 degrees last night and my car isn't really used to those temperatures and I've noticed the difference all around. Including taking a little extra "umph" to turn start first thing in the morning.
Old 02-08-2014, 09:40 PM   #7
Burrcold
I doubt it's the cold. Usually if the LCD is going into safe mode, it would be right from start up. This case sounds like a loose connection to the headunit or inside the headunit.
WTB: BRZ OEM Navigation DJ Sueno Mid-Atlantic 1 11-24-2013 07:34 AM
IA: BRZ OEM navigation qoncept Audio/Visual, Electronics, Infotainment, NAV 2 05-29-2013 11:28 AM
BRZ OE navigation unit... again. glorydays Audio/Visual, Electronics, Infotainment, NAV 2 03-16-2013 01:34 PM
So, how is the navigation? MmmHamSandwich Electronics | Audio | NAV | Infotainment 25 08-27-2012 02:12 PM
Navigation for FRS? Yuck Electronics | Audio | NAV | Infotainment 5 08-27-2012 12:02 AM
