Old 02-14-2014, 01:10 PM   #85
radroach
Drives: car
*editing this post* I/O limitation will be the write speed of the ecu memory, ecutek control unit, etc, ROM memory is usually pretty slow to write. So, having a faster SSD usually won't make a difference.
Old 02-14-2014, 01:28 PM   #86
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by olorin View Post
Nope, about a minute and a half. Its no different than running windows on a pc. Its also pretty easy to create a windows partition on an existing OS X partition.
I have a MBP SSD, i5 processor 8 GB RAM and it takes about 3-4 minutes.
Maybe you have a better processor and that is the determining factor?
Old 02-14-2014, 11:30 PM   #87
Deathreaper
Drives: 2013 Scion FRS
If you guys can post CPU usage figures while flashing you should be able to confirm any bottleneck.
Deathreaper is offline   Reply With Quote
Old 02-15-2014, 01:26 AM   #88
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
Originally Posted by Sportsguy83 View Post
On Ecutek, but my point is, it doesn't matter if its Ecuflash or Ecutek,
IF the ECU was the limiting factor, then my flash time and nelsmar time would be the same
Okay, so why don't we do some calculations then..
How big is the file being flashed? I think the stock map is 1.3mb (when downloaded from OFT)
Looks like the binary files are also about 1.3mb
I can pretty much guarantee that the data transfer speed is going to be limited by the ecutek cable and ISO specs for obd2. which doesn't make sense... because yes you should both be getting the same times.
unless the ecutek software is doing some serious processing in the back ground.. which wouldn't make sense because the file you are flashing is a binary rom file.
sportsguy why don't you open up task manager next time you flash. just watch for ram / processing going up during the process.
86-tundra is offline   Reply With Quote
The Following User Says Thank You to 86-tundra For This Useful Post:
Sportsguy83 (02-15-2014)
Old 02-15-2014, 01:37 AM   #89
Foobar
SLO NO MO
Foobar's Avatar
I have a Sager NP8150 that I use for flashing. I noticed that flashing takes about a minute and a half on one of my USB ports, but takes a lot longer on the others. I think its the USB2 that's faster than the USB3. Go figure.
Old 02-15-2014, 11:36 AM   #90
Sportsguy83
Drives: Limited BRZ
That reinforces @mad_sb theory that it has to do with the driver being optimized for certain chipsets.
Old 02-15-2014, 04:37 PM   #91
Foobar
SLO NO MO
Foobar's Avatar
Yeah I think that's what the deal is. I'm gonna install ECUTek and W7 on an old Atom based Netbook of mine and see how fast that one flashes.
Old 02-16-2014, 08:54 AM   #92
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
Let me know how it goes. I have my old MSI Wind back home. I would love to use this for tuning. As soon as I find it, mom chucked it in the basement along with the rest of shit as soon as I left for basic. lol
Bg8780 is offline   Reply With Quote
Old 02-16-2014, 08:56 AM   #93
Bg8780
Bg8780's Avatar
Originally Posted by Draco_PR23 View Post
I have a MBP and I was thinking to upgrade to a SSD with Bootcamp to improve the flash times.
If not I might consider a cheap Windows laptop.
It may help a little bit. I would still say upgrade to an SSD just for the sake of everything else you use it for. I picked up a 480gb Crucial M500 and it has been AWESOME! 400+ mbps read/write. And I was already coming from a Kingston HyperX. I can't recommend these SSD's enough.
The Following User Says Thank You to Bg8780 For This Useful Post:
Draco_PR23 (02-16-2014)
Old 02-16-2014, 01:10 PM   #94
Foobar
SLO NO MO
Foobar's Avatar
OK, my netbook, a Lenovo S10 Atom-based 1.6ghz 2.5gb RAM and some crappy slow hard drive running 32-bit Windows 7 Pro was able to flash my car in a little over 3 minutes with USB2. My Sager NP8150 with USB2 does it somewhere before 1.5 mins so this thing is more than twice as slow for flashing. Using my USB3 port on the Sager, it goes to well over 5 minutes (I stopped counting and went inside the last time that happened).
So the netbook is slower, but for the convenience and portability, I think I'm going to keep it as my main ECUTek machine for flashing and logging.
Old 02-16-2014, 08:46 PM   #95
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
I will eventually upgrade, but I was planning to get a Samsung Evo SSD but I will look into the Crucial. Thanks!
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
Old 02-17-2014, 03:41 AM   #96
Bg8780
Bg8780's Avatar
I was wrestling between the M500 and the 840 EVO. Newegg was running a promotion on the Crucials so I went that route. The Crucial has nice hardware encryption but the Samsung is TLC which is still being proven.
They are both great just go with which ever is cheaper at the time. Check out some reviews on Tom's Hardware and anantech. They usually know what they are talking about.
Draco_PR23 (02-17-2014)
Old 02-17-2014, 10:58 AM   #97
Sportsguy83
Drives: Limited BRZ
Opened task manager, and it shows the CPU using between 3-4 of the CPU and memory sat steady at 21,00K of memory. The CPU jumped to about 21 when it reached 100% for a brief moment and that's it.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
86-tundra (02-17-2014)
Old 02-17-2014, 11:35 AM   #98
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
The Lenovo Yoga 2 Pro is like 70 seconds. But's slightly better than a tablet. Full Laptop support, dual USB 3.0 ports, has tablet/touch mode.
For what it is, I love it, kinda durable too #jamesjuniorproof
Ironsquid is offline   Reply With Quote
The Following 3 Users Say Thank You to Ironsquid For This Useful Post:
Bg8780 (02-17-2014), jamesm (02-17-2014), Sportsguy83 (02-17-2014)
Laptop + Tactrix cable + BRZEdit personal - $400 Dodzilla Engine, Exhaust, Bolt-Ons 5 02-14-2014 05:30 PM
SOLD: Toshiba C855D Laptop swift996 Miscellaneous 0 01-10-2014 07:06 PM
Carbon Fiber Laptop Sleeves - Introducing DFWcomposites to ft86club DFWcomposites Announcements, Contests, Giveaways 4 08-12-2013 03:42 AM
Carbon Fiber Laptop Sleeves - DFWcomposites DFWcomposites Miscellaneous 3 08-12-2013 03:42 AM
ALIENWARE LAPTOP brichard0625 Off-Topic Lounge [WARNING: NO POLITICS] 68 11-06-2012 02:01 PM
