86WORX
Old 02-05-2014, 09:48 AM   #15
FR-S Matt
Originally Posted by kjdd787 View Post
Thanks for the clarification I really only n want rear camber with minimal front camber
Sent from my SCH-I545 using Tapatalk
You want it the other way around. You want more front camber than rear. Camber bolts are usually preferred first before camber plates. LCA's are a must to keep camber in spec in the rear.
Old 02-05-2014, 11:43 AM   #16
wparsons
wparsons's Avatar
^^ It all depends on his goals...
flickr
Old 02-05-2014, 01:06 PM   #17
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Ok so to clear things up to me slammed is on the floor but I want to go as low as possible without scraping everything it would be nice to make it over a speed bump
And my driveway is not steep at all but I see slammed cars with problems pulling into a parking lot with a .5 inch bump
Sorry for my dumb questions
Your question isn't dumb, it needs to be worded better. I still am unclear as to what you define as "as low as possible" and what constitutes "scraping everything".
If you lower this car, due to the way the bumper overhangs the front you will encounter some scraping no matter what. You can make it over speedbumps but that will depend on the softness of your suspension.
But you should clarify the question above first...
-alex
Old 02-05-2014, 01:38 PM   #18
kjdd787
Drives:
-alex
I want to go low enough so there is zero wheel gap
kjdd787 is offline   Reply With Quote
Old 02-05-2014, 01:44 PM   #19
mav1178
mav1178's Avatar
Then you will not make it over speed bumps. You can't have your cake and eat it too...
My car with ~1" lowered already has difficulty going in/out of some parking lots and structures.
Zero wheel gap = slammed = all sorts of clearance issue for you.
-alex
Old 02-05-2014, 02:30 PM   #20
mad_sb
Based on your descriptions you will be removing camber to get your alignment back to a reasonable street alignment. Lowering induces more negative camber. Sounds like you want to go atleast 1.5 - 2.0 inches lower than stock.
For the rear you will almost certainly need Lower control arms (since you want it on the floor).
For the front, it depends. If you go with coilovers that have camber tops you probably won't need any more adjustment. If you go with lowering springs then at a minimum you will need crash bolts for the front.
Old 02-05-2014, 03:46 PM   #21
kjdd787
Drives:
How much clearance issues will happen with that low of a drop
Old 02-05-2014, 04:43 PM   #22
wparsons
wparsons's Avatar
There are tons of threads showing ride heights, and what wheels fit different suspension setups...
flickr
Old 02-06-2014, 10:47 PM   #23
mongiamc10
Drives: 2014 FR-S
i havent seen anyone ask nor did he originally mention so i will ask... what is your price point or max to spend on your suspension? that will have a lot to do with what you are trying to achieve; better to probably get everything youll need at once. if money is no object then bag it and be done with it =]
mongiamc10 is offline   Reply With Quote
Old 02-06-2014, 10:52 PM   #24
kjdd787
Drives:
I mean money has some what to do with it but I'm getting my tax return so I would really like to keep it under 1500 but I don't want cheap garbage
Old 02-07-2014, 08:47 AM   #25
wparsons
wparsons's Avatar
If your budget is $1500 total, then you're going to have to go cheap.
Budget LCA's are around $400, good ones are closer to $600+. That leaves you with $900-$1100 for the coilovers, rear toe links(you'll need them lowering it that much), install and alignment.
To have zero wheel gap is dropping it a lot, and it's going to ride way worse than stock regardless of what coilovers you get. Without correcting the roll center it's also going to handle worse than stock. All things to keep in mind before buying anything.
flickr
Old 02-07-2014, 07:26 PM   #26
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Hoping camber bolts will fix this front camber!! This is with the Eibach Pro Kit.
Last edited by texasbound972; 02-07-2014 at 07:31 PM. Reason: Forgot to add some stuff.
texasbound972 is offline   Reply With Quote
Search this Thread:
Advanced Search
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 02:10 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
Adjustable Camber Arms vs. Whiteline Camber Bushings digital_assassin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 70 06-02-2013 07:06 AM
