Old 02-07-2014, 03:58 PM   #29
torqdork
torqdork's Avatar
Drives: RV-7
Originally Posted by AdamVR4 View Post
So you'd get under a car held up by some other brand jack? I don't care where the jack is from because you don't ever get under a car until its on stands.
How are people minimizing damage to the "support positions" in the diagram? A puck with a groove?
Works on either 3T or 6T steel jackstands with a saddle design that fits the rocker contour and pinch welds better than most. I've had no damage and have used them at least ten times with the car supported for days at a time:
http://www.harborfreight.com/2-piece...and-95952.html
torqdork is offline   Reply With Quote
Old 02-07-2014, 04:18 PM   #30
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
Originally Posted by OICU812 View Post
Guaranteed can find this jack in states. Its Michelins Branded low profile jack. Not only is it super low profile but also a looong reach. Ive jacked cars even lower then mine which is 1.5" less then stock to ground with zero issue, it's fantastic!
http://www.canadiantire.ca/en/pdp/au...l#.UvNDnLQvtCM
QFT
This is the one I have and it's awesome!
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 02-07-2014, 04:32 PM   #31
MidnightRunner
MidnightRunner's Avatar
I usually have someone slide my basic Jack under while I lift the car a quarter inch from my wheel well. More power to you if you have money at your disposal, but let's not confuse needs and wants. I'm only an inch lower on springs btw.
And word of advice, I always remove my wheels and throw em under the car incase the stands slip. Better to have a scuffed rim than being in a casket.
Sent from my LG-P769 using Tapatalk
There is no great genius without a mixture of madness - Aristotle
MidnightRunner is offline   Reply With Quote
The Following 2 Users Say Thank You to MidnightRunner For This Useful Post:
WryGuy (06-04-2016), zc06_kisstherain (02-07-2014)
Old 02-07-2014, 06:22 PM   #32
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
me place jack right next to jack stands.
wheel works as well but i am kinda lazy to remove wheels every time.
hardly two jack stands fail at same time
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
MidnightRunner (02-08-2014)
Old 02-08-2014, 01:35 AM   #33
MidnightRunner
Haha, now while a $100+ Jack might not be my cup of tea, a quality impact wrench comes in extremely handy on multiple occasions.
Old 06-04-2016, 01:05 PM   #34
WryGuy
Drives: 2014 FR-S Argento, 2003 Celica GT
Just curious.
I have ramps I use for oil changes and such. But cannot remove wheels. So thinking to get a Jack and stand.
I'm going to get the HF 68050 and a couple Jack stands with rubber pads mentioned above.
Will any of that fit in the FR-S trunk (with back seat lowered) aside from the rubber pads?
WryGuy is offline   Reply With Quote
Old 06-04-2016, 01:34 PM   #35
Blue Gt
Blue Gt's Avatar
My car is lowered 1.5" on coil-overs so I drive it onto some 12" long 1" by 8" boards. Then my Sears jack can just fit under the front bumper. DP
Blue Gt is offline   Reply With Quote
Old 06-04-2016, 10:24 PM   #36
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
I have this jack and love it. Fits easily under the front of the car and jacks up high enough to place jack stands under the sides. My car is stock height. http://www.harborfreight.com/15-ton-...ump-60569.html
fx1mark is offline   Reply With Quote
Old 06-05-2016, 12:13 AM   #37
WryGuy
Thanks!
Old 06-05-2016, 12:22 AM   #38
wheelhaus
wheelhaus's Avatar
Originally Posted by WryGuy View Post
Just curious.
With the handle removed the 68050 will fit no problem. If its still in the box you might need to fold down the back seat, but otherwise you shouldnt have any issues getting it home.
wheelhaus is offline   Reply With Quote
Old 06-05-2016, 12:45 AM   #39
WryGuy
Whew!
Good to know.
Appreciate your help.
Old 09-25-2016, 10:50 PM   #40
wheelhaus
wheelhaus's Avatar
FYI the 2-ton long reach low profile jack (68050/62310/60678) is on sale again, $119.99 is the best price I've seen since I bought mine at $109 four years ago. Mine is still going strong. Found the coupon in a motorcycle magazine of all places... Coupon is good until Dec 23rd 2016, remember to print and bring it to the HF store!
Old 09-26-2016, 12:53 AM   #41
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
That's the downside of condo living. I can't leave a 99lb jack out, so the weight is an issue (the 26lb regular HF jack works well in this case).
Otherwise, great deal!
daiheadjai is offline   Reply With Quote
Old 09-26-2016, 09:42 AM   #42
Ashikabi
Ashikabi's Avatar
I suggest spending the money on an aluminum jack. I have the 3 ton from HF at 75 pounds and it's a pain to carry back and forth. If you're stock you should be able to fit most large jacks under there without ramps. I'm low so I drive on long, low ramps, then jack. NEVER use a non-oem jack on the side pinch welds. They will collapse. Modify the pinch welds with a jacking plate or jack from the front crossmember/rear differential
The Following User Says Thank You to Ashikabi For This Useful Post:
daiheadjai (09-26-2016)
JACK's BRZ! Mr. Jack Member's Car Journals 10 07-05-2013 10:19 AM
Some interesting background on oil that doesn't require a chemistry degree Chimpo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 04-11-2013 11:24 PM
Does the BeSpoke audio system require an Iphone? Cj_Staal Electronics | Audio | NAV | Infotainment 4 02-17-2013 01:13 AM
Scion FR-S, Subaru BRZ rough idle issues require ECU reflash gunitrecord BRZ First-Gen (2012+) -- General Topics 1 10-06-2012 03:14 AM
Where ti jack car up at? skatery1989 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 08-13-2012 02:53 AM
