86WORX
Old 02-05-2014, 05:14 PM   #15
Selvedge
Originally Posted by Purdue FR-S View Post
So, can I get away with this cheaper one?
http://www.harborfreight.com/rapid-p...NzgxNCJ9%0D%0A
Or do I need to get the one that costs significantly more?
http://www.harborfreight.com/2-ton-h...ump-68050.html
Originally Posted by TemeCal View Post
To make life easier, I'd get a low-profile jack. I've used normal sized jacks, and low profile jacks. If you're jacking up from the front or the back (diff), you will need a low jack.
I have a "big red" racing jack, my brother has a harbor freight racing jack. Both BARELY squeeze under the front bumpers of ours (our cars are 1" lower).
@TemeCal says his brother uses the cheaper one and his is lowered. So if you're stock, I'm guessing you'll be fine.
Selvedge is offline   Reply With Quote
The Following User Says Thank You to Selvedge For This Useful Post:
Purdue FR-S (02-05-2014)
Old 02-05-2014, 08:33 PM   #16
Purdue FR-S
Boiler Up!
Purdue FR-S's Avatar
Drives: 2018 BRZ tS
Yeah this is what I was thinking too . . . just didn't wanna get the smaller one if it was going to be annoying to use
Purdue FR-S is offline   Reply With Quote
Old 02-06-2014, 12:45 AM   #17
Selvedge
If you do get it, let me know how it works out. If it's fine, I'm going to pick one up the next time I go down to the States.
Old 02-06-2014, 01:19 AM   #18
Kakawate
Man-ape
Kakawate's Avatar
Drives: 2013 Buddy Club Scion FR-S
I drive my car on ramps first then use the jack. Low profile jacks are the way to go if you plan to go lowered.
Kakawate is offline   Reply With Quote
Old 02-06-2014, 03:03 AM   #19
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
If they're low enough for your car, the lightweight aluminum jacks work well. If you use a jack a lot, however, they don't last all that long.
I use an AC Hydraulics DK13HLQ when a low-profile jack is required. It's a 3½" jack, and I really like that it can lift as high as I need (max of 29"): http://www.pelicanparts.com/catalog/...yd1-detail.htm. Not cheap, but you'll never buy another jack.
dradernh is offline   Reply With Quote
Old 02-06-2014, 04:12 AM   #20
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Guaranteed can find this jack in states. Its Michelins Branded low profile jack. Not only is it super low profile but also a looong reach. Ive jacked cars even lower then mine which is 1.5" less then stock to ground with zero issue, it's fantastic!
http://www.canadiantire.ca/en/pdp/au...l#.UvNDnLQvtCM
The Following User Says Thank You to OICU812 For This Useful Post:
AznKirby (02-07-2014)
Old 02-06-2014, 10:26 AM   #21
frslee
Just drive it
Drives: 13' FR-S
Wow, that Michelin jack looks amazing. It's built for race cars!
Anyways, if you can't get your jack under the car, put your front axle on some wood board, then you'll be good to go.
frslee is offline   Reply With Quote
Old 02-06-2014, 10:34 AM   #22
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
i have this jack and it works like a champ with lowering springs:
http://www.harborfreight.com/Aluminu...ons-68051.html
supramkivtt2jz is offline   Reply With Quote
Old 02-06-2014, 11:03 AM   #23
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
get some wood and make ramps to drive up onto...easy solution for your lowered car...
Fett4Real is offline   Reply With Quote
Old 02-06-2014, 11:26 AM   #24
iaclimber4
iaclimber4's Avatar
Drives: 2013 Whiteout FR-S MT
I bought this one, similar to michelin jack. I'm not lowered, and i'm glad i got this. Jacking up at the rear diff, the length really helps. It's HEAVY at ~97 lbs though, you'll only roll it around.
[ame="http://www.amazon.com/Arcan-XL2T-Black-Profile-Service/dp/B007G83T16/ref=sr_1_3?ie=UTF8&qid=1391700211&sr=8-3&keywords=arcan+low+profile+floor+jack"]Amazon.com: Arcan XL2T Black Low Profile Steel Service Jack - 2 Ton Capacity: Automotive[/ame]
iaclimber4 is offline   Reply With Quote
Old 02-06-2014, 11:32 AM   #25
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I have Arcan one but it is in red.
Costco has it.
+1 What a coincidence, I started looking into this a couple days ago too! I'm planning to get this one because it's relatively lightweight, not that I'd be lifting it around a lot anyway, but still: http://www.harborfreight.com/rapid-p...html-7814.html
I was also going to get http://www.harborfreight.com/3-ton-h...nds-38846.html and http://www.harborfreight.com/solid-r...ock-96479.html
I posted on this thread http://www.ft86club.com/forums/showthread.php?t=10111 to get GrimmSpeed to relink the photos, but they haven't done it yet.
Is it a good idea to use a hockey puck between the jack and the car to protect the car?
And lastly, sorry to threadjack, but could someone please confirm that the areas circled in blue are the front and rear jack points?
@Selvedge
yes circled ones are jack points
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
Selvedge (02-07-2014)
Old 02-06-2014, 05:10 PM   #26
Don Ivey
Drives: '13 FR-S
Not to rain on anyone's Harbor Freight parade, but you wouldn't catch me under a car only being held up by one (or two). Use jack stands after you get it up in the air. Of course, YMMV,
Don Ivey
'13 FR-S (Hot Lava)
Don Ivey is offline   Reply With Quote
The Following User Says Thank You to Don Ivey For This Useful Post:
torqdork (02-06-2014)
Old 02-06-2014, 07:11 PM   #27
torqdork
torqdork's Avatar
Drives: RV-7
Absolutely agree. And for extra measure after the car is up on four 3-ton jackstands, I place the raised jack in light contact with the crossmember closest to the CG.
torqdork is offline   Reply With Quote
Old 02-07-2014, 02:07 PM   #28
frsvr4
Drives: '13 FRS
So you'd get under a car held up by some other brand jack? I don't care where the jack is from because you don't ever get under a car until its on stands.
How are people minimizing damage to the "support positions" in the diagram? A puck with a groove?
'13 Asphalt FR-S // 6 spd, 3M bra, BeSpoke, Sportsguy83 arm rest, YoSpeed sills & plaque, P3Cars Vent Gauge +oil P sensor; on shelf: SRP pedals
'93 Pearl White 3000GT VR-4 // 5 spd, stock block & 30+ psi: 10.5@135
frsvr4 is offline   Reply With Quote
JACK's BRZ! Mr. Jack Member's Car Journals 10 07-05-2013 10:19 AM
Some interesting background on oil that doesn't require a chemistry degree Chimpo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 04-11-2013 11:24 PM
Does the BeSpoke audio system require an Iphone? Cj_Staal Electronics | Audio | NAV | Infotainment 4 02-17-2013 01:13 AM
Scion FR-S, Subaru BRZ rough idle issues require ECU reflash gunitrecord BRZ First-Gen (2012+) -- General Topics 1 10-06-2012 03:14 AM
Where ti jack car up at? skatery1989 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 08-13-2012 02:53 AM
