#43 | |
Super 86
Drives: Red 86 GTS
End result was a ruined syncro in 6th in my first 4 months with the 86. It's been replaced but now i always go into that gear first. When downshifting and skipping i will still go through all the gears until i reach the desired one then rev match, just so i don't wear the syncro of any gear badly.
230rwhp/184ftlb on 98RON/93AKI
Build thread Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can |
#44 | |
Drives: 2013 Scion FR-S 10 Series MT
Mods: K&N Air Filter - Open Flash Tablet (Stage 1 v1.55) - more to come!
#45 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
I agree with OP. this car could have been a 5spd. I find 3rd or 4th gear useless.
#46 | |
For straight line street driving, I can understand the lack of value of having a 6 speed. 3rd gear redlines at 83 mph, and I'm unaware of any American roads that exceed a speed limit of 80 mph. But then again, what's the point of having a top speed of greater than say 90 mph then? Clearly, 143 is overkill, no? ...and you know, there are those who do like to track their cars. Having a 6 speed makes selecting the proper gear for a given turn much better. Keeping the car within its powerband as often as possible is important and relevant. For those who complain about the lack of torque, 0-60 mph times, or 1/4 times... you guys do realize that a 5 speed would have taller/wider gears, and would make the car even slower, right? Of course, even with a 5 speed, the car could keep a similar gearing ratio, but at the expensive of top speed... and while top speed may not be relevant to everyone, I'd rather not take sacrifices because some people don't "need" the benefits of a 6 speed. EDIT: I have an idea. Why not swap out the 2.0L boxer for a 1.6L boxer (non-turbo). We don't need the extra horsepower and torque for daily driving, and we'd get way better mpg's!!! EDIT 2: Go buy Gran Turismo 6 and try driving multiple cars using both a 5 speed and 6 speed transmission for each car if you still need help understand the benefits of having a close-ratio 6 speed vs a wide-ratio 5 speed. The Evo 8 is a good example that I can recall, which comes with a 5 speed stock; Hint: it's difficult to be in the proper gear for most turns due to being either below the powerband or pegging the redline.
| The Following User Says Thank You to Hanni_0176 For This Useful Post: | Jond63 (02-05-2014) |
#47 | |
Relax.
#48 | |
I also realize that most of said posts were probably sarcasm. But my point still stands.
#49 | |
Like any friction surface the source of wear is directly related to the difference in speed between the two objects. Why would 2->5 be any worse than 5->2? Because the input shaft is slowing of it's own accord? Unless you wait deliberately between gears or double clutch you're putting the same wear and tear in either direction. Again, in the grand scheme of things it may not matter, but if you subscribe to the 'skip shifting is bad' idea, then it's bad in both directions without proper precautions. |
#50 | |
| The Following User Says Thank You to Hanni_0176 For This Useful Post: | strat61caster (02-05-2014) |
#51 |
head of infinite swagger
Drives: 2013 FR-S 6MT
3rd and 4th are my money gears for driving around town, 2nd is just a bit too short.
If anything 5th is redundant, by the time I'm going fast enough for 5th I might as well be in 6th.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater 2000 Silverstone M5 6MT - SOLD 2013 Ultramarine FR-S 6MT - Car Journal - SOLD 2004 AlpineWhite M3 6MT - SOLD |
#52 |
Drives: FR-S 10 Series
I skip 5th on occasion. Getting up to 50 and then just cruise. Don't do it much, but that is the only one I will do on purpose w/o "real" reason.
I skip 2nd some mornings b/c this car seems to hate 2nd with a burning passion in cold weather before everything has warmed up. |
#53 |
Grip>Drift
Drives: FRS
This car has so little torque I wish it had 14-speeeds.
#54 | |
#55 |
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
2nd and 3rd feel the best. Just like in any car.
You are basically saying I like looking at my cake, but I don't want to eat it.
#56 |
Drives: '13 Gen Coupe 3.8 R
This thread...what?
2nd and 3rd gear are like, the life blood of the joy in driving this car. |
| The Following User Says Thank You to R.S-HawK For This Useful Post: | Ramster (02-05-2014) |
| Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode | SteveH | Other Vehicles & General Automotive Discussions | 7 | 02-13-2013 01:08 AM |
| Reverse Gear not going into gear? MT | joergasm | Issues | Warranty | Recalls / TSB | 22 | 11-29-2012 01:08 AM |
| No more 1st gear thump or 2nd gear notchiness | kc4mne | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 09-06-2012 09:39 PM |
| 5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? | kharn83 | Issues | Warranty | Recalls / TSB | 9 | 08-06-2012 08:44 PM |
| Reverse gear on the first and second gear side | randytindoggy | Scion FR-S / Toyota 86 GT86 General Forum | 52 | 01-29-2012 02:21 PM |
