Old 02-06-2014, 12:56 PM   #15
Wepeel
Drives: '13 BRZ Ltd
FYI that's 260 lb/in Front and 294 lb/in Rear.
Wepeel is offline   Reply With Quote
The Following 2 Users Say Thank You to Wepeel For This Useful Post:
BigFatFlip (02-07-2014), rallysrt (02-06-2014)
Old 02-07-2014, 01:31 AM   #16
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Originally Posted by FR-S Matt View Post
Nameless beat them to this by a long time. They're running Australian rally suspension on their rally car. Pretty badass stuff.
True, but they are running completely custom MCA golds that run $5k
Old 02-07-2014, 02:48 AM   #17
coyote
coyote's Avatar
Drives: Slowly
I may have said elsewhere you can buy Golds for $5k, but there is no way $5k will buy you the kind of setup that car has.
Sent from my Nexus 4 using Tapatalk
coyote is offline   Reply With Quote
Old 02-07-2014, 05:48 AM   #18
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
MCA golds don't a price. They are custom. You pay depending on the damper you want. 5k might the starting price but I have read of 12k being spent on golds somewhere.
Old 02-07-2014, 06:18 AM   #19
coyote
coyote's Avatar
Drives: Slowly
I've driven cars on MCA worth double that.
No, they cost double ... worth at least triple.
Old 02-07-2014, 06:57 AM   #20
Captain Snooze
Drives: Red Herring
:o
Old 02-07-2014, 01:11 PM   #21
BigFatFlip
BigFatFlip's Avatar
Very true, I meant to say "at the very least $5k" and that's for the coilovers alone, not counting the completely custom geometry/subframe the Nameless guys had to engineer to work with the MCA's.
I guess the point I was trying to make is that these TRDs may be a good cheap alternative. Now say I was interested in purchasing these, where would I get them?
Old 02-07-2014, 02:27 PM   #22
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
i'd like to see a shock dyno performed between these and the stock ones.
i might consider these for my 'winter' setup.
SC10N FR-S #435 of 2500
azian_advanced is offline   Reply With Quote
The Following User Says Thank You to azian_advanced For This Useful Post:
JohnJuan (08-08-2014)
Old 08-07-2014, 05:55 PM   #23
Rossman
Rossman's Avatar
Drives: '22 BRZ, '17 BRZ (prev '13 FR-S)
Anyone know where this suspension kit can be purchased?? Out where I am there are a lot of dirt roads, I need some more clearance or this car is not going to survive!
Thanks
Rossman is offline   Reply With Quote
The Following User Says Thank You to Rossman For This Useful Post:
Muaddib (09-02-2014)
Old 08-07-2014, 10:31 PM   #24
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Thanks
You seem rally interested.
I'll show myself out.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
The Following 7 Users Say Thank You to Laika For This Useful Post:
forwallblakmail (09-02-2014), gramicci101 (09-06-2014), JohnJuan (08-08-2014), NWFRS (09-29-2015), solidONE (10-28-2015), Turdinator (08-07-2014), YMAA (08-08-2014)
Old 08-08-2014, 02:29 AM   #25
8R6
8R6's Avatar
Drives: FRS
i thought stock was already rally set up? shit is like 6 inch gap lol
8R6 is offline   Reply With Quote
Old 09-01-2014, 09:54 PM   #26
Weasel Soup
Veteran RallyCrosser
Weasel Soup's Avatar
Drives: 10 Series FR-S, 95 Escort Rally Car
Has anyone been able to procure a set of these?
Everything should be attempted twice. Once to satisfy curiosity, and the second time to see if you like it.
My Journal
2016 SCCA RallyCross National Champion - Prepared Rear Wheel Drive
Weasel Soup is offline   Reply With Quote
Old 10-28-2015, 06:55 AM   #27
Trettiosjuan
Drives: GT86
Nobody?
It seems that the TRD rally dampers have significantly lower damping force at high damper speeds than the OEM dampers, despite spring rates being double in front and 60% higher in the rear.
Numbers (OEM converted and interpolated from BRZ damper shock dyno results by racecomp):
Damping force at (high) 0,3m/s damper speed
OEM vs TRD Rally
Front
Compression ~560 540
Rebound ~1690 1250
Rear
Compression ~735 400
Rebound ~1620 1120
Spring rates (kg/mm)
OEM GT86(EU) vs TRD Rally
Front
2,3 4,6
Rear
3,3 5,2
So it will definitely want to sit higher in it's springs and extend quicker, possibly a bit underdamped/more comfy?
Intrigued... might wanna try them if I can get a hold of them...
Trettiosjuan is offline   Reply With Quote
Old 10-28-2015, 08:37 AM   #28
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
That's a real knee-slapper, right there.
Intent > Content
Search this Thread:
Advanced Search
Nameless Rally Car ducks Scion FR-S / Toyota 86 GT86 General Forum 5 11-20-2013 04:09 AM
Who is up for a Rally? Thongpocket Southeast 12 11-04-2013 09:27 AM
rally? autox? paraguin Tracking / Autocross / HPDE / Drifting 6 08-13-2012 08:20 PM
Bullrun Rally? trackmagic Scion FR-S / Toyota 86 GT86 General Forum 1 06-28-2012 01:51 PM
Cusco FRS/BRZ Rally Car vividracing FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 06-04-2012 11:42 PM
