#15 |
I've had 2 headlights go out at once. Anything is possible...
#16 |
Drives: Limited WRB AT6 BRZ
This has already happened twice since I got the car around Aug. 2012. Both remote batteries died about the same time. It appears that the remote sends out a signal all the time, which eventually drains the battery whether you use it or not. I now keep two extra batteries in the glove box and keep the battery out of the second remote. Kinda sucks that the batteries don't even last a year.
#17 |
Some guy in a white car
Drives: 2013 SWP BRZ Limited
a few issues i have seen is interference with cell phones.
also the wheel will lock just like normal turn key ignitions. give the wheel a yank and try starting again. the fob must be within a few feet of the door/trunk to open. sometimes if i'm leaning in to open the door for someone it wont open until i scoot a little closer. the stupidest thing i ever did was i could not figure out why my car wouldn't lock. it was because i was travelling and took my spare key with me which was inside the car. so, make sure you only have 1 key inside the car. derp. if it persists, see the dealer
2013 Subaru BRZ Limited 6MT - Satin White Pearl![]() |
#18 | |
Drives: 16 CBS WRX Limited
This is actually written in the manual which states that the remotes are constantly "on" and that batteries need to be replaced, regardless of use, approximately every 1.5 years. |
#19 | |
Drives: Suzuki Swift
When will you know when the key need to be changed. In my case the fog key opens the door but when it comes to starting my Suzuki swift, it doesn't start. |
#20 | |
I am having the same problem as you. Was the light in the Fob coming on every time you press the unlock or lock? In my case it does. The unlocking of the doors work fine but the problem is that the Fob isnt being recognized by the car when it comes to starting the suzuki swift. |
| Keyless start button: how to put it in ACC mode? | JSUB | BRZ First-Gen (2012+) -- General Topics | 124 | 09-09-2015 06:42 PM |
| BRZ start button not always working? | JSUB | BRZ First-Gen (2012+) -- General Topics | 8 | 10-22-2013 11:24 AM |
| How secure is the Keyless Entry and Start system? | SeattleJeremy | BRZ First-Gen (2012+) -- General Topics | 31 | 09-23-2013 12:23 AM |
| Keyless Entry and Start-up issues | taiguochin | BRZ First-Gen (2012+) -- General Topics | 27 | 01-21-2013 11:15 AM |
| Keyless Entry Delay/Not Working | Dezoris | Issues | Warranty | Recalls / TSB | 0 | 11-02-2012 07:57 PM |
