Old 09-26-2016, 10:43 AM   #43
fizzymike
fizzymike's Avatar
Drives: 2014 Silver BRZ
If your on stock ride height a normal one is fine, however if you lower your car I would say that its worth getting so you dont have to drive up on planks like me
fizzymike is offline   Reply With Quote
Old 09-26-2016, 10:51 AM   #44
Nickosport
Drives: 2015 WRB BRZ Premium
I have the 2 ton harbor freight jack. Its heavy af, weight on the box says 101lbs. It does work great, especially on lowered cars. It also has a very high max height. If its something you need to bring with you and not just a shop jack I would suggest one of the aluminum ones though. My 2 ton stays at the shop so weight isn't a factor.
That's the best price i have seen on that jack. I paid 139 for mine, but it wasn't on sale.
2015 WRB BRZ - Nameless - Raceseng - Eibach - Whiteline - Cusco - Perrin
Nickosport is offline   Reply With Quote
JACK's BRZ! Mr. Jack Member's Car Journals 10 07-05-2013 10:19 AM
Some interesting background on oil that doesn't require a chemistry degree Chimpo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 04-11-2013 11:24 PM
Does the BeSpoke audio system require an Iphone? Cj_Staal Electronics | Audio | NAV | Infotainment 4 02-17-2013 01:13 AM
Scion FR-S, Subaru BRZ rough idle issues require ECU reflash gunitrecord BRZ First-Gen (2012+) -- General Topics 1 10-06-2012 03:14 AM
Where ti jack car up at? skatery1989 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 08-13-2012 02:53 AM
