#71 | |
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
#72 |
I Love custom Turbo kits
Drives: Limited BRZ
On Ecutek, but my point is, it doesn't matter if its Ecuflash or Ecutek,
IF the ECU was the limiting factor, then my flash time and nelsmar time would be the same
#73 | |
If you were flashing from exactly the same map, making exactly the same changes, and the write times were so significantly different I would believe it. Last edited by AdrianG; 02-14-2014 at 09:11 AM. |
#74 | |
Drives: Limited BRZ
#75 |
| The Following User Says Thank You to AdrianG For This Useful Post: | Sportsguy83 (02-14-2014) |
#76 |
We should compile a list of laptops that are known to have good flashing times.. since they seem to vary quite a bit by model. I wouldn't mind picking one up if I knew that it would flash like lightning
| The Following 2 Users Say Thank You to jamesm For This Useful Post: | Draco_PR23 (02-14-2014), Sportsguy83 (02-14-2014) |
#77 | |
Drives: Limited BRZ
![]() (Give me a call when possible).
| The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post: | Draco_PR23 (02-14-2014), jamesm (02-14-2014) |
#78 |
Drives: '13 Black Subaru BRZ Limited
I'm speaking ONLY on theory here but I'd say the biggest factor off speed when it comes to flashing a ROM is probably your machines storage device (SSD, HDD)
I say this because @Sportsguy83 said his friends tablet flashes pretty quick. I'm sure the tablet is running a very decent SSD. Since the ROM that is being flashed is coming from the main storage device, this makes sense. Unless, the ROM that is being flashed is cached in the RAM. Then this is a different story. I'm just thinking aloud. I could be completely wrong. I just upgraded the SSD in my Macbook recently to a much faster one, so I'll have to see if I notice a difference when I flash next. That won't be for awhile though. |
| The Following User Says Thank You to Bg8780 For This Useful Post: | Sportsguy83 (02-14-2014) |
#79 | |
Drives: Limited BRZ
Then I went to a Mac with SSD and lowered it to 3-4 minutes. But now I want the cake and keep it at about 1 minute with a SSD modern Windows device.
#80 |
Thupercharged
FWIW I had a thinkpad twist with an i5 and standard harddrive. Flash times did not improve/change when I switched to a 120gb Samsung EVO 840 SSD. Everything else was faster, but flash times felt the exact same
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
| The Following User Says Thank You to DJCarbine For This Useful Post: | Sportsguy83 (02-14-2014) |
#81 |
Fiebru
Drives: Scion FR-S and Integra Type R
I have a MBP and I was thinking to upgrade to a SSD with Bootcamp to improve the flash times.
If not I might consider a cheap Windows laptop.
Current Cars:
2017 White Platinum Ford Fiesta ST 2013 Raven Scion FR-S 2012 Spruce Mica Toyota Tacoma TRD Off-Road 2000 Phoenix Yellow Acura Integra Type R |
#82 | |
Drives: Limited BRZ
I'm not too happy of my MBP performance, but it will honestly depend on how much do you plan on flashing. If you want to flash say once a week, it's not a big deal at all. But I am flashing 4-5 times a night right now fine tuning driveability and then dyno time and for that its a PITA to wait inside the car 3-4 minutes everytime.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | Draco_PR23 (02-14-2014) |
#83 | |
Drives: GBS Premium
#84 | |
Drives: GBS Premium
Not so sure an SSD would really make a difference. Its not doing a lot of disk activity to flash the ECU. CPU and bus speed are more important.
| Laptop + Tactrix cable + BRZEdit personal - $400 | Dodzilla | Engine, Exhaust, Bolt-Ons | 5 | 02-14-2014 05:30 PM |
| SOLD: Toshiba C855D Laptop | swift996 | Miscellaneous | 0 | 01-10-2014 07:06 PM |
| Carbon Fiber Laptop Sleeves - Introducing DFWcomposites to ft86club | DFWcomposites | Announcements, Contests, Giveaways | 4 | 08-12-2013 03:42 AM |
| Carbon Fiber Laptop Sleeves - DFWcomposites | DFWcomposites | Miscellaneous | 3 | 08-12-2013 03:42 AM |
| ALIENWARE LAPTOP | brichard0625 | Off-Topic Lounge [WARNING: NO POLITICS] | 68 | 11-06-2012 02:01 PM |
